Results 1 to 11 of 11
    Jan 2017
    Default NP300 Double Cab 2.4 Petrol vs. 3.5Tdi (2x4 or 4x4) in 2022
    Like so many others in the past I'm new to Nissan bakkies. I've recently learned that they are well priced and it seems like the market is full of second hand options. I've got a business that requires us to drive 50% of the time on gravel roads to mines and farms.
    So far we have been using a NP200 for these trips, but I've recently gotten the idea that a larger bakkie would do better on the heavy "sinkplaat" gravel roads. I've been reading up on the older posts on 4x4 Community all morning and it seems like over the years from 2009 to 2019 there was lots of talk about the NP300 with various good advice. So I'm asking to see if anything has changed in the recent 3-4 years.
    I'm looking for any advice on what would suit us better:
    1. I need to look at fuel economy, so deciding between the Diesel 2.5 vs the Petrol 2.4 and 2x4 vs 4x4, I would have to take this into account. I accept the NP300 will be heavier on fuel than the NP200, so no need to point that out, I'm not looking comparing oranges to apples here. I read somewhere that comparing km/l, the 2.4 is the heaviest with about 8km/l. Then the 2.5Tdi seems to be able to deliver up to 12km/l?
    2. I also don't need anything fast, the slower it is the better (basically use as a work vehicle it should not be able to race with the vehicle).
    3. I also enjoy the fact that the NP300 is an underspec engine of the Navara, since it ensures reliability is high and speed/torque is low (again for business purposes, that is good).
    4. I've always driven petrol, but I expect that Diesel will give me more pull on bad roads with load, vs the petrol, but using less fuel liters?
    5. Also because the 2.5Tdi is such an old engine, I also expect it to be very reliable and lots of spare parts available (to cost of ownership is better).
    6. I like fixing vehicles myself, so the more basic the engine the easier the "DIY" fixes.
    It seems in the recent years, you basically one have the 2.4 Petrol and 2.5 Diesel, and they both come in 4x4 and 2x4.
    Since I'll be buying second hand, I see that I also have the option of getting 4x4 for decent prices. If I can easily choose between 2x4 and 4x4, would I be wasting a lot on fuel economy if I drive the 4x4 in 2x4 most of the time? I'll be looking at a 2014+ model, but I heard that after a certain model (was that 2015?) the vehicles got ABS and airbags. I would rather try to get ABS and airbags, if this means looking at 2015+ models. Please let me know. Also my budget is R200k, I see that I can get DC vehicles below 100k on the clock for under R200k.
    I've also not sure, but are the NP300 discontinued? Or did I read that on a oversees site, not applicable to SA? This doesn't bother me, but I believe second hand prices will then drop more.
    The only reason why I like the idea of going for a 4x4 is that it may handle load (trailers or 400Kg loads on the back) on gravel roads better, if needed, driving slow is fine. Also thinking of driving in rain on wet roads, I may one day find myself using the 4x4 to ensure I don't get stuck in pools of water on the gravel roads.
    I will never do off-road with the bakkie, it's strictly for driving to and from sites for work. I will also not be modding the vehicle at all. I want the vehicle to be as stock as possible.
    I do want to go for Double Cab since it can carry 4 people, or sensitive equipment on the back seat, out of water and dust. It also seems to me that the double cab has the "most" cabin features. But I also don't want fancy electronic features. For a work vehicle the harder it is for something to break the better. So especially the manual cabin slides are a big plus to me. I saw that most DC's do come with electric windows, but if I have a choice I would prefer manual windows. Again, since they have less that can break.
    So back to my question,
    if you feel I'm making a mistake, please say so.
    Also I need to decide between Diesel vs. Petrol and 2x4 or 4x4.
    Ellisras
    Thanked: 2410
    Default Re: NP300 Double Cab 2.4 Petrol vs. 3.5Tdi (2x4 or 4x4)
    NP300s are basic workhorses of note. But be aware the double cab is very cramped in the rear
    Don’t blame yourself over past mistakes. It’s like driving down the N1 while looking in the rear view mirror only.
    2000 Patrol GU 4.2D(onkey) "old-timer" chugging along towards 900 000 km, almost.
    2007 Patrol Pickup TD42 "bulldozer" - 500 000km
    2014 Patrol GU 3.0CRD "teenager" in puberty - 180 000 km
    2007 Echo3 Trailer "the nest" with Braked Axle fitted + 265/75/R16 rubber on Patrol Rims!
    Ewiks Caravan Movers now fitted to trailer, lekkerrrr - I should have done that long ago. AND 2.6kW lifepo4 in trailer, 3.1kW lifepo4 in NL box with Victron MPPT and DC-DC in Patrol, 2x1kW in small packs with MPPC/ DC‐DC as backup in case , all self built, 480W panels Victron MPPT and 220V 25A IP67 charger
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" - 158 000 km
    Thanked: 960
    Taking everything you said into consideration, the 2.4 D/C would be my choice. Choosing between the 4x4 or 2x4, that will be up to you to justify, but I am confident the 2.4, that has rear diff lock, will be fine.
