Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 42
    Thanked: 241
    Default Testing battery capacity
    Hi folks
    This may also go under camping/fridges etc...
    What is the correct way to test my camping trailer's batteries ito capacity etc.?
    I want to determine how many days/hours I can run my fridge on the two batteries.
    The theoretical calculation would look something like this: 2x 100Ah batteries = 200Ah. Fridge current draw at 2.5A. Thus, 80 hours run time max. 40 hours if one only wants to deplete batteries to 50%. This calculation does obviously not take into consideration the fridge being opened at irregular intervals.
    So what I did is the following:
    Charged the batteries full with AC charger (13.96V)
    Cooled down the fridge down to 2'C on AC
    Took the batteries of charge and swithed the fridge to DC - battery voltage at this stage 13.02V
    The fridge has now been running for around 24 hours (obviously not all the time, have not been opening it at all) - battery voltage 12.35V
    At what voltage do I assume 50% battery discharge? 12.1V?
    This test I assume will just reflect the theoretical calculation - and proves the batteries are good or not.
    What if I want to do a real time, worst case scenario test? Should I do the same, but set the fridge to -10'C or so, so it needs to run constantly?
    This will show me the shortest possible time I can go without charging batteries, correct?
    Input from the gurus appreciated!
    2014 Hilux D4D dc 4x4
    2013 Metalian Maxi
    Jun 2022
    Thanked: 967
    Default Re: Testing battery capacity
    Quote Originally Posted by KrokODell View Post
    Hi folks
    12.1V should be 40% SOC. Don't think you want to go lower than this on a lead acid battery
    Jun 2013
    Thanked: 5590
    What chemistry ?
    AGM
    SLA
    Deep cycle, high cycle, normal ?
    There will be small variances.
    Stranger
    GOF Club
    BMW R1200R
  4. The Following 2 Users Say Thank You to Stranger For This Useful Post:
    Thanked: 241
    2x Exide SMF100 batteries
    2013 Metalian Maxi
    Lonehill (JHB)
    Thanked: 218
    Hope this chart will help
    2022 Suzuki Swift 1.2 GLX AMT (my city bug)
    2018 Ford Everest 2.2 XLS 2x4 auto (SWAMBO)
    Echo 4 trailer
    2014 Ford Ranger 3.2 XLT 4x4 D/C Auto (sold 2022 thank you Putin)
  7. The Following 9 Users Say Thank You to ChrisH For This Useful Post:
    Apr 2012
    Bela Bela
    Thanked: 588
    I would incorporate a coulometer from Electromannsa into your setup. It has been discussed in the Electrickery thread.
    Pete Williamson
    ADVENTURE BEFORE DEMENTIA
  9. The Following 2 Users Say Thank You to petewill For This Useful Post:
  10. #7
    Thanked: 241
    Quote Originally Posted by petewill View Post
    I would incorporate a coulometer from Electromannsa into your setup. I has been discussed in the Electrickery thread.
    Will have a look
    2013 Metalian Maxi
  11. #8
    Thanked: 241
    Quote Originally Posted by ChrisH View Post
    Thank you. Very handy indeed.
    2013 Metalian Maxi
  12. The Following User Says Thank You to KrokODell For This Useful Post:
  13. #9
    Thanked: 241
    This is from the Hcdp manual. I assume this lockout refers to the voltage level when the system shuts down? Why would they have set it so very low? That is surely a recipe to ruin the batteries.
    The newer National Luna fridges has an option for various cut out voltages - 11.5 being the highest option. Unfortunately my older National Luna does not have a cut out setting and onlu cuts out at 10.5. Again, way too low.
    Is there an option to install some inline cut out device?
    2013 Metalian Maxi
  14. #10
    Gauteng
    Thanked: 2378
    The list ChrisH provided is under no load. While running 50% is perhaps around 11.8V?
  15. The Following 3 Users Say Thank You to ekkekan For This Useful Post:
  16. #11
    Ellisras
    Thanked: 2266
    2000 Patrol GU 4.2D(onkey) "old-timer" chugging along towards 900 000 km, almost.
    2014 Patrol GU 3.0CRD "teenager" in puberty - 160 000 km
    2007 Echo3 Trailer "the nest" with Braked Axle fitted + 265/75/R16 rubber on Patrol Rims!
    Ewiks Caravan Movers now fitted to trailer, lekkerrrr - I should have done that long ago. AND 2.6kW lifepo4 in trailer, 3.1kW lifepo4 in NL box with WRN MPPT/DCtiDF in Patrol, 2x1kW in small packs with MPPC/ DCtoDC as backup in case , all self built, 480W panels Victron MPPT and 220V 25A IP67 charger
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" - 158 000 km
  17. The Following User Says Thank You to Dungbeetle For This Useful Post:
  18. #12
    Lonehill (JHB)
    Thanked: 218
    Correct. Also.... Your fridge might also measure a lower voltage than say when you measure at the battery due to losses in the cable to the battery caused by length or thickness of the cable.
    Echo 4 trailer
  19. The Following User Says Thank You to ChrisH For This Useful Post:
  20. #13
    Feb 2013
    Dinokeng Game Reserve
    Thanked: 6233
    If it helps, in my experience, my NL 90l dual uses around 700Wh over 24 hours while camping in moderately hot Gauteng weather.
    This is with freezer set around -5 and fridge around 0 or 1, that's how I usually set it for a weekend camp, and plenty lid openings cause how else will you get beer?
    Before you judge a person, first walk a mile in their shoes.
  21. The Following User Says Thank You to bigboy529 For This Useful Post:
  22. #14
    Aug 2019
    Thanked: 1862
    Yip and that is just within the reach of a 200 W fold up solar panel. One or 2 shady days you need to take a long drive to charge batteries
  23. #15
    Feb 2013
    Thanked: 6233
    On a good sunny day I usually get around 1000Wh charge from 200W on a Victron MPPT and that's nogal without moving the panels around at all.
  24. The Following User Says Thank You to bigboy529 For This Useful Post:
  25. #16
    Thanked: 241
    So I am not sure what my test tested as I think it had many designs flaws...
    After 96 hours the battery is at 12.15V.
    How can I do a better test?
    Should I pack the fridge full of cold items., then over the course of a weekend open it every hour or so, remove a cold beer... and pack a warm one back. This would be a more realistic test I think.
    Any other ways?
    2013 Metalian Maxi
  26. #17
    Friemersheim, Southern Cape
    Thanked: 8335
    Any other ways?
    The real life situation.
    After 96hrs @ 12.15V is plenty good
    Edit...you read my thread about the older AGM battery...it survived the whole Tankwa trip and still going strong
    Robert van den Berg
    Old Wheeler
    ďThe truth will set you free, but first it will piss you off."
  27. #18
    Hillcrest
    Thanked: 20915
    Any other ways?
    https://electromannsa.co.za/product/...pacity-tester/
    NAGOF
    HAM Callsign - ZS5KAD
    Freedom of speech is useless unless you allow people you donít like to say things you donít likeÖÖÖ
  28. #19
    Hillcrest
    Thanked: 20915
    Maybe we should distinguish between testing a batteries capacity and a batteries capacity to fulfil a specify users needs.
    NAGOF
  29. The Following User Says Thank You to Fluffy For This Useful Post:
  30. #20
    Thanked: 2923
    For wot, R2k, you can have Bluetooth acces, App on your phone and data for the life of the battery.
    https://www.sunstore.co.za/products/...-battery-shunt
    Know your battery usage. Measure it.
    Just saying.
    Political Correctness
  31. The Following User Says Thank You to the_terrible_triplett For This Useful Post:
