Grand Cherokee Error code
Results 1 to 5 of 5
Thread: Error code
    Bergville
    Default Error code
    Can anyone help? Error code P1130 on a WJ2002. What does it mean?
    On the edge...
    Here you go:
    P1130 - fuel rail pressure monitoring
    On the edge...
    OVERKILL:
    P0100 Mass or Volume Air Flow Circuit Malfunction
    P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
    P0101 Mass or Volume Air Flow Circuit Low Input
    P0103 Mass or Volume Air Flow Circuit High Input
    P0104 Mass or Volume Air Flow Circuit Intermittent
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
    P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
    P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
    P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
    P0110 Intake Air Temperature Circuit Malfunction
    P0111 Intake Air Temperature Circuit Range/Performance Problem
    P0112 Intake Air Temperature Circuit Low Input
    P0113 Intake Air Temperature Circuit High Input
    P0114 Intake Air Temperature Circuit Intermittent
    P0115 Engine Coolant Temperature Circuit Malfunction
    P0116 Engine Coolant Temperature Circuit Range/Performance Problem
    P0117 Engine Coolant Temperature Circuit Low Input
    P0118 Engine Coolant Temperature Circuit High Input
    P0119 Engine Coolant Temperature Circuit Intermittent
    P0120 Throttle/Pedal Position Sensor/Switch A Circuit Malfunction
    P0120 ETS Main Throttle Position Sensor Malfunction
    P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
    P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
    P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
    P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
    P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
    P0126 Insufficient Coolant Temperature for Stable Operation
    P0128 Range/Performance Problem In Thermostat
    P0128 ECT Below Thermostat Regulating Temperature
    P0130 Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 1
    P0131 Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    P0132 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 1)
    P0133 Oxygen Sensor Circuit Slow Response (Bank 1 Sensor 1)
    P0134 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
    P0135 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    P0136 Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 2)
    P0137 Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 2)
    P0138 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 2)
    P0139 Oxygen Sensor Circuit Slow Response (Bank 1 Sensor 2)
    P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
    P0141 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
    P0142 Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 3)
    P0143 Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 3)
    P0144 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 3)
    P0145 Oxygen Sensor Circuit Slow Response (Bank 1 Sensor 3)
    P0146 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
    P0147 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
    P0150 Oxygen Sensor Circuit Malfunction (Bank 2 Sensor 1)
    P0151 Oxygen Sensor Circuit Low Voltage (Bank 2 Sensor 1)
    P0152 Oxygen Sensor Circuit High Voltage (Bank 2 Sensor 1)
    P0153 Oxygen Sensor Circuit Slow Response (Bank 2 Sensor 1)
    P0154 Oxygen Sensor Circuit No Activity Detected (Bank 2 Sensor 1
    P0155 Oxygen Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    P0156 Oxygen Sensor Circuit Malfunction (Bank 2 Sensor 2)
    P0157 Oxygen Sensor Circuit Low Voltage (Bank 2 Sensor 2)
    P0158 Oxygen Sensor Circuit High Voltage (Bank 2 Sensor 2)
    P0159 Oxygen Sensor Circuit Slow Response (Bank 2 Sensor 2)
    P0160 Oxygen Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
    P0161 Oxygen Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
    P0162 Oxygen Sensor Circuit Malfunction (Bank 2 Sensor 3)
    P0163 Oxygen Sensor Circuit Low Voltage (Bank 2 Sensor 3)
    P0164 Oxygen Sensor Circuit High Voltage (Bank 2 Sensor 3)
    P0165 Oxygen Sensor Circuit Slow Response (Bank 2 Sensor 3)
    P0166 Oxygen Sensor Circuit No Activity Detected (Bank 2 Sensor 3
    P0167 Oxygen Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
    P0170 Fuel Trim Malfunction (Bank 1)
    P0171 System too Lean (Bank 1)
    P0172 System too Rich (Bank 1)
    P0173 Fuel Trim Malfunction (Bank 2)
    P0174 System too Lean (Bank 2)
    P0175 System too Rich (Bank 2)
    P0176 Fuel Composition Sensor Circuit Malfunction
    P0177 Fuel Composition Sensor Circuit Range/Performance
    P0178 Fuel Composition Sensor Circuit Low Input
    P0179 Fuel Composition Sensor Circuit High Input
    P0180 Fuel Temperature Sensor A Circuit Malfunction
