Results 1 to 18 of 18
    Mar 2012
    Thanked: 49
    Default Grand Vitara questions
    Hi All,
    I am looking at getting a GV as a daily runaround.
    The vehicle will be used mostly for the morning run which is roughly 8kms a day, and on weekends and holidays. So fuel consumption is not that big of a deal.
    Is there anything I need to look for specifically? Model, Year etc.
    What Mileage is acceptable? Is it worth looking at a higher mileage 150K kms+?
    I cannot find any 3.2s for sale, so it will probably be a 2.4.
    EDIT: I have also noticed that some has the ESP button, and some not? but they all seem to have LR?
    Just want to get some insight on these vehicles, as I only know the Pajero's.
    Thanks!
    Current: 2019 Honda CR-V 1.5T AWD
    Ex: 2015 Pajero LWB Di-Dc Exceed (SOLD) Rattle mobile
    Ex: 2010 Gen 4 3.8v6 Pajero SWB (SOLD)
    Ex: 2011 Mazda 3 MPS (sadly Sold)
    Ex: 2004 3.5 v6 SWB Pajero (SOLD)
    Ex: 2007 Clio RS 197 (SOLD)
    Apr 2012
    Thanked: 56
    Default Re: Grand Vitara questions
    I just bought a 3.2 and waiting on delivery.
    I looked for a long time, and the one I bought has some small niggles that I need to sort out.
    I sent it for a full Dekra Technical inspection for peace of mind, so I at least know what I was getting myself into.
    at 180 000kms, I expected more issues to crop up, but pretty much just the normal wear and tear items.
    Some stuff I've heard of to look for:
    Power steering leaks
    If Auto, make sure the gear shifts are smooth and not rough
    I haven't encountered any posts or big issues to look out for during my few months of searching, but I specifically looked at the 3.2.
    2014 Jimny with some Bits & Bobs(Sold)
    2000 Kia Sportage(Sold)
  3. The Following User Says Thank You to ...kRiLLiN... For This Useful Post:
    Thanked: 25
    Goodday
    You are correct all the GVs have lowrange. If I remember correctly in 2015 till later there were two models. The Dune without ESP and traction control and The Summit with ESP and traction control.
    If you can't find a 3.2 I would suggest that you look for a Summit that does have all the electronic aids.
    Goodluck with your hunt.
  5. The Following User Says Thank You to Roverland For This Useful Post:
    May 2012
    Thanked: 3962
    If looking at a manual, check/test the clutch. The 2.4 GV's known for a "weak" clutch.
    Depends on what you are intending to do, the Dune can be a bargain. It would not perform very well on rough axle twisters that you cannot approach with a bit of momentum. But if that is not on the cards then one could consider a Dune.
    Sarel
    "Grent" Vitara x 2
    (One legit and one platkar masquerading as a GV)
  7. The Following User Says Thank You to New For This Useful Post:
  8. #5
    Aug 2017
    Thanked: 758
    Quote Originally Posted by ...kRiLLiN... View Post
    Thats about the mileage where your 3.2 will likely start giving throttle body issue, most I've seen have that niggle at the 180k mark, some worse than others.
    OP if its an early 2.4 there was a problem with cracked blocks or heads (can't recall which) so you should check that's been sorted during its life. Front control arms also seem to need regular replacing, especially if the car has a lift kit. Check the transfer case CV joint, and check for leaks on gearbox seals and rear main crank seal. Off the top of my head those are the main issues you might come across.
    2010 Suzuki Grand Vitara 3.2
  9. The Following User Says Thank You to MarshallGTi For This Useful Post:
  10. #6
    Mar 2012
    Thanked: 49
    Thanks for the info. I have however seen some versions new that says dune, but it has the ESP.
    Is the ESP worth looking for/paying extra for?
  11. #7
    Jun 2016
    Randfontein
    Thanked: 12446
    The Dunes with ESP are listed incorrectly.
    The models before (cant remember the year models now) the Dune and Summit also had ESP. But they were not called Dune and Summit.
    Maybe post some links of the vehicles that interest you.
