Page 26 of 35 FirstFirst ... 21 22 23 24 25 26 27 28 29 30 31 ... LastLast
Results 501 to 520 of 695
Thread: Custom Tuning
  1. #501
    Oct 2006
    Thanked: 473
    Default Re: Custom Tuning
    Quote Originally Posted by Benson View Post
    Silverton had an awesome 3.0l TD Isuzu in.
    a Good Stage 2 with EGR delete.
    140kW to 185kW and 450Nm to 600Nm
    Flywheel or wheel figures?
  2. #502
    Langs die rivier, op n berg
    Thanked: 5939
    Quote Originally Posted by Racer-X View Post
    Klink soos flywheel. 185kw op wiele is 220-230kw op flywheel.
  3. The Following User Says Thank You to Reenen For This Useful Post:
  4. #503
    Hermamus
    Thanked: 1049
  5. The Following User Says Thank You to Benson For This Useful Post:
  6. #504
    Oct 2006
    Thanked: 473
    Flywheel figures.
    How do you get to those figures?
    A percentage increase from factory figures?
  7. #505
    Hermamus
    Thanked: 1049
    We develop our base maps on the dyno and with road logging.
    So we know what changes to make to the ecu to achieve certain things.
    So if you want power / economy / towing we can custom it for your purpose.
    Our stage 1 is the best of both worlds between power and economy.
  8. #506
    Oct 2006
    Thanked: 473
    Does that mean that the vehicles are not always dyno tested after being remapped?
  9. #507
    Hermamus
    Thanked: 1049
    Correct yes.
    Believe it or not, a dyno is not the be all in tuning.
    We do a throurough check on the car, diagnostics and adjusting some calibrations via the diag as well.
    We check load, boost ( actual vs requested) via road road logs.
    That said. If you want dyno figures before and after, i am more than happy to do that with the tune.
  10. The Following 2 Users Say Thank You to Benson For This Useful Post:
  11. #508
    Aug 2019
    Thanked: 1674
    Correct yes.
    Do you check AFR and EGT values while you tune ?
  12. #509
    Hermamus
    Thanked: 1049
    Depending on what it is you need. Yes.
    For a normal stage 1 I very rarely need to check these because of the parameters we work with.
    Safe and reliable is our biggest concern.
    This is a hilux I did a few weeks ago, without a dyno. Customer was super excited to see the difference that he was already feeling.
    And this is the curve the Dyno gave him.
    Perfect, if I say so myself.
    Again, even though we provide expected figures, this is not what we mainly focus on, the drivability, where the power is available and what you want to do with that power is what makes us different in the game.
    If you're just chasing numbers, we are happy to play with that, but we are more concerned about giving you what you need, and making sure that when you do go on that loooong trip, that you can drive it back as well.
    When you start asking for stage 2 + and stage 3, which is taking you vehicle completely out our safe and reliable parameters, as there will also be a lot of hardware changes, we need aditional information yes. Click image for larger version.
  13. The Following 4 Users Say Thank You to Benson For This Useful Post:
  14. #510
    Thanked: 5939
    Ek is dom met die goed.
    Hoekom is die kw kurwe platter as die torque kurwe. Ek verbeel my die kw klim met rpm tot so 4000/4300 rpm en dan drop dit
  15. #511
    Thanked: 790
    Daai het ook my oog gevang, gaan kyk toe mooi na daai dyno result.
    Dis basically net 'n 2000rpm snapshot (2000 tot 4000) en nie die hele rev range nie.
    So ons sien net die peak, nie die klim vanaf idle rpm tot verby die afval na 4000rpm nie.
  16. #512
    Hermamus
    Thanked: 1049
    Quote Originally Posted by Andre N View Post
    Daai kan ek ongelukkig nie mee help nie.
    Dit was die manne waarnatoe hy die kar gevat het.
  17. #513
    Thanked: 790
    Daar's nie issue nie, Net vir Reenen geantwoord oor hoekom die Kurwe nie soos gewoonlik vir ons lyk nie.
  18. #514
    Hermamus
    Thanked: 1049
    A very nice tune done for this 200 VX-R in Tzaneen.
    All our members in limpopo are welcome to go visit Jean-Luke at Point S. Click image for larger version.
  19. #515
    Hermamus
    Thanked: 1049
  20. #516
    Hermamus
    Thanked: 1049
    Hilux 3.0l D4-d
    Customer was complaining about reduced power and really bad fuel consumption.
    We ended up removing two uni chips from the bakkie, blanked the EGR and tmdid a nice Stage 1 eco map on it.
    Even with the eco map the bakkie pulls better and is more responsive..
    Looking forward to the fuel consumption figures.. Click image for larger version.
  21. #517
    Hermamus
    Thanked: 1049
    V8 Cruiser.
    In for an upper intake clean, egr blank and map fix...
    Ohh whee, 2nd gear sees all 4's struggling not spin on the tar. Attachment 704783Click image for larger version.
ID:	704784Click image for larger version.
ID:	704786Click image for larger version.
  22. #518
    Hermamus
    Thanked: 1049
    An awesome lookin 2.2 Puma at Silverton in for a stage 1 with egr delete.
    Gentleman had his Isuzu mapped earlier this week..... Click image for larger version.
ID:	704787Click image for larger version.
  23. #519
    Hermamus
    Thanked: 1049
    I think I have found the one that beat me.
    So we have a done a few Ranger's, mapping and EGR blank / cooler delete.
    And yes it is a difficult and time consuming job, but you can get to everything if you bent like a contortionist...
    Booked in this beautiful Everest Yesterday. Now I know their ECU tends to fall asleep unless you keep the charge right up there. So hooked up everything and got a read before we started tackling the hardware.
    OMW there is just no space to work in there, the firewall is right up to the engine.
    You can get to only half the bolts on either side of the engine bay to do anything. Unless you start stripping intakes and alternators.
    The owner was very worried, but patient and fairly understanding, which helped a whole lot. So after a chat we decided to do the software and CAT hardware delete only.
    For future reference, on the Everest's, looks like it's engine out to work on the EGR... Even the manual says so
  24. #520
    Hermamus
    Thanked: 1049
    3.0l d4d done in Vereeniging.
    Amazing what a nice tune does for these engines.
    More responsive through the gear, the torque is just at the spots low down and cruising on the highway.