    P0181 Fuel Temperature Sensor A Circuit Range/Performance
    P0182 Fuel Temperature Sensor A Circuit Low Input
    P0183 Fuel Temperature Sensor A Circuit High Input
    P0184 Fuel Temperature Sensor A Circuit Intermittent
    P0185 Fuel Temperature Sensor B Circuit Malfunction
    P0186 Fuel Temperature Sensor B Circuit Range/Performance
    P0187 Fuel Temperature Sensor B Circuit Low Input
    P0188 Fuel Temperature Sensor B Circuit High Input
    P0189 Fuel Temperature Sensor B Circuit Intermittent
    P0190 Fuel Rail Pressure Sensor Circuit Malfunction
    P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
    P0192 Fuel Rail Pressure Sensor Circuit Low Input
    P0193 Fuel Rail Pressure Sensor Circuit High Input
    P0194 Fuel Rail Pressure Sensor Circuit Intermittent
    P0195 Engine Oil Temperature Sensor Malfunction
    P0196 Engine Oil Temperature Sensor Range/Performance
    P0197 Engine Oil Temperature Sensor Low
    P0198 Engine Oil Temperature Sensor High
    P0199 Engine Oil Temperature Sensor Intermittent
    P0200 Injector Circuit Malfunction
    P0201 Injector Circuit Malfunction - Cylinder 1
    P0202 Injector Circuit Malfunction - Cylinder 2
    P0203 Injector Circuit Malfunction - Cylinder 3
    P0204 Injector Circuit Malfunction - Cylinder 4
    P0205 Injector Circuit Malfunction - Cylinder 5
    P0206 Injector Circuit Malfunction - Cylinder 6
    P0207 Injector Circuit Malfunction - Cylinder 7
    P0208 Injector Circuit Malfunction - Cylinder 8
    P0209 Injector Circuit Malfunction - Cylinder 9
    P0210 Injector Circuit Malfunction - Cylinder 10
    P0211 Injector Circuit Malfunction - Cylinder 11
    P0212 Injector Circuit Malfunction - Cylinder 12
    P0213 Cold Start Injector 1 Malfunction
    P0214 Cold Start Injector 2 Malfunction
    P0215 Engine Shutoff Solenoid Malfunction
    P0216 Injection Timing Control Circuit Malfunction
    P0217 Engine Overtemp Condition
    P0218 Transmission Over Temperature Condition
    P0219 Engine Overspeed Condition
    P0220 Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
    P0220 ETS Throttle Position Sensor Property Malfunction
    P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem
    P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low Input
    P0223Throttle/Pedal Position Sensor/Switch B Circuit High Input
    P0224 Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
    P0225 Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
    P0226Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem
    P0227 Throttle/Pedal Position Sensor/Switch C Circuit Low Input
    P0228 Throttle/Pedal Position Sensor/Switch C Circuit High Input
    P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
    P0230 Fuel Pump Primary Circuit Malfunction
    P0231 Fuel Pump Secondary Circuit Low
    P0232 Fuel Pump Secondary Circuit High
    P0233 Fuel Pump Secondary Circuit Intermittent
    P0234 Engine Overboost Condition
    P0235 Turbocharger Boost Sensor A Circuit Malfunction
    P0236 Turbocharger Boost Sensor A Circuit Range/Performance
    P0237 Turbocharger Boost Sensor A Circuit Low
    P0238 Turbocharger Boost Sensor A Circuit High
    P0239 Turbocharger Boost Sensor B Malfunction
    P0240 Turbocharger Boost Sensor B Circuit Range/Performance
    P0241 Turbocharger Boost Sensor B Circuit Low
    P0242 Turbocharger Boost Sensor B Circuit High
    P0243 Turbocharger Wastegate Solenoid A Malfunction
    P0244 Turbocharger Wastegate Solenoid A Range/Performance
    P0245 Turbocharger Wastegate Solenoid A Low
    P0246 Turbocharger Wastegate Solenoid A High
    P0247 Turbocharger Wastegate Solenoid B Malfunction
    P0248 Turbocharger Wastegate Solenoid B Range/Performance
    P0249 Turbocharger Wastegate Solenoid B Low
    P0250 Turbocharger Wastegate Solenoid B High
    P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
    P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
    P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
    P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
    P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
    P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
    P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
    P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
    P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
    P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
    P0261 Cylinder 1 Injector Circuit Low
    P0262 Cylinder 1 Injector Circuit High
    P0263 Cylinder 1 Contribution/Balance Fault
    P0264 Cylinder 2 Injector Circuit Low
    P0265 Cylinder 2 Injector Circuit High
    P0266 Cylinder 2 Contribution/Balance Fault
    P0267 Cylinder 3 Injector Circuit Low
    P0268 Cylinder 3 Injector Circuit High
    P0269 Cylinder 3 Contribution/Balance Fault
    P0270 Cylinder 4 Injector Circuit Low
    P0271 Cylinder 4 Injector Circuit High
    P0272 Cylinder 4 Contribution/Balance Fault
    P0273 Cylinder 5 Injector Circuit Low
    P0274 Cylinder 5 Injector Circuit High
    P0275 Cylinder 5 Contribution/Balance Fault
    P0276 Cylinder 6 Injector Circuit Low
    P0277 Cylinder 6 Injector Circuit High
    P0278 Cylinder 6 Contribution/Balance Fault
    P0279 Cylinder 7 Injector Circuit Low
    P0280 Cylinder 7 Injector Circuit High
    P0281 Cylinder 7 Contribution/Balance Fault
    P0282 Cylinder 8 Injector Circuit Low
    P0283 Cylinder 8 Injector Circuit High
    P0284 Cylinder 8 Contribution/Balance Fault
    P0285 Cylinder 9 Injector Circuit Low
    P0286 Cylinder 9 Injector Circuit High
    P0287 Cylinder 9 Contribution/Balance Fault
    P0288 Cylinder 10 Injector Circuit Low
    P0289 Cylinder 10 Injector Circuit High
    P0290 Cylinder 10 Contribution/Balance Fault
    P0291 Cylinder 11 Injector Circuit Low
    P0292 Cylinder 11 Injector Circuit High
    P0293 Cylinder 11 Contribution/Balance Fault
    P0294 Cylinder 12 Injector Circuit Low
    P0295 Cylinder 12 Injector Circuit High
    P0296 Cylinder 12 Contribution/Range Fault
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Cylinder 1 Misfire Detected
    P0302 Cylinder 2 Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0304 Cylinder 4 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    P0306 Cylinder 6 Misfire Detected
    P0307 Cylinder 7 Misfire Detected
    P0308 Cylinder 8 Misfire Detected
    P0309 Cylinder 9 Misfire Detected
    P0310 Cylinder 10 Misfire Detected
    P0311 Cylinder 11 Misfire Detected
    P0312 Cylinder 12 Misfire Detected
    P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
    P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
    P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
    P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
    P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
    P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
    P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
    P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
    P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
    P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
    P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
    P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
    P0333 Knock Sensor 2 Circuit High Input (Bank 2)
    P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
    P0335 Crankshaft Position Sensor A Circuit Malfunction
    P0336 Crankshaft Position Sensor A Circuit Range/Performance
    P0337 Crankshaft Position Sensor A Circuit Low Input
    P0338 Crankshaft Position Sensor A Circuit High Input
    P0340 Camshaft Position Sensor Circuit Malfunction
    P0341 Camshaft Position Sensor Circuit Range/Performance
    P0342 Camshaft Position Sensor Circuit Low Input
    P0343 Camshaft Position Sensor Circuit High Input
    P0344 Camshaft Position Sensor Circuit Intermittent
    P0350 Ignition Coil Primary/Secondary Circuit Malfunction
    P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
    P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
    P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
    P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
    P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
    P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
    P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
    P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
    P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
    P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
    P0370 Timing Reference High Resolution Signal A Malfunction
    P0371 Timing Reference High Resolution Signal A Too Many Pulses
    P0372 Timing Reference High Resolution Signal A Too Few Pulses
    P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
    P0374 Timing Reference High Resolution Signal A No Pulses
    P0375 Timing Reference High Resolution Signal B Malfunction
    P0376 Timing Reference High Resolution Signal B Too Many Pulses
    P0377 Timing Reference High Resolution Signal B Too Few Pulses
    P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
    P0379 Timing Reference High Resolution Signal B No Pulses
    P0380 Glow Plug/Heater Circuit "A" Malfunction
    P0381 Glow Plug/Heater Indicator Circuit Malfunction
    P0382 Glow Plug/Heater Circuit "B" Malfunction
    P0385 Crankshaft Position Sensor B Circuit Malfunction
    P0386 Crankshaft Position Sensor B Circuit Range/Performance
    P0387 Crankshaft Position Sensor B Circuit Low Input
    P0388 Crankshaft Position Sensor B Circuit High Input
    P0389 Crankshaft Position Sensor B Circuit Intermittent
    P0400 Exhaust Gas Recirculation Flow Malfunction
    P0401 Exhaust Gas Recirculation Flow Insufficient Detected
    P0402 Exhaust Gas Recirculation Flow Excessive Detected
    P0403 Exhaust Gas Recirculation Circuit Malfunction
    P0404 Exhaust Gas Recirculation Circuit Range/Performance
    P0405 Exhaust Gas Recirculation Sensor A Circuit Low
    P0406 Exhaust Gas Recirculation Sensor A Circuit High
    P0407 Exhaust Gas Recirculation Sensor B Circuit Low
    P0408 Exhaust Gas Recirculation Sensor B Circuit High
    P0410 Secondary Air Injection System Malfunction
    P0411 Secondary Air Injection System Incorrect Flow Detected
    P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
    P0413 Secondary Air Injection System Switching Valve A Circuit Open
    P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
    P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
    P0416 Secondary Air Injection System Switching Valve B Circuit Open
    P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
    P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
    P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
    P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
    P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
    P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
    P0430 Catalyst System Efficiency Below Threshold (Bank 2)
    P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
    P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
    P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
    P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
    P0440 Evaporative Emission Control System Malfunction
    P0441 Evaporative Emission Control System Incorrect Purge Flow
    P0442 Evaporative Emission Control System Leak Detected (small leak)
    P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
    P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
    P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
    P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
    P0447 Evaporative Emission Control System Vent Control Circuit Open
    P0448 Evaporative Emission Control System Vent Control Circuit Shorted
    P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
    P0450 Evaporative Emission Control System Pressure Sensor Malfunction
    P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
    P0452 Evaporative Emission Control System Pressure Sensor Low Input
    P0453 Evaporative Emission Control System Pressure Sensor High Input
    P0454 Evaporative Emission Control System Pressure Sensor Intermittent
    P0455 Evaporative Emission Control System Leak Detected (gross leak)
    P0456 EVAP Leak Monitor Small Leak Detected
    P0460 Fuel Level Sensor Circuit Malfunction
    P0461 Fuel Level Sensor Circuit Range/Performance
    P0462 Fuel Level Sensor Circuit Low Input
    P0463 Fuel Level Sensor Circuit High Input
    P0464 Fuel Level Sensor Circuit Intermittent
    P0465 Purge Flow Sensor Circuit Malfunction
    P0466 Purge Flow Sensor Circuit Range/Performance
    P0467 Purge Flow Sensor Circuit Low Input
    P0468 Purge Flow Sensor Circuit High Input
    P0469 Purge Flow Sensor Circuit Intermittent
    P0470 Exhaust Pressure Sensor Malfunction
    P0471 Exhaust Pressure Sensor Range/Performance
    P0472 Exhaust Pressure Sensor Low
    P0473 Exhaust Pressure Sensor High
    P0474 Exhaust Pressure Sensor Intermittent
    P0475 Exhaust Pressure Control Valve Malfunction
    P0476 Exhaust Pressure Control Valve Range/Performance
    P0477 Exhaust Pressure Control Valve Low
    P0478 Exhaust Pressure Control Valve High
    P0479 Exhaust Pressure Control Valve Intermittent
    P0480 Cooling Fan 1 Control Circuit Malfunction
    P0481 Cooling Fan 2 Control Circuit Malfunction
    P0482 Cooling Fan 3 Control Circuit Malfunction
    P0483 Cooling Fan Rationality Check Malfunction
    P0484 Cooling Fan Circuit Over Current
    P0485 Cooling Fan Power/Ground Circuit Malfunction
    P0500 Vehicle Speed Sensor Malfunction
    P0501 Vehicle Speed Sensor Range/Performance
    P0502 Vehicle Speed Sensor Low Input
    P0503 Vehicle Speed Sensor Intermittent/Erratic/Higg
    P0505 Idle Control System Malfunction
    P0506 Idle Control System RPM Lower Than Expected
    P0507 Idle Control System RPM Higher Than Expected
    P0510 Closed Throttle Position Switch Malfunction
    P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
    P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
    P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
    P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
    P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
    P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
    P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
