Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 41 to 60 of 124
Thread: Tips and Tricks
  1. #41
    May 2016
    Thanked: 9141
    Default Re: Tips and Tricks
    I'm probably not as sensitive, but the cheap hand cleaner I get with the little scrubbing things in it have never dried my hands out...
    Even if hand cleaners did, I would just use them anyway and live with the dry hands. #be-a-man.
    It has worked for me.
    1. Every tip is not for every reader. Use it, or lose it.
    2. I am a man, but prefer well-kept hands. (call that "sensitive")
      I hate dry, chapped hands.
    God gave us reason, not religion
    2003 Mitsubishi Pajero 3.2 Di-d LWB
  2. #42
    Aug 2016
    Thanked: 310
    How and where do you pack a bucket?
    I use an old 5 liter oil can. Cut the top out and add a handle yourself. It packs so much easier being rectangular. My shower gear fits inside except for the poles. Goes directly on the coles or gas stove. You cannot find them anymore so I made up a stainless one. The shape makes for much better scooping of shallow water. Ie flooded tent. Even works as a dust/sand scoop with a brush. Strong enough to work as seat when changing and fixing a tyre.
    What to do with the rubbish bag or wood. Crate on the roofrack used to be the answer. Now everyone has rooftop tents and solar panels. I have a frame that straps on top of the spare wheel on the rear bumper. A milk crate straps on top of the frame. It is much lower to be in easy reach and still lower than the roof. It does not get hooked up on overhanging branches and parking garages.
    A wet 'chammy' is the best for quickly wiping your hands clean when water is scarce. (After breaking camp.)
    When you encounter 40 degrees plus.
    A small spray bottle in your face for overheating and a wet towel on the back of your neck. (First choice is a working aircon and enough fuel to run it.) Also, grab the best tree in the camp site. (Not needed for overnighters.) Add proper insulation to your cab roof and the canopy roof and the firewall. Put your freezer on 25mm of polystirene. Vent the feezer directly to the outside.
    When heavy sand is encountered, do not let the tyres down all the way and do not lock everything that can be locked. You wont have any leeway when the really bad stuff strikes. Rather use the opportunity to learn how to drive in sand. It will be a blessing for the rest of your life. Learn that you let down your tyres down a bit at a time only. If you still get stuck, let it down some more. With this principle you will always get out without overdoing it and writing off a tyre. In bad situations, remove the wall of sand in front of all four tyres or reverse for 2 meters. In 40 years I never needed someone to pull me out of sand. I always get out on my own. Then there is mud. (Different story)
    Take a tyre off a rim at home and find out what tools and skills you need before it happens to you in the bush where there is no back-up.
    If you go in the wet season and sleep in a tent. Get a proper tent that can handle thunderstorms. (Wind and rain.) Surprisingly difficult to find a tent that can then still go up in less than 10 minutes. Practice folding your tent at home. It is so much smaller and easier to pack if done properly. Most tents have some special little tricks like all dome tents. Do the whole job on top of its own ground sheet, then it stays clean. Have a brush with stiff bristles handy to wipe the ground sheet clean as you do the final folds.
    Go camping or touring with a couple of old hands and keep your eyes peeled.
  3. The Following 8 Users Say Thank You to Pieter de Waal For This Useful Post:
  4. #43
    Ruimsig
    Thanked: 43949
    I have heard or seen that tip many times, and tried it once. Didn't work at all for me.
    It takes more effort to rinse the clothes properly than to wash them, and there are no short-cuts to the rinse. In any case, I am not in a situation where I can go on long enough trips that packing enough clothes becomes a problem.
    My mom's drive around Australia, she had 2 drums, the second was for the rinse. 1st drum up to lunch stop, remove laundry and place into second drum. Wash line up on reaching her evening camp, and hang out rinsed clothes. That was here routine and she said it worked a charm. The 2 drums were mounted to the yoke of her caravan.
    Estee = S T = Sean Towlson, A Schrodingers Douche Bag GOF
    ''In Western society, it is not the facts or the truth that are important, but the correct presentation of information, even if it is a lie.''
    Clank, a 1979 Ex-SADF Series III 109 SW powered by a Toyota 2B Oil Burner
  5. The Following 3 Users Say Thank You to Estee For This Useful Post:
  6. #44
    Oct 2012
    Thanked: 1343
    Not really a 4x4 tip but surgical gloves are the business for cleaning dirt bike foam air filters and applying new sticky oil.
  7. The Following User Says Thank You to mudgrubber For This Useful Post:
  8. #45
    Thanked: 4293
    I find I have to rinse 4-5 times to get all the soap out.
    Unlike Iandvl I am not a man. I get bad eczema from clothing detergent.
  9. The Following 4 Users Say Thank You to Peter Connan For This Useful Post:
  10. #46
    Garsfontein
    Thanked: 5565
    I was not referring to laundry detergent. You should try my handcleaner. It works a treat...
    Ian de Villiers
    Patrol 4.5 GRX
    Jurgens XT65 2x0 with Super Select Zero
    ORRA: H80
  11. The Following User Says Thank You to iandvl For This Useful Post:
  12. #47
    Thanked: 7966
    When using hotels.com it is easy to use the filters to ensure the accommodation has a pool, a shower and air conditioning.
    "K.a.k Wheeler
    2006 Jeep Grand Cherokee 3.0 CRD - 399000km and permanent member of the family
    2014 Jeep Wrangler JKU 3.6 - no lift kit and smaller wheels.
  13. The Following 5 Users Say Thank You to Rainier Vermaak For This Useful Post:
  14. #48
    Garsfontein
    Thanked: 5565
    Quote Originally Posted by Rainier Vermaak View Post
    I guess you learnt that from grinder ?
    Ian de Villiers
    Patrol 4.5 GRX
    ORRA: H80
  15. #49
    Thanked: 538
    I made this cage for a customer to hold 2 of those bottles. It fits onto the swingarm of the spare wheel carrier. He has 2 swingarms on the vehicle, so he uses one for the spare and the other for bottles or firewood. It has a lockable strap over the top to stop things from being liberated. Attachment 703538Attachment 703539
    Edit
    I see the washing pot has been covered already
    Platkar 1: BMW 118 (SWAMBO)
  16. #50
    Nov 2014
    Thanked: 7664
    Before working on greasy and oily job, scratch a bar of sunlight to get a layer of soap under your (freshly cut) nails. When the time comes to wash, the soap just dissolves and you don't have to dig under nails with a nail to get rid of the black grime.
    At his best, man is the noblest of all animals; separated from law and justice he is the worst : Aristotle
  17. The Following 12 Users Say Thank You to Gungets Tuft For This Useful Post:
  18. #51
    Ruimsig
    Thanked: 43949
    Spider web is an ideal blood coagulant in case you need one.
  19. The Following 7 Users Say Thank You to Estee For This Useful Post:
  20. #52
    Garsfontein
    Thanked: 5565
    Not only a coagulant, but being protein-based, they are covered with a type of "antibiotic" to prevent organisms from consuming them. So if you dress a wound with spider webs, you're also preventing infection to some degree.
    Ian de Villiers
    Patrol 4.5 GRX
    ORRA: H80
  21. The Following 10 Users Say Thank You to iandvl For This Useful Post:
  22. #53
    Thanked: 5447
    Who and how did someone discover this?
    "When a clown enters a palace, he does not turn into a prince, the palace turns into a circus."
    Luka Geertsema
  23. #54
    Nov 2014
    Thanked: 7664
    Just wait for the Button, Brown Recluse or Sac spider to go out for breakfast before you use it though ...
    But - good tip. I did not know that.
  24. The Following User Says Thank You to Gungets Tuft For This Useful Post:
  25. #55
    Ruimsig
    Thanked: 43949
    Loaded with Vitamin K so helps speed up wound healing too.
  26. The Following 2 Users Say Thank You to Estee For This Useful Post:
  27. #56
    Jun 2013
    Thanked: 5187
    Put a piece of string through your toilet roll. You can hang it on things to keep it out of the dirt or from dropping down the long drop. Make it long enough to hang around you neck if needs be,
    Stranger
    GOF Club
    BMW R1200R
  28. The Following 8 Users Say Thank You to Stranger For This Useful Post:
  29. #57
    Robertson/ Larissa, Greece
    Thanked: 9613
    Gaan maar k$k lyk
  30. The Following 9 Users Say Thank You to Francois Theron For This Useful Post:
  31. #58
    Nov 2014
    Thanked: 7664
    And make sure you don't get it confused with the soap-on-a-rope...
  32. The Following 3 Users Say Thank You to Gungets Tuft For This Useful Post:
  33. #59
    Oct 2012
    Thanked: 1343
    Gaan maar k$k lyk
    I think he means before use
  34. #60
    Thanked: 4293
    Speaking of bog-roll, if you tuck the end into the tube, the wind doesn't un-roll it. And should you drop it, it stays rolled up too.
  35. The Following 4 Users Say Thank You to Peter Connan For This Useful Post:
