Page 2 of 2 FirstFirst 1 2
Results 21 to 37 of 37
Thread: Drowned Pajero
  1. #21
    Oct 2014
    Thanked: 147
    Default Re: Drowned Pajero
    A number of years ago we had a Tazz that got 'drowned'. It had 6000km on the clock and insurance were not prepared to live with a drowned car and replaced the vehicle. I don't think your insurance will repair.
  2. The Following User Says Thank You to Davedusty For This Useful Post:
  3. #22
    May 2016
    Thanked: 9938
    I would insist on it being scrapped.
    I would tell my insurance beforehand that I will NOT be signing a "happy letter", if they decide to try and repair it.
    2003 Mitsubishi Pajero 3.2 Di-d LWB
  4. The Following User Says Thank You to 4ePajero For This Useful Post:
  5. #23
    Sep 2018
    Hi Guys
    Thanks very much for all the comprehensive advice and info.
    It is fully insured, and it was fresh water.
    Unfortunately, it had a new sub assembly only 70000km ago, so it would/should have been good for many more miles... Also recently replaced all the relays etc. To get the 4wd working again - R25k job....
    Any, if insurance offers to write iff, i will probably accept that.
    Thanks again for the replies; very interesting...
    Sounds like a huge project to save her - pity!!
ID:	700611Click image for larger version.
ID:	700609Click image for larger version.
  6. The Following User Says Thank You to Alan Sampson For This Useful Post:
  7. #24
    Feb 2007
    melkbosstrand
    Thanked: 204
    Quote Originally Posted by Alan Sampson View Post
    Hi Guys
    So sad about your Paj...
    As previously mentioned, try buy it back and turn it into a toy? Strip the interior and make it a "play" thing?
    Current: Toyota FJ Sport Cruiser
    Current: VW Touareg Escape
    Previous: VW Amarok ULTIMATE 4motion (auto)
    Previous: Amarok 4motion (MT) with a few goodies
    Previous: Isuzu KB300 Dteq 4x4 not that many goodies
    Prevous: Isuzu KB360 4x4 with a few goodies
  8. The Following 2 Users Say Thank You to jonoB For This Useful Post:
  9. #25
    Mar 2015
    New Germany
    Thanked: 2154
    Take syringe, pull the pusher tube out halfway, dunk the whole syringe under water...
    Yes water could enter the engine, but unlikely if it was not running... You would see I said he must first check that it was free of water...
    The gearbox will have water ingress yes. I agree and never stated that it would not.
    The engine breather pipe? Do you mean the snorkel?
    I spent my last 34 yrs commercial diving and seen how water gets into nearly everything once submerged even by half a meter, unless the intake and exhorts was kept above surface or any vents water will find its way in even via the dipstick
    So yes water will be in the engine
    2002 Defender with 300TDi VNT modified
    2005 Defender TD5 CR VNT turbo, Ashcroft lockers,HD CW&P, HD side shafts & CV and Pegged, 35” coppers STT pro ………..and more
  10. The Following 4 Users Say Thank You to clivemd For This Useful Post:
  11. #26
    Mar 2011
    Krugersdorp
    Thanked: 107
    The water-logged wiring harnesses would be my main concern.
    Claim from insurance, buy the wreck and break for parts.
    I agree, write it off and start over. You dont really want to fix this car. It will drive you crazy in the future. Buy the salvage if you feel up to it and strip for spares.
    Alan Exton
    ZS6E
    LandCruiser 100 Series VX 4.2 Diesel
    Isuzu Mux 4x4
  12. #27
    Jan 2009
    Mbabane
    The very last sentence should have been the opener here.
    Quote Originally Posted by marcus d90 View Post
    This is what i have learned since i had drowned my Ford Courier 4WD V6 about 20 years ago.
    Do not turn the engine over with the key, even if plugs removed.
    Put it in gear and push it first to get the most water out, then crank it.
    Remove the air filter , if there is water present, there will be water in the engine.
    If the entire engine was submerged, there will be water in it.
    If it stood like this for a short while, you will have to strip off the intake and tappet covers
    to clean off the rust and dirt. Flush the engine.
    The cambelt tensioners might have water damage if it was standing in water for a while.
    The clutch should be fine if submerged.
    Drain all fluids, and replace. If milkshake, flush couple of times.
    The radiator might be blocked with mud.
    The electrical system will be a nightmare, clean the fusebox with plenty electrical contact cleaner.
    Your Alternator might be clogged with mud. Check all connectors. The ECU might be damaged.
    Remove all door panels and boot panels, clean properly in the crevices.
    If your vehicle was submerged in salt water , let the insurance scrap it.
    2022 Prado VX-L
    2016 2.2D Rav 4 VX
    2014 Lexus IS350 EX
  13. #28
    Garden Route
    Thanked: 537
    The insured value of a 2003 vehicle is going to be nauseatingly low 🙈🙈🙈
    It takes 2 years to learn to speak & 60 to learn to keep your mouth shut
  14. The Following User Says Thank You to rodneykdc For This Useful Post:
  15. #29
    May 2016
    Thanked: 9938
    Quote Originally Posted by rodneykdc View Post
    That's exactly why I suggested that he buys the wreck and break it for parts.
  16. #30
    Feb 2016
    Klapmuts
    Thanked: 16
    Quote Originally Posted by Wilk View Post
    I will not crank it before the oil is drained (and water). New filter and oil. Then you can can remove the Injectors and get the water out.
    Why would water get into the engine? It's a diesel and it seems logical to me that the only way to get water into the engine would be if it was running when the water flooded it.
  17. #31
    Thanked: 3277
    Quote Originally Posted by lifeboy View Post
    The sump and bottom end of the motor isn't sealed, it has vents. There will be some exhaust and inlet valves that will be open, even only slightly. The water will have found its way into all parts of the motor. As was posted earlier by the member that is a commercial diver, the motor will be full of water.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
    Jurgens Xplorer (Home from Home)
  18. #32
    Langs die rivier, op n berg
    Thanked: 6791
    N stilstaande engine het altyd van valves oop. Maak nie saak of intake of exhaust valves, as n valve oop is, sal water of deur intake of deur exhaust bo pistons in kom.
    Net so sal water deur breather pyp by intake pyp net na lugfilter in kom en crankcase (maw olie) vol water maak.
  19. #33
    May 2016
    Thanked: 9938
    I would bet a few bob on the fact that at least one combustion chamber and the sump are flooded with water.
  20. #34
    Apr 2022
    Hartbeespoort
    Hi Guys
    Advice please... My 2003 Pajero diesel was drowned up to roof level in the recent Cape floods. It was standing idle at the time with the battery disconnected. What needs doing (apart from cleaning - everything covered in silt!).
    Eg. Air cleaner, oil, fuel??
    Eish!
    Alan Sampson
    If you do any form of work on the vehicle, even recovering it off the beach or wherever it was, the insurance will use it as an excuse and will deny all liability. They want to assess first. Idiots.
  21. #35
    Oct 2007
    Wichenford, United Kingdom
    Thanked: 211
    My son is a game ranger and during a flood one of the Toyotas ended up being submerged to top of doors for 3 days. They dragged it out and towed to onsite workshop. Mechanic did a clean and the darn thing started with no issue! Everyone was quite surprised that no major work was required.
    2018 Jeep Grand Cherokee Overland CRD chased by a 2018 Buccaneer Cruiser twin axle caravan.
  22. #36
    Jul 2018
    Kathu
    Thanked: 411
    please keep us updated?
  23. #37
    Thanked: 527
    Does insurance have it?
    If I may ask, if they did, what did you settle for?
    Andrew to all.
