Results 1 to 10 of 10
    Aug 2016
    Default Adapter for Afrox Gasbottle
    Hallo,
    I want to go for 3ó4 month to East Africa. I have 9 kg Gasbottles from Afrox. I donít want to change them to Cadac or so. I am looking for an Adapter. Can you help me. Afrox canít help. Is there some one hoe can give me, ore got the measurement and then I can make meine here. Thank you very much.
    Reg. Jochen
    Gaborone, Botswana
    Thanked: 3089
    Default Re: Adapter for Afrox Gasbottle
    Are you using a regulator on the 9kg cylinder?
    Kobus
    Aug 2016
    Yes I am using a Regulator.
    Aug 2017
    Nylstroom
    Thanked: 2446
    Go to your local gas place with the cylinders and stuff. You get big to small and small to big adapters so you can use them across regulators.
    Thanked: 4646
  6. The Following User Says Thank You to IcePick88 For This Useful Post:
    Thanked: 2440
    Deleted
    Thanked: 2720
    There are numerous adaptors available at LP gas suppliers and camping shops. What do you need to connect to the standard 9kg bullnose fitting on the cylinder? The two in the photos below are from Leroy Merlin, but they can be found at different shops, too. The blue one is probably the more versatile as you can connect a cooker plate onto it. Click image for larger version.
ID:	694687Click image for larger version.
    The humble person makes room for progress; the arrogant person believes theyíre already there.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
    Jurgens Xplorer (Home from Home)
    Aug 2016
    Sorry Gentleman, I am looking for a Adapter for East African Gasbottles. What I mean is, I want to refill my Afroxbottle in East Africa.
    say my Afrox 9 kg Gasbottle is empty and I have to refill it. They got in East Africa a different inlet. So my Adapter must fit the one side for Afrox and the other side East Africa.
    Thank you Reg. Jochen
    Aug 2017
    Nylstroom
    Thanked: 2446
    Quote Originally Posted by Jochen.p View Post
    You'll have a problem. They're not allowed to refill bottles with adapters on them, adapters are removed before refilling.
    Thanked: 4646
    Maybe should have lead with this first.
