Results 1 to 12 of 12
    Swakopmund
    Thanked: 22
    Default BFG KO2 265/70R17 - Handling on Amarok
    Hey everyone,
    I am running these tires now on my 2015 4 motion D/C. Since moving form my previous tires (Triangle AT 265/65) I have found overtaking another car at speeds over 120 feels dodgy at best.
    Only the front tires are new the back ones have about 30k left on them according to the tire guy. My pressure is 2b all around and I have a Beekman canopy with no other extras.
    Hopeful someone can give me some advice or if they experienced similar handling issues at highway speeds.
    Dec 2014
    Thanked: 1476
    Default Re: BFG KO2 265/70R17 - Handling on Amarok
    Quote Originally Posted by Spatanky View Post
    Hey everyone,
    You will have to be more specific here. What handling issues are you referring to?
    2012 Jeep Wrangler JKUR -- Sold (I'll be back )
    2015 Jeep Grand Cherokee Overland 5.7 Hemi
    Oct 2012
    otjiwarongo
    Thanked: 1104
    Hey everyone,
    I.wont buy a 3 ply tire again unless u do hard work and heavy loads. Mine is at 2.5 and that is per agent they dont like low pressure.
    2024 VW Amarok V6 Tdi
    2019 Bushlapa Miskruier 1616
    2012 Toyota FJ Cruiser
    2013 Toyota FJ Cruiser (Sold)
    2017 VW Amarok V6 (Sold)
    2023 VW Tiguan R-Line (Sold)
  4. The Following 3 Users Say Thank You to hein100 For This Useful Post:
    Swakopmund
    Thanked: 22
    Quote Originally Posted by Alwyn777 View Post
    Like feel unstable/jumpy when changing lane to overtake, driving below 100 feels fine and comfortable.
    Swakopmund
    Thanked: 22
    Quote Originally Posted by hein100 View Post
    Thanks I will try 2.5 and see if it changes the behavior.
    Feb 2020
    Melkbosstrand
    Thanked: 809
    I have KO2's, different size, but they seem happiest at 2.3 front and 2.5 rear or thereabouts on tar for my vehicle.
    With 2.5 front things start to get a bit skittish in the wet on tar.
    Previous owner (for 18 years and who fitted the tyres the vehicle came with when I bought it in 2020) numbers were:
    tar: 2.3 front / 2.5 rear
    gravel: 2 front / 2.2 rear
    Sand: 1.8 front / 2 rear
    Dune: 1.2 front / 1.4 rear
    Different vehicle of course, so weight distribution on yours will be different, so you will have to experiment a bit.
    1995 Defender 110 300tdi
    Shortly taking wing..
  8. The Following 2 Users Say Thank You to CraigWatt For This Useful Post:
    Pretoria/Langebaan
    Thanked: 348
    I have 265/65R18 BF KO2s on my V6. I run them at 2.2, no issues.
  10. The Following 3 Users Say Thank You to Makaira For This Useful Post:
  11. #8
    Swakopmund
    Thanked: 22
    Quote Originally Posted by CraigWatt View Post
    Thanks for the reply, I am definitely going to start experimenting. General consensus on Google is 2.2-2.7 (32 - 39 psi) depending on use. Definitely a bit of a learning curve as these tires are quite beefy and its the first time I've had an AT thats more than 2 ply. They are load rated E which google search mentions equivalence to 10ply I should have done a bit more homework before getting them but got a really good deal on 4 used ones (so bought 2 new ones so I have the spare and not uneven when fitting only 1 new tire).
  12. The Following User Says Thank You to Spatanky For This Useful Post:
  13. #9
    Tshwanetoria
    Thanked: 4495
    Did 75k on mine, always at 2bar no-load and 3bar when fully laden.
    Initially had them on 2.2/2.5 but Amarok was jumpy, then Seikel told me to stick to VW specs.
    The sidewalls are rather stiff, so lower pressure will work better, I think.
    The story about damage at low pressures only apply to very low pressures (1.5 ish?) and high speed, I would say.
  14. #10
    Jul 2007
    Thanked: 423
    In the past I found the BFG’s to excellent for heavy duty off road. For me they weren’t great for on road use as far as handling , noise an fuel consumption is concerned… they do look fantastic though…
    VW Amarok V6 DC 4Motion
    (Ex) 2011 VW Amarok BiTDI DC 4Motion
    (Ex) 2007 Mitsubishi Triton 2.5 DID DC 4x4
    (Ex) 2001 Mitsubishi Colt 2.8 TDI DC 4x4
  15. #11
    Henties
    Thanked: 2569
    That 10 ply rating doesn't refer to the side wall plies, but to the plies underneath the tread. 2 different things. The ply rating isn't an indication of the actual amount of plies in the tyre, but it compares the strength / load carrying ability of the tire to the amount of cotton plies used in earlier tyres. In your case, the tyre's load carrying ability is comparable to one with 10 cotton plies.
    2007 Volvo S60
    2012 FJ Cruiser
    1983 FJ60 Landcruiser -sold-
  16. The Following User Says Thank You to HugoNotte For This Useful Post:
  17. #12
    Swakopmund
    Thanked: 22
    Appreciate all the replies. I did a trip of around 1500km mixed gravel and tar. The pressure between 2.2 and 2.6. The tires performed way beyond my expectation. I found that 2.2 is very good all round.