    2024 Mahindra S10 Pik Up 4x4 d/c
    2010 Isuzu KB250 dteq d/c
    2023 Suzuki Ciaz (Swambos platkar)
  12. #8
    Thanked: 25
    Before 2015 there was only the full spec withe traction control etc. Then became a Dune and a Summit. The Dune doesn't have this. I had a Dune and now a V6. Click image for larger version.
  13. #9
    Jun 2016
    Randfontein
    Thanked: 12446
    Quote Originally Posted by Roverland View Post
    I think its 2012 because I had a 2013 Dune
  14. #10
    Thanked: 25
    Willie you are correct. The Dune was introduced in 2012. My memory slipped me. I had a 2015 Dune.
  15. The Following User Says Thank You to Roverland For This Useful Post:
  16. #11
    Mar 2012
    Thanked: 49
    I had a look at one this morning. 2010 2.4, 179k KMS. Has the ESP. Drives very well. But it has a slight shudder on the Clutch in 1st gear. No slipping. is this something to be concerned about? Also, do they have a timing belt or chain? And at what mileage are they due for replacement?
  17. #12
    Jun 2016
    Randfontein
    Thanked: 12446
    Quote Originally Posted by Vuil-uil View Post
    The clutch shudder is not good.
    They have a cam chain, no need to replace unless it gets noisy.
  18. #13
    Mar 2012
    Thanked: 49
    Quote Originally Posted by WillieJimny View Post
    So best to rather steer clear of this one? So the hunt continues!
  19. #14
    Feb 2013
    Springs
    Kyk by Suzuki Boksburg
    2013 model automatic +- 55000 Km
    Was my Grand Vitara
  20. #15
    Thanked: 1185
    Around 150+K is when the fuel pump should be replaced. Check that.
    '09 Suzuki Grand Vitara 3.2
  21. #16
    New Germany
    Thanked: 378
    Quote Originally Posted by AncientGeek View Post
    Out of curiosity, what would be the symptoms of a fuel pump failure assuming it hasn't failed completely?
    Wondering how to check when buying a vehicle.
    2008 Suzuki Grand Vitara 3.2 V6
    2012 GWM Steed 5 DC 4x4 TCI - Sold
    2002 Isuzu Frontier 280dt LX 4x4 - Sold
    2000 Suzuki Grand Vitara 1.6 3dr - Sold
  22. #17
    Thanked: 1185
    Quote Originally Posted by kippie2 View Post
    Not easy to check. The problem is (I think) not so much the pump but the filter which is built into the pump.
    On mine I got loss of power and misfiring if I put my foot down. But only if the air temperature was above 30 degrees. My theory is cavitation occurs with a partially blocked filter.
    I had already replaced the throttle body.
    I think that is why I got it relatively cheap. The PO was unable to solve that (but did not tell me).
  23. The Following User Says Thank You to AncientGeek For This Useful Post:
  24. #18
    Jun 2024
    Hi guys
    So this is my first post ever. And was hoping someone can help me or point me in the right direction.
    I'm currently driving a 1400 champ but looking at something a little bit bigger and capable as I work in the mountains (trail builder) and bumped into a 2001 Grand Vitara V6. Been reading good things and noticed one thing to look out for is the timing chain.
    The vechile is up for 65k. It has 265 000km on the clock and apparently only been serviced at Suzuki with provided invoices of work that has been done on it. Engine was rebuilt completely at 180 000km. I'm planning on checking it out this week out of curiosity. But I'd like to hear from you guys what I should look out for and if the price seems suspect or is that in par for the age being just over 20 years old now. From the photos it seems nice except for some rusted bolts and steel mounting bits (lived close to the ocean mostly) but the owner says there's no rust or body work done on the car.
    It would be my daily, so another question I would like to ask is if it can be a cheapish daily runner fuel wise (considering its a smaller than usual V6 SUV) and if it's expensive parts wise to maintain.
    I'm new to 4x4 vechiles in general so any advice would be great 🙌
    Lekker!
  25. The Following User Says Thank You to FlowScape For This Useful Post:
