Page 4 of 48 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
Results 61 to 80 of 942
Thread: Custom Tuning
  1. #61
    Strand
    Thanked: 1369
    Default Re: Custom Tuning
    Quote Originally Posted by The TRANSPORTER View Post
    Hi Benson,
    Het ook gepraat op whatsapp oor my D-teq wanneer jy in Pretoria is..
    Yes yes, jy is 100% op my lysie. Ek confirm met almal datums vlg week.
  2. #62
    Strand
    Thanked: 1369
    2008 Ford Ranger 3.0l Tdci
    Initially she came in as she didn't want to start, and tents to go into limp mode.
    start was easy, leking fuel line behind the engine, replaced and starts first time everytime.
    Limp mode was MAP sensor erros and Barromatic pressure errors, This turned out to be a leaking Boost pipe, so she got a new one.
    So she got a full Service
    new universal on her propshaft
    Radiator Coolant Flush
    Stage 1 Economy Remap
    EGR and EGR cooler blank and delete
    CAT removed and Deleted
    This puts her up to 152kW and 500Nm
Name:	Ranger 30 2008.jpg
  3. #63
    Strand
    Thanked: 1369
    Disco 4 SDV6
    Egr blanked, cat removed and Software done.
    Range rover TDV8
ID:	678818Click image for larger version.
ID:	678821Click image for larger version.
ID:	678819Click image for larger version.
  4. #64
    Strand
    Thanked: 1369
    2014 Hilux 3.0l D-4d
    Client was not worried about consumption, poweerrrrrr it is then!
    Stage 2 with CAT removal end egr blank off with all the electronic deletes!
    Not a sign of any smoke!
    Smoke maps are so 2010Attachment 678923Click image for larger version.
  5. #65
    Strand
    Thanked: 1369
    Customer States. Ford is going into limp and struggles to start.
    Diagnostic error, Map sensor and Barometric error etc etc.
    Struggling to start, funny enough when you depress the clutch... Told him to be more uplifting and depress the clutch when turning the key... Seems to have solved it.. So maybe a thrust bearing ontl the way out.
    Map sensor was easy enough...
    Removed it, well some of it..
    New one fitted and sommer cleaned a few other sensors as well...
    Happiness all round and customer on his way with a smile... Click image for larger version.
  6. #66
    Thanked: 439
    Benson, ek gee jou kridiet. Jy het duidelik passie, omgee en jy weet hoe om dit te deel. Ek sien altyd uit om te sien waarmeer jy volgende besig is en hoe jy elke keer die ekstra myl loop. Mag jy die vrugte daarvan pluk in elke aspek van jou besigheid en persoonlike lewe.
    Wanneer ek weer 'n kaap trippie beplan gaan ek jou kontak vir 'n besoek.
    2024 Mahindra MHawk S11 Dew 4x4
    2015 Jurgens Xcape (up FOR SALE)
  7. The Following User Says Thank You to 1965Landy For This Useful Post:
  8. #67
    Strand
    Thanked: 1369
    Quote Originally Posted by 1965Landy View Post
    Voel of ek elke dag in 'n speelgoed winkel is.
    Awesome om met kliŽnte te gesels oor waar hulle was en planne oor waarheen hulle gaan.
    Ek het al die ander kant van die muntstuk gesit, so probeer altyd seker maak dat wanneer 'n voertuig ons verlaat hy Cairo sal sien en dit terug maak.
    En dan die beste is die glimlag op almal se gesigte wanneer hulle tweede hak en die verskil die voertuie voel.
  9. #68
    Strand
    Thanked: 1369
    Had a Polo 1.4tdi manual in from another workshop today.
    Car was smoking badly under load.
    Step one, Cleaned out the intake. And blanked the EGR. Deleted from software. Smoking was more or less gone.
    Step two, removed the CAT, deleted from software.
    Smoke is almost non existant. I belive with a good 'service' with some aggressive throttle, it should burn out the last crap in the system.
    New EGR would have been R25k, new CAT quoted R16000.
    Customer walked out with a bill of less than R5k.
    Happiness.
  10. The Following User Says Thank You to Benson For This Useful Post:
  11. #69
    Strand
    Thanked: 1369
    Some cars just age really well.
    Had this old girl in a beautiful CLK350 convertable with just over 270kkm on behind her.
    A little rough idle, and a convertable roof that, well, is not converting to anything.
    Took her for a test drive. Rough idle and slow response... Well I have some suspension... Took the EGR valves.. Yes two of these pieces of (insert swear word here) and they were dirty as hell! And this from a Petrol.
    So a good Clean, and a software deletion later, a completely different car.
    The cats are a little more difficult to remove, so the client opted out for now.
    Now we tackle the roof. The rear headrests popped, so we manually pushed these back with a strong wire and some maneuvering...
    Okay now we have an open circuit error. This can be anything from a broken plug, loose connector, wires touching or as simple as a fuse.
    Step one was to make sure the roof operates. Manually. Easy enough, if you where to take and where to let go..
    So nothing stuck, time to go through the relays, fuses and connections.
    Some more info from the client, someone worked there and after that... I hate this but at least it gave me an idea on where to start.
    One plug was not secured. Okay one less error.
    One relay and one fuse replacement later, the roof closes and for the first time in 6 months of other people asking scrupulous amounts of money and Not fixing it, the roof works a charm!
    Happy client, and happy me. Love fault finding.....
    Ps. There is so much oomph in this car, I was not gonna waste a client's money for a stage 1 remap. The egr deletion alone will bring back enough life in her.
    https://youtu.be/cq7AYUf4eok
    Attachment 679277Click image for larger version.
ID:	679280Click image for larger version.
ID:	679279Click image for larger version.
  12. The Following 2 Users Say Thank You to Benson For This Useful Post:
  13. #70
    Oct 2017
    Vereeniging
    Thanked: 542
    Sometimes I have to wonder what the EGR systems on our fleet Haailakse must look like after 260,000 km of chugging along to work and back with a tool canopy full of heavy Gedores and very little TLC . .
    Die B staan vir Beneke
  14. #71
    Weltevredenpark, Roodepoort
    Thanked: 55
    Ek stem volkome saam jou, is mal daaroor om al Benson se kommentare oor verskillende karre te lees. En die entoesiasme wat gepaard gaan! Maar dan voel ek weer sad want ek weet my ou getroue KZ-TE (met 255,000 op die klok) het seker niks om op te gradeer nie, en 'n bietjie ekstra oemf sal darem baie lekker wees!
    Johan Westraad
    Gravel Travel Inspired!
  15. The Following User Says Thank You to Echo Man For This Useful Post:
  16. #72
    Strand
    Thanked: 1369
    Quote Originally Posted by Echo Man View Post
    Daar is altyd ietsie om mee te speel. Ek het donkie jare terug n KZ gery, is waar my liefde vir 4x4 begin het.
    Op die oukies kan mens altyd met die intercooler ( dink die grootte is 450x260x76 as ek reg onthou) en ook met Turbo speel.... Maar glo my, die intercooler op homself gaan n nhelse verskil maak.
  17. #73
    Strand
    Thanked: 1369
    Quote Originally Posted by EtienneB View Post
    n CAT en EGR het hitte nodig om skoon te brand, so die grootste issue is die mommy wagons en die kort trippies.
    As jy kyk na n DPF regeneration siklus, die voertuig rev om die exhaust gasse warm genoeg te kry (680 grade + op n Vito wat ek so ruk terug gedoen het) om die Soot skoon te brand.
    so hulle sit n item in die kar om die omgewing te beskerm, maar jy moet brandstof verbrand om die siklus te begin. meer brandstof soos ek verstaan is ook nie goed vir die omgewing nie.
    So waar trek mens die lyn. haal die strond uit, dan hou die engine langer, en jy hoef dus nie die kar vervang nie, minder van alles wat olie gebruik word dan gebruik. dit sluit tot die plastiek wat gebruik word vir die interior in. so ja, tot n Tesla het nogsteeds olie nodig om gemaak te word
  18. #74
    Apr 2014
    Thanked: 302
    Jou KZ is nog nie eers behoorlik ingeloop nie. My 2003 staan op 419 000km. Begin nou eers lekker ry.
    Quote Originally Posted by Benson View Post
    My head, wel nie myne nie, my KZ s'n het op 230K gekraak. Vervang met 'n AMC en ek het ook 'n Cirus intercooler en Dastek chip ingesit saam met 'n Madman EGT guage. "Drivability" baie beter. EGT' s ook laer.
    Ek het nou 'n ander probleem. Klink asof die linker agter wiel bearing gegaan het. Staan al vir 3 maande. Besig om moed bymekaar te skraap om dit te vervang.
  19. #75
    Strand
    Thanked: 1369
    Quote Originally Posted by LdLL View Post
    Jou KZ is nog nie eers behoorlik ingeloop nie. My 2003 staan op 419 000km. Begin nou eers lekker ry. My head, wel nie myne nie, my KZ s'n het op 230K gekraak. Vervang met 'n AMC en ek het ook 'n Cirus intercooler en Dastek chip ingesit saam met 'n Madman EGT guage. "Drivability" baie beter. EGT' s ook laer.
    O ek is so allergies vir Chips op karre dit jie eens snaaks nie.
    Het 'n puma wat in limp ingaan, met injectors wat lek en fuel rail pressure issues.
    Chip uit gehaal. All sorted.
    Limp weg, en die kar trek actually beter en is ligter op brandstof.
    Ons gaan binnekort Hybrid en intercooler met 'n lekker map doen daar.
  20. #76
    Strand
    Thanked: 1369
    Got a real looker in for some love this week.
    Defender 90 2.8.
    We worked on the following
    New bonnet release
    Coolant Top up
    Replased all the suspension bushes
    Full Service
    Fixed the blower fan
    and did a general checkup.
ID:	679398   Click image for larger version.
ID:	679399   Click image for larger version.
  21. #77
    Aug 2019
    Thanked: 1877
    Defender 90 2.8.
    New bonnet release
    Coolant Top up
    Full Service
    Best LR ever build love those
  22. #78
    Strand
    Thanked: 1369
    Yup, wanted to tell the owner it is beyond repair and I will take it off his hands....
  23. #79
    Strand
    Thanked: 1369
  24. #80
    Strand
    Thanked: 1369
    Had a Volvo S60 T3 come in as a referral from one of my clients. Engine was rebuild after cooler leaked and sent water through the intake.
    But after this a very rough idle jumping from 1200 - 500 up and down.
    The initial diagnostic report came in with a book full of faults.
    Cleared all and took for a drive, almost all them came back.
    Spent about an hour on the car resetting throttle valves, cam timing and and and.
    Got the idle to near perfect, and one really happy customer.
    Will do a cat and EGR delete for him in the near future!
    Rebuilding an engine on a new car is no possible without proper diagnostic capabilities Click image for larger version.
