This morning on my way to work I collected another chip on the windscreen of my car !The windscreen already looks like something out of a war movie, but I decided I will not change it until I cannot drive safely with it it.
The road between Olifantsfontein and the airport is in such a bad state that you cannot drive in certain lanes, and stones are thrown up every where.
Apart from the 80% of idiot road users using this road, the road itself is now becoming a safety hazard... and SANRAL still expect you to pay for the privilege of driving on this POS !!! But what ticked me off this morning, was a news item that SANRAL did not spend 50% of their allocated budget for road maintenance. The idiocy of this government and its agents is unbelievable... !![]()
Is it not gravel dropped from trucks? Lots of construction along that route
Estee = S T = Sean Towlson, A Schrodingers Douche Bag GOF
''In Western society, it is not the facts or the truth that are important, but the correct presentation of information, even if it is a lie.''
Clank, a 1979 Ex-SADF Series III 109 SW powered by a Toyota 2B Oil Burner
I drive the R21 and R24 on a daily basis. Windscreen chips aplenty.
I drive with a roll of wide sellotape in the cubby. As soon as humanly possible, I wipe clean around the chip and stick a piece of clear tape over the chip.
When I have 3 or 4 chips (also dependent on where the chip / chips are), I phone my chip repairer and he comes to my house and repairs the chips. 99,9% of the time, you cannot even see where the chip was.
Key is to cover the chip with sellotape ASAP so that no dust / air / water goes in and a crack starts running.
(I also see you get round clear stickers from windscreen replacement places to stick over a chip.)
Will gladly share the number of the chip repairer should you wish to give him a call.
Between pomona and airport I replaced my 7th windscreen this year on friday
2020 Toyota Landcruiser 200 GX-R
2018 Range rover sport
2017 BMW M4
I also travelled it last night and got a ping from a stone on the side of my car. No Estee, the top layer is coming away bit by bit. I really feel sorry for my platkar travelling that road.
What did South Africa have before gravel roads - tarred roads, sad but true.
Hmm, I am sure there are more knowledgeable people than I on the forum but sounds like it could be a poorly constructed, old or badly designed seal (bitumen emulsion and bitumen coated smallish stone) applied as part of the maintenance or rehabilitation of the surfacing. These things are somewhat specialized and need experienced design and application. I will say no more.
Frik Eloff
Isuzu 300tdi D-teq, reg vir die bos....
Toyota Tuna 2.7 4x4 .... grudge necessity "not my choice"
There is no doubt that the build quality was below par, in some places where the strips of tar has lifted, you can see the old painted markings. Normally if a road is resurfaced, the top layer is skimmed off to get the newly applied tar something to attach to. Obviously this was not done so as to maximize profits for the cadres....! A few truckloads of asphalt, slap it on an old road with as little effort as possible and viola, a new modern toll road that the cadres can milk billions from !!!![]()
Use to replace 3 windscreens min a year when I travelled Pretoria - Boksburg
Frik Eloff
The R21 was widened towards the median, the existing road surface and base course defects were rectified, and the whole width of the road was then paved with 42mm medium asphalt to improve ride quality, followed by the 20mm UTFC layer
Frik Eloff
A couple of months ago, I was on my way back to the airport with a brand new (sub 500km on the clock) Polo TSI DSG rental.
Got a chip in the windscreen just before the airport.
Not my fault, but I still felt bad.
Current: Mercedes-Benz ML350 4Matic
SWAMBO: 2020 Renault Koleos 2.5 Dynamique
In South Africa that means very little. On the contrary, it seems the bigger and more renowned the companies are, the better the chances are for corruption ! There was plenty of rumours about companies like M... & R....
Do you honestly believe that there is nothing wrong with the initial construction of that stretch of road..?
