Results 1 to 5 of 5
    May 2007
    Hillcrest
    Thanked: 174
    Default Inner Tube Issue
    Hoping someone here can shed some light on an issue i am now having
    I have a Yamaha TW200 that is used on week ends to beat about the bush with.
    In the last 200km of riding I have ripped up two inner tubes
    Now, this is not an MX bike that I go tearing through the veld with at top speed
    (top speed on this farm bike being 90km/h on a down hill)
    This thing is also not a sport bike with the pull off power of a rocket
    Most trails are done in first or second gear at an almost walking pace.
    But I have now twice ripped the tube open at the valve.
    My first thought was maybe tire is moving on the rim, but I doubt it, as I know how well seated that tire is after trying to get it off that rim.
    Anyone else had an issue like this before?
    Trying to understand the problem before I go spend another R600 on another inner tube
    You don't need eyes to see...
    You need vision.
    Addo
    Thanked: 377
    Default Re: Inner Tube Issue
    I had the same problem on my 125 honda , I then bought a heavy duty inner tube and the problem went away
    Range Rover Sport SC 4.2 V8 ( FATBOY )
    Disco1 V8 ( LAZYBOY )
    Austin Mini 1380cc ( Finiky )
    Oct 2012
    Thanked: 1385
    Low tyre pressure and no rim lock (s)?
    cape town
    Thanked: 378
    front or rear wheel ?
    are you powdering with talcum before installing the tube,
    wet the tyre bead with liquid soap,
    pumping up till the tyre just takes shape then bouncing the wheel a few times along its circumference before fully inflating ?
    Jun 2022
    Thanked: 809
    Rim lock absent or faulty
