Hi all
Have just put in a second battery in my Prado.
Am also just about to go overseas for a few months. When I do this I always use a battery conditioner, so the battery does not go flat.
What do I do with 2 batteries ?
If I attach the conditioner to the main battery, will it also look after the second ?
Or do I need 2 conditioners ?
Or disconnect the 2nd battery ?
Failed the physical for the Groot Trek
If it is 2 or 3 months then I would disconnect them, full charge them and leave them like that, recharge when you return.
If its more than 3 months I would remove them and place them together, fully charge them, then connect them in parallel and put them on a trickle charger till you return.
Assuming its lead acid batteries.
For lithium just leave them at 80% SOC.
How is the second battery connected ?
My Pajero stands a week at a time and I put a 50 W solar panel and PWM controller together. BH connector to the main battery. It has shown to charge the aux battery through the aux system.
Stranger
GOF Club
BMW R1200R
Not sure what dual battery system you have. I have a CTEK D250SA. I just leave the solar panel connected to this unit when parked at home.
Page 4 of the manual states that:
"Trickle charging of the starter battery from a solar panel
The D250SA trickle charges the starter battery from a solar panel at intervals of 3 seconds if theservice battery is fully charged."
Have not seen any specific negative consequences over the past 4 years.
Alfa 159 - die dors ene, met 6 silinders
Jimny GL Auto - Swambo se nuwe daily
VW T5 4Motion - cause there ain't no Italian 4x4 kombies
Alfa Giulietta - sodat Mini-Me nie geld kan mors op drank en sigarette nie
I connect my 15a victron charger to the starter battery only.
After a certain period of time (not sure if determined by the 5min timer or the voltage level of the starter battery) the National Luna solenoid clicks on thereby opening the line to the auxiliary batteries (I have three) and the charger just carries on happily keeping all of their levels up until one day I decide to take a spin and disconnect the charger.
Im no expert, I might be doing something wrong but it works for me (and my batteries).
Your mind is your strongest weapon.
Then there's.....POWER TOOLS!
2021 Mahindra Scorpio S11 SUV.
'00 Frontier 280DT 4X2
2002 Sprite Surfer Nomad
'94 Cruiser 80 GX (Sold)
first make sure 2nd battery is fully charged
then put charger onto the starter battery.
Yep, make sure both batteries are fully charged, then connect them together, put the charger on and leave like that.
Thats a perfect world. Real world, just connect both to the charger and go overseas.
I am however a bit concerned with the word "conditioner". What is that.
Maintenance charger is what you really need.
NAGOF
HAM Callsign - ZS5KAD
