SNA additional 6-Months
Hou op om almal altyd gelukkig te probeer hou, Jy is nie n braaibroodjie nie
Is it just me or has the app and online monitoring been really temperamental these days? I find it is regularly offline and sometimes struggle to change settings or get updated info...
Sarel
"Grent" Vitara x 2
(One legit and one platkar masquerading as a GV)
So I have the SNA5000wpv hooked up to a Hubble AM-2 battery, with 4 x 340w solar panels.
Previously I had an Axpert 3kva with Am-4 battery and the panels. They worked great for like a year, but we wanted to go the legal route so went to the luxpower last Wednesday.
All was working ok until yesterday when I had a small amount of reverse flow that triggered the tamper mode of my meter. How do I know this, it's the first thing the CoCT said, "do you have solar?". And with the Siemens Prepaid Meter, it's very sensitive to reverse flow.
The obvious solution is a CT Sensor, but seems this inverter cannot get one.
This is giving me a headache as I have had to turn off the mix PV and AC mode otherwise it might trigger the tamper mode again on the meter.
Hopefully there is a way I can install a device to prevent this back flow, but if not I would prefer to get a Deye as they can get a CT sensor.
Regarding the app, it was offline today. It also reads my battery as 50ah instead of 120ah. And the way the try prevent you from making changes in the app without administration codes is a little annoying.
So far not very happy.
Hi
This training video from Luxpower will help https://www.youtube.com/watch?v=gWGFs7cP0Tw&t=2310s
There is a really good WhatsApp support group run by Luxpower. You can enter your problem here and they will respond relatively quickly. They also so remote firmware updates etc. from here. https://chat.whatsapp.com/HYx7K33TWNg0Wg0KWaPnTi
The Luxpower SNA is a very good inverter, but if the SNA model doesn't work out, there is a very well priced bigger brother, the Luxpower LXP model that has the CT clamp. Fanless, noiseless and manages everything for you.
https://luxpowertek.com/lxp-hybrid-3-6k
His - 2023 Subaru Forester
Hers - 2023 Toyota Corolla Cross 1.8XS
Clouds is doing good today ....
<<Confucius said>>
Hi All,
Push notifications is now available on iOs and Android ...
Currently only available when AC is off / Loadshedding ...
Need to be on iOs 2.0.4 or Android 3.0.6
All the Luxpower resellers sell the LXP5, LXP10 and LXP12
https://www.pvpower.co.za/product-ca...-power-hybrid/