    P0533 A/C Refrigerant Pressure Sensor Circuit High Input
    P0534 Air Conditioner Refrigerant Charge Loss
    P0550 Power Steering Pressure Sensor Circuit Malfunction
    P0551 Power Steering Pressure Sensor Circuit Range/Performance
    P0552 Power Steering Pressure Sensor Circuit Low Input
    P0553 Power Steering Pressure Sensor Circuit High Input
    P0554 Power Steering Pressure Sensor Circuit Intermittent
    P0560 System Voltage Malfunction
    P0561 System Voltage Unstable
    P0562 System Voltage Low
    P0563 System Voltage High
    P0565 CRUISE CONTROL ON SIGNAL MALFUNCTION
    P0566 Cruise Control Off Signal Malfunction
    P0567 Cruise Control Resume Signal Malfunction
    P0568 Cruise Control Set Signal Malfunction
    P0569 Cruise Control Coast Signal Malfunction
    P0570 Cruise Control Accel Signal Malfunction
    P0571 Cruise Control/Brake Switch A Circuit Malfunction
    P0572 Cruise Control/Brake Switch A Circuit Low
    P0573 Cruise Control/Brake Switch A Circuit High
    P0574 Cruise Control Related Malfunction
    P0575 Cruise Control Related Malfunction
    P0576 Cruise Control Related Malfunction
    P0577 Cruise Control Related Malfunction
    P0578 Cruise Control Related Malfunction
    P0579 Cruise Control Related Malfunction
    P0580 Cruise Control Related Malfunction
    P0600 Communication Link Malfunction
    P0601 Internal Control Module Memory Check Sum Error
    P0602 Control Module Programming Error
    P0603 Internal Control Module Keep Alive Memory (KAM) Error
    P0604 Internal Control Module Random Access Memory (RAM) Error
    P0605 Internal Control Module Read Only Memory ROM) Error
    P0606 PCM Processor Fault
    P0609 Control Module VSS Output "B" Malfunction
    P0620 Generator Control Circuit Malfunction
    P0621 Generator Lamp "L" Control Circuit Malfunction
    P0622 Generator Field "F" Control Circuit Malfunction
    P0645 A/C Clutch Relay Circuit
    P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
    P0654 Engine RPM Output Circuit Malfunction
    P0655 Engine Hot Lamp Output Control Circuit Malfunction
    P0656 Fuel Level Output Circuit Malfunction
    P0700 Transmission Control System Malfunction
    P0701 Transmission Control System Range/Performance
    P0702 Transmission Control System Electrical
    P0703 Torque Converter/Brake Switch B Circuit Malfunction
    P0704 Clutch Switch Input Circuit Malfunction
    P0705 Transmission Range Sensor Circuit malfunction(PRNDL Input)
    P0706 Transmission Range Sensor Circuit Range/Performance
    P0707 Transmission Range Sensor Circuit Low Input
    P0708 Transmission Range Sensor Circuit High Input
    P0709 Transmission Range Sensor Circuit Intermittent
    P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
    P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712 Transmission Fluid Temperature Sensor Circuit Low Input
    P0713 Transmission Fluid Temperature Sensor Circuit High Input
    P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
    P0715 Input/Turbine Speed Sensor Circuit Malfunction
    P0716 Input/Turbine Speed Sensor Circuit Range/Performance
    P0717 Input/Turbine Speed Sensor Circuit No Signal
    P0718 Input/Turbine Speed Sensor Circuit Intermittent
    P0719 Torque Converter/Brake Switch B Circuit Low
    P0720 Output Speed Sensor Circuit Malfunction
    P0721 Output Speed Sensor Range/Performance
    P0722 Output Speed Sensor No Signal
    P0723 Output Speed Sensor Intermittent
    P0724 Torque Converter/Brake Switch B Circuit High
    P0725 Engine Speed input Circuit Malfunction
    P0726 Engine Speed Input Circuit Range/Performance
    P0727 Engine Speed Input Circuit No Signal
    P0728 Engine Speed Input Circuit Intermittent
    P0730 Incorrect Gear Ratio
    P0731 Gear 1 Incorrect ratio
    P0732 Gear 2 Incorrect ratio
    P0733 Gear 3 Incorrect ratio
    P0734 Gear 4 Incorrect ratio
    P0735 Gear 5 Incorrect ratio
    P0736 Reverse incorrect gear ratio
    P0740 Torque Converter Clutch Circuit Malfuction
    P0741 Torque Converter Clutch Circuit Performance or Stuck Off
    P0742 Torque Converter Clutch Circuit Stuck On
    P0743 Torque Converter Clutch Circuit Electrical
    P0744 Torque Converter Clutch Circuit Intermittent
    P0745 Pressure Control Solenoid Malfunction
    P0746 Pressure Control Solenoid Performance or Stuck Off
    P0747 Pressure Control Solenoid Stuck On
    P0748 Pressure Control Solenoid Electrical
    P0749 Pressure Control Solenoid Intermittent
    P0750 Shift Solenoid A Malfunction
    P0751 Shift Solenoid A Performance or Stuck Off
    P0752 Shift Solenoid A Stuck On
    P0753 Shift Solenoid A Electrical
    P0754 Shift Solenoid A Intermittent
    P0755 Shift Solenoid B Malfunction
