Wrangler 4dr 15" / 16" Rims for Wrangler Unlimited?
Results 1 to 13 of 13
    The Windy City
    Thanked: 3849
    Default 15" / 16" Rims for Wrangler Unlimited?
    Has anybody found suitable 15" or 16" rims yet for a Wrangler Unlimited? The price of the 17" tyres scares the living daylights out of me!
    I see in 2004 they launched the Wrangler Extreme Sport with 15" rims, any chance that those will fit?
    What is the rim specs I need to look out for?
    Are there any other implications in changing down from the 17"? (Other than a huge cost saving in tyre replacements!)
    Thanked: 28
    Default Just out of curiosity?
    Hi, I was just wondering what is the price difference between the sizes you mention above? And does brand play a big difference?
    The Windy City
    Thanked: 3849
    Brand does not make a difference.
    Problem with 17" is price and also availability, there are very few choices. For example in the Maxxis ranges the only choice is Bighorns, one size, one model.
    Price for a 17" tyre with semi offroad use is over R2700.00, similar tyre in 15" just over R1000!
    Strand
    Thanked: 47
    Dirk,
    Nie seker wat julle band grootes vir die 17" rims is nie - het gesien Maxxis het 265/65/17 Bighorns (ingebring vir Navara) op special vir 1650 per band. Sommige plekke verkoop ook nou D694's vir 1900 per band. (Selfde bande was 'n jaar terug 2450 per band.) Lyk of dit nou 'n goeie tyd is om 17's te koop as mens kan.
    Joburg
    Thanked: 25
    2004 would be a TJ. Different PCD to the JK.
    Will 15's clear the brakes?
    Stu.
    Current:
    06 Wrangler Sahara. 3.5inch Rubicon Express and Bilstein lift, Metalcloak control arms, 1.25" RC Body Lift, 1" JKS MotorMount Lift, Zone Disconnects, BFG KM2 33's
    NO LOCKER NEEDED!!!
    KTM 1190 Adventure
    Joburg
    Thanked: 25
    Seems you just need o get the Backspacing right, but you still may have to grind the calipre setup down a tad.
    33x15
    They say some fit, some dont.
    Stu.
    Current:
    NO LOCKER NEEDED!!!
    KTM 1190 Adventure
    On the edge...
    Some 15" rims do fit, but they are not the norm. Most tend to rub the callipers. The steel 15's seem to be the best option as they have a thinner wall than the alloys.
    But, even if they do fit the clearance is very tight.
    The PCD on a TJ is 5 on 4.5, where as the PCD on your JK is 5 on 5. There is an adaptor available to change from the 5/5 down to a 5/4.5.
    Other than the price there are no pitfalls dropping down to a 16" rim, just more rubber.
    Dec 2007
    Harties
    Default m2cw
    Hi Dirk,
    Just my 2cw.
    I changed from the 17's to the 16's, softer ride and better off-road "Performance" Less side wall punctures ect... I tried the 15's(Alloy) on the jeep as i originally wanted to go with 31's, however they did not fit over the front caliper. I dont think the wrangler and Cherokee is the same but some input might help. Price wise i still think going 15's will be the best as the 16's and 17's are more expensive than the 15's. Good luck and remember to post pictures....
    I like anything with 4 or more wheels...
    Jun 2007
    Hi Dirk
    Also looking for a set of 16x8 rims for a Jeep JK Rubicon. Best price so far was R1150 plus VAT for the Cragar Black Rock steel rim from US Parts in Cape Town.
    http://www.usparts.co.za/contact.php
    They import almost all the rims sold on the Quadratec wesite.
    http://www.quadratec.com/jk_wrangler...ls/default.php
    The Windy City
    Thanked: 3849
    Thnks, sal ook met oom Francois chat om dalk saam te order.
    Thanked: 1041
    Quote Originally Posted by Jakiesespeelding View Post
    Dirk,
    jon het nie stock op daai size nie en is heelwat duurder. Daai prys is seker ex vat. Die 265 70 17 is omtrent r2500
    Training: 4x4, bush mechanics, recovery, defensive, 4x4 trucks
    Angel Construction
    COMBAT19: Large scale fogging and decontamination of coronaviruses
    [email protected]
    [email protected]
    +27824453301
    The Windy City
    Thanked: 3849
    I found rims! Jeep original from Mopar, available from the agents for about R1450 incl. VAT.
    16" X 7" Wheel With Mopar Unique Finish. Finish is Machined Alumnium with Black Vent Pockets.
    5-spoke, with Jeep logo center cap
    Jun 2008
    pretoria
    What size tyre do you plan on fitting? I also need to change but want to change to a 33"
    2020 Toyota Landcruiser 200 GX-R
    2018 Range rover sport
    2017 BMW M4
  1. Defender 110: 15" of 16" staal rims
    By andrewbk in forum Land Rover
    Last Post: 2011/04/04, 08:17 PM
  2. I need 16" Navara Rims
    By 4X4byFAR in forum Nissan
    Last Post: 2010/09/28, 08:04 AM
  3. 15" vs 16"
    By Navigator in forum General 4x4 Discussion
    Last Post: 2010/06/18, 04:41 PM
  4. Steel GLX 16" rims for a 1999 Gen2.5 Pajero
    By andre plant in forum Mitsubishi
    Last Post: 2010/03/03, 02:46 PM
  5. 16" rims for 2008 Hilux 4x4
    By Janpetrus in forum Toyota
    Last Post: 2009/08/17, 11:55 PM