    '00 Nissan D22 QD32Ti 4x4 D/C - many, many mods.
    '10 Toyota LC150 1GR-FE VX - stock
    '10 Yamaha XT1200Z Super Ténéré - stock with some farkles
    - Our lives were governed by the Ten Commandments, good judgment, and common sense. -
    Jun 2016
    Secunda
    Thanked: 27
    Quote Originally Posted by swakop_toe View Post
    I would also choose the 2.4. These bakkies are donkeys but Africa proof. Less chances of dirty/wrong fuel damaging the engine, filters getting clogged etc. How does the saying go? With less power comes more reliability!
    2013 Nissan Navara 3.0 DCi 4x4 D/C - Rooigevaar
    Jan 2017
    Good to know, but since we will not use the back seats that often, I believe it will be ok, for the few times someone need to sit there.
    Quote Originally Posted by Ratelrooi View Post
    Is the reason for recommending the 2.4 Petrol only because of the simplicity of the petrol engine? I've leaned towards the Diesels because of better fuel economy, with the same level of "power" than the 2.4 Petrol.
    (I did read that people have had problems with using diesel filters that are not original Nissan filters, so I'll have to keep to using Nissan filters.)
    I'm also thinking that looking at the fuel economy, I may want to reconsider only having a NP300 and maybe look at getting a NP200 for the trips that don't need the grunt of the NP300. I hear the NP200 give about 18-20km/liter. Which means normal trips would cost half te cost with the NP200 vs. the NP300. But ok, I may need to look at budgets again to see when this would be possible in the future.
    Thanked: 960
    The savings in maintenance on the 2.4 you will use in fuel, in my opinion. And with diesel practically as expensive as petrol, stick to the motor with much less moving parts?
    The NP200 is a car with a bucket.
    It will disappoint you where you describe you want to drive and use it for.
    Jan 2017
    I've now spoken to a mechanic as well, and it seems like going 4x4 is worth it if it does not cost that much more. Since you have it when you need it and when you don't need it it's just like a 2x4 anyways. Also the 2.4 petrol still wins for maintenance, but I've realised that I "want" diesel anyways.
    So I'm going for the 2.5TDi 4x4.
    The NP200s are like a car with a bucket
    But I've actually driven one, and yes they are not built for anything extreme. But my suggestion for NP200 was just for city driving and highway trips. The NP300 will do the rural trips.
    If anyone can help me with this, I've looked on AutoTrader and found that there are some NP300's that are priced way lower than the average. I'm wondering why, since they are not old or have high km's compared to the other ones that are about 100k more. The only difference are that thay are silver and not white.
    https://www.autotrader.co.za/cars-fo...on=RetailPrice
    Can the silver color be the only reason they are so cheap? Also they have been listed since last year, so it's not like they are going quickly, so what could perhapse be the reason no one wants them (and even the sellers know that and have priced them accordingly)?
    Jan 2022
    Kempton park
    Thanked: 867
    Quote Originally Posted by bernarddt View Post
    Silver and white are the most easy to sell colours. Sometimes whatever you see advertised cheap is because it’s been dragged through barbed wire by the previous owner and you don’t really see it on pics.
    Jan 2009
    Thanked: 393
    All those silver ones at the end of your search is from the dodgy dealers in Jhb-CBD - not the type of people you want to deal or buy a car from - old saying, if it is too good to be true.....
    Martin Pienaar
    Thanked: 766
    Be warned. The 2.4 petrol is very thirsty.
    The 2.5 TDI has much more power than the 2.4 petrol and is actually not to bad to drive.
    I currently drives a model 2018 2.5 TDI D/C 2x4. Previously had a 16VTD in D/C 2x4 for working purposes.
    Don't be fooled by manual window winders being more reliable.
    My experience with many vehicles shows that electric windows are just as reliable, if not more so.
    Jan 2017
    Quote Originally Posted by Andrew V9X View Post
    Quote Originally Posted by Martinj View Post
    Thanks for the advice! So basically you can only really consider them if you can view the vehicle in person and the business looks trustworthy.
    Quote Originally Posted by Viertrek View Post
    Awesome advice! Thanks, I'm also pro the 2.5 TDI D/C 👍 Cool to know the electric windows is not really a factor.