    P0756 Shift Solenoid B Performance or Stuck Off
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical
    P0759 Shift Solenoid B Intermittent
    P0760 Shift Solenoid C Malfunction
    P0761 Shift Solenoid C Performance or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Intermittent
    P0765 Shift Solenoid D Malfunction
    P0766 Shift Solenoid D Performance or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Intermittent
    P0770 Shift Solenoid E Malfunction
    P0771 Shift Solenoid E Performance or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Intermittent
    P0780 Shift Malfunction
    P0781 1-2 Shift Malfunction
    P0782 2-3 Shift Malfunction
    P0783 3-4 Shift Malfunction
    P0784 4-5 Shift Malfunction
    P0785 Shift/Timing Solenoid Malfunction
    P0786 Shift/Timing Solenoid Range/Performance
    P0787 Shift/Timing Solenoid Low
    P0788 Shift/Timing Solenoid High
    P0789 Shift/Timing Solenoid Intermittent
    P0790 Normal/Performance Switch Circuit Malfunction
    P0801 Reverse Inhibit Control Circuit Malfunction
    P0803 1-4 Up shift (Skip Shift) Solenoid Control Circuit Malfunction
    P0804 1-4 Up shift (Skip Shift) Lamp Control Circuit Malfunction
    P0812 Reverse Switch Input Malfunction
    P1000 Monitor Testing Not Complete
    P1001 KOER Not Able To Complete KOER Aborted (key on engine running)
    P1100 MAF Intermittent
    P1100 Manifold Absolute Pressure (MAP) Sensor Malfunction (Open/Short)
    P1101 MAF Out Of Range
    P1102 Manifold Absolute Pressure (MAP) Sensor Malfunction - Low Voltage
    P1103 Manifold Absolute Pressure (MAP) Sensor Malfunction - High Voltage
    P1105 MAP/BARO Switch Solenoid Valve
    P1106 Manifold Absolute Pressure (MAP) sensor circuit intermittent high voltage
    P1106 Barometric pressure circuit problem
    P1107 Manifold Absolute Pressure (MAP) sensor circuit intermittent low voltage
    P1107 Barometric pressure circuit low inputP1108 BARO to MAP signal circuit comparison too high
    P1108 Barometric pressure circuit high input
    P1110 Atmospheric Pressure Sensor Low Input
    P1111 Intake Air Temperature (IAT) sensor intermittent high voltage
    P1112 Engine Coolant Temperature Radiator Outlet Sensor High Input
    P1114 Engine Coolant Temperature (ECT) sensor circuit intermittent low voltage
    P1115 Engine Coolant Temperature (ECT) sensor circuit intermittent high voltage
    P1116 Mass Or Volume Air Flow Circuit Range/Performance Problem (Bank 2)
    P1117 Mass Or Volume Air Flow Circuit Low Input (Bank 2)
    P1118 Mass Or Volume Air Flow Circuit High Input (Bank 2)
    P1120 TPS Out Of Range Low
    P1121 Throttle Position (TP) Sensor Inconsistent With MAF Sensor High Voltage
    P1122 Throttle Position (TP) Sensor Inconsistent With MAF Sensor Low Voltage
    P1123 Pedal Position 1 High Input
    P1124 TPS Out Of Self Test Range
    P1125 TPS Intermittent
    P1126 Thermostat Function
    P1127 Exhaust Not Warm Enough, Downstream Sensor Not Tested
    P1128 MAP Lower Than Expected
    P1129 MAP Higher Than Expected
    P1130 Lack Of HO2S-11, Fuel Trim At Limit
    P1131 HO2S 11 Indicates Lean
    P1132 O2 Sensor Heater Control Circuit (Bank 1 Sensor 1)
    P1133 Heated Oxygen Sensor (HO2S) insufficient switching bank 1 sensor 1(Rear Bank)
    P1134 Heated Oxygen Sensor (HO2S) transition time ratio bank 1 sensor 1 (Rear Bank)
    P1135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1)
    P1136 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1)
    P1137 O2 Sensor Heater Circuit Signal Intermittent (Bank 1 Sensor 2)
    P1138 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2)
    P1139 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2)
    P1140 Mass or Volume Air Flow Circuit Range/Performance Problem
    P1142 TPS Circuit Range/Perf. Problem (Low Input)
    P1144 Mass Air Flow Sensor Open/Short To Ground
    P1145 Solenoid Valve Running Losses Control Circuit Electrical
    P1146 Pressure Sensor Circuit Range/Perf (High Input)
    P1147 ETS Sub Accel Position Sensor 1 Malfunction
    P1148 Closed Loop Control (Bank 1)
    P1150 Lack Of HO2S-21 Switch Fuel Trim At Limit
    P1151 O2 Sensor Heater Circuit Signal Intermittent (Bank 2 Sensor 1)
    P1152 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1)
    P1153 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 1)
    P1154 Heated Oxygen Sensor (HO2S) transition time ratio bank 2 sensor 1(Front Bank)
    P1155 O2 Sensor Heater Circuit Intermittent (Bank 2 Sensor 2)
    P1156 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 2)
    P1157 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 2)
    P1158 Fuel Trim Inactive Bank 1 Low
    P1159 Fuel Trim Inactive Bank 1 High
    P1160 Fuel Trim Inactive Bank 2 Low
    P1161 Fuel Trim Inactive Bank 2 High
    P1162 Fuel Trim Inactive Per Ignition Bank 1 Low
    P1163 Fuel Trim Inactive Per Ignition Bank 1 High
    P1164 Fuel Trim Inactive Per Ignition Bank 2 Low
    P1165 Fuel Trim Inactive Per Ignition Bank 2 High
    P1168 FRP Sensor In Range But Low
    P1169 FRP Sensor In Range But High
    P1171 Electronic Throttle System Open
    P1172 Electronic Throttle System Motor Current
    P1173 Electronic Throttle System Rationality Malfunction
    P1174 Fuel Trim Adaptation Inactive Bank 1 Malfunction
    P1175 Fuel Trim Adaptation Inactive Bank 2 Malfunction
    P1176 O2 Sensor Slow Response Bank 1
    P1177 O2 Sensor Slow Response Bank 2
    P1178 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 1 Sensor 1)
    P1179 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 1)
    P1180 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 1 Sensor 2)
    P1181 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 2)
    P1182 O2 Sensor (Bank 1 Sensor 2) Open Circuit During Coast Down Fuel Cut-off
    P1183 EOT Sensor Circuit Malfunction
    P1184 EOT Sensor Out Of Range
    P1186 O2 Sensor Heater Control Circuit (Bank 1 Sensor 2)
    P1187 O2 Sensor Heater Control Circuit (Bank 2 Sensor 2)
    P1188 Fuel Control (Bank 1 Sensor 1)
    P1189 Fuel Control (Bank 2 Sensor 1)
    P1190 Pre-catalyst Fuel Trim System Bank 1
    P1191 Pre-catalyst Fuel Trim System Bank 2
    P1192 Post-catalyst Fuel Trim System Bank 1
    P1193 Post-catalyst Fuel Trim System Bank 2
    P1195 1/1 O2 Sensor Slow During Catalyst Monitor
    P1196 2/1 O2 Sensor Slow During Catalyst Monitor
    P1197 1/2 O2 Sensor Slow During Catalyst Monitor
    P1198 Radiator Temperature Sensor Volts Too High
    P1199 Radiator Temperature Sensor Volts Too Low
    P1229 Supercharger Intercooler Pump Not Working
    P1232 Low Speed Fuel Pump Primary Circuit Malfunction
    P1233 Fuel System Disabled Or Offline
    P1234 Fuel System Disabled Or Offline
    P1235 Fuel Pump Control Out Of Range
    P1236 Fuel Pump Control Out Of Range
    P1237 Fuel Pump Secondary Circuit Malfunction
    P1238 Fuel Pump Secondary Circuit Malfunction
    P1244 Generator Load Low
    P1245 Generator Load Input High
    P1246 Generator Load Input Failed
    P1258 Engine Metal Over Temperature Protection
    P1259 VTEC System Malfunction
    P1260 Fuel Pump Speed Relay Control Circuit
    P1260 Theft Detected - Engine Disabled
    P1270 Vehicle Speed Limiter Reached
    P1281 Engine Is Cold Too Long
    P1282 Fuel Pump Relay Control Circuit
    P1285 Cylinder Head Over Temperature Sensed
    P1288 Intake Manifold Short Runner Solenoid Circuit
    P1290 CHT Sensor Out Of Range (Ford)
    P1289 Manifold Tune Valve Solenoid Circuit
    P1289 CHT Sensor High Input
    P1290 CNG Fuel Pressure Too High
    P1290 CHT Sensor Low Input
    P1291 No Temp Rise Seen From Fuel Heaters
    P1292 CNG Pressure Sensor Voltage Too High
    P1293 CNG Pressure Sensor Voltage Too Low
    P1294 Target Idle Not Reached
    P1295 No 5 Volts To TP Sensor
    P1296 No 5 Volts To MAP Sensor
    P1297 No Change in MAB From Start To Run
    P1297 Low Voltage ELD Circuit
    P1298 High Voltage In ELD Circuit
    P1298 Lean Operation At wide Open Throttle
    P1299 Vacuum Leak Found (IAC Fully Seated)
    P1299 Cylinder Head Over Temperature Protection Active Random Misfire
    P1309 Misfire Monitor Disabled
    P1320 Ignition Control (IC) Module 4x Reference Circuit Intermittent No Pulses
    P1323 Ignition Control (IC) Module 24x Reference Circuit low frequency
    P1336 Crankshaft Position System Variation Not Learned
    P1337 Crankshaft Speed Fluctuation Sensor No Signal
    P1350 Ignition Control System
    P1351 Ignition Coil Control Circuit High Voltage
    P1352 Ignition Bypass Circuit High Voltage
    P1359 Crankshaft Position/TDC/Cylinder Position Sensor Connector Disconnection
    P1361 Intermittent Interruption In TDC1 Sensor Circuit
    P1362 No Signal In TDC1 Sensor Circuit
    P1366 Intermittent Interruption In TDC2 Sensor Circuit
    P1367 No Signal In TDC2 Sensor Circuit
    P1370 Ignition Control (IC) Module 4x Reference too many pulses
    P1371 Ignition Control (IC) Module 4x Reference too few pulses
    P1374 CKP High to Low Resolution Frequency Correlation
    P1375 Ignition Control (IC) Module 24x Reference High Voltage
    P1376 Ignition Ground Circuit
    P1377 Ignition Control (IC) Module Cam Pulse to 4x Reference Pulse Comparison
    P1380 EBTCM DTC Detected-Rough Data Unusable
    P1380 Variable Cam Timing Solenoid A Circuit Malfunction
    P1381 Misfire Detected-No EBTCM/PCM Serial Data
    P1381 Cylinder Position Sensor Intermittent Interruption
    P1381 Variable Cam Timing Over-advanced (Bank 1)
    P1382 Cylinder Position Sensor No Signal
    P1383 Variable Cam Timing Over-retarded (Bank 1)
    P1388 Auto Shutdown Relay Circuit
    P1389 No ASD Relay Output Voltage At PCM
    P1390 Timing Belt Skipped One Tooth or More
    P1390 Octane Adjust Out Of Range
    P1391 Intermittent Loss of CMP or CKP
    P1398 Mis-Fire Adapter Numerator at Limit
    P1399 Wait To Start Lamp Circuit
    Heated Catalyst Battery Voltage or Current too Low During Heating (Bank 1)
    P1401 Heated Catalyst Current too High During Heating (Bank 1)
    P1402 Heated Catalyst Power Switch Over temperature Condition (Bank 1)
    P1402 EGR Function (Open)
    P1403 Carbon Canister Shut Off valve Control Circuit Electrical
    P1404 Exhaust Gas Recirculation (EGR) Valve Pintel Stuck Open
    P1405 Heated Catalyst Power Switch Over temperature Condition (Bank 2)
    P1406 Heated Catalyst Internal Control Module Checksum/ROM Error
    P1407 EGR No Flow Detected
    P1408 EGR Out Of Self Test Range
    P1409 EGR Vacuum Regulator Solenoid Circuit Malfunction
    P1410 EGR Valve Position Sensor Circuit Malfunction
    P1411 Secondary Air Injection System Downstream Flow
    P1413 Secondary Air Injection Pump Relay Control Circuit Signal Low
    P1414 Secondary Air Injection System Monitor Circuit High
    P1415 Secondary Air Injection (AIR) System Bank 1
    P1416 Secondary Air Injection (AIR) System Bank 2
    P1420 Secondary Air Valve Control Circuit Electrical
    P1421 Secondary Air System Bank 1
    P1422 Secondary Air System Bank 2
    P1432 Secondary Air Injection System Incorrect Flow Detected
    P1436 A/C Evaporator Temperature Circuit Low Input
    P1437 A/C Evaporator Temperature Circuit High Input
    P1438 Purge Control Valve Control Open Circuit
    P1439 Purge Control Valve Control Circuit Signal Low
    P1440 Purge Control Valve Control Circuit Signal High
    P1441 Evaporative System Flow During Non-Purge
    P1442 Leakage Diagnostic Pump Control Circuit Signal Low
    P1443 Leakage Diagnostic Pump Control Circuit Signal High
    P1444 Diagnostic Module Tank Leakage (DM-TL) Pump Control Open Circuit
    P1445 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal Low
    P1446 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal High
    P1447 Diagnostic Module Tank Leakage (DM-TL) Pump Too High During Switching
    P1448 Diagnostic Module Tank Leakage (DM-TL) Pump Too Low During Switching
    P1449 Diagnostic Module Tank Leakage (DM-TL) Pump Too High
    P1450 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Open Circuit
    P1451 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal Low
    P1452 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal High
    P1453 Secondary Air Injection Pump Relay Control Circuit Electrical
    P1454 Secondary Air Injection Pump With Series Resistor Control Circuit Electrical
    P1456 Leak Detected In EVAP Control System
    P1457 Leak Detected In EVAP Control System
    P1459 Heated Catalyst Heater Power Supply Open Circuit (Bank 2)
    P1460 Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 2)
    P1461 Heated Catalyst Gate Voltage Signal Low
    P1462 Heated Catalyst Internal Control Module Checksum/ROM Error
    P1463 Heated Catalyst Battery Temperature Sensor 1 Electrical
    P1464 Heated Catalyst Battery Temperature Sensor 2 Electrical
    P1465 Heated Catalyst Battery Temperature Sensor 1 or 2 Plausibility
    P1466 Heated Catalyst Power Switch Temperature Sensor Plausibility
    P1467 Heated Catalyst Comparison Battery Voltages of Power Switches Plausibility
    P1468 Heated Catalyst Battery Disconnecting Switch Plausibility
    P1469 Low A/C Cycling Period
    P1470 Leakage Diagnostic Pump Control Circuit Electrical
    P1472 Diagnostic Module Tank leakage (DM-TL) Switching Solenoid Control Circuit Electrical
    P1473 Diagnostic Module Tank leakage (DM-TL) Pump Current Plausibility
    P1474 HCF Primary Circuit Failure
    P1475 Leakage Diagnostic Pump Reed Switch Did Not Close
    P1476 Leakage Diagnostic Pump Clamped Tube
    P1477 Too Much Secondary Air
    P1478 Battery Temp Sensor Volts Out of Limit
    P1479 Transmission Fan Relay Circuit
    P1480 PCV Solenoid Valve
    P1482 Catalyst Temperature Sensor Circuit Shorted Low
    P1483 Engine Cooling System Performance
    P1484 Catalytic Converter Overheat Detected
    P1485 Air Injection Solenoid Circuit
    P1486 Evap Leak Monitor Pinched Hose
    P1487 Hi Speed Rad Fan CTRL Relay Circuit
    P1488 Auxiliary 5 Volt Supply Output Too Low
    P1489 High Speed Fan CTRL Relay Circuit
    P1490 Low Speed Fan CTRL Relay Circuit
    P1491 Malfunction In EGR System
    P1492 EVAP Canister Purge Control/Solenoid Valve (Circuit)
    P1493 Ambient/Batt Temp Sen Volts Too Low
    P1494 Leak Detection Pump Switch or Mechanical Fault
    P1495 Leak Detection Pump Solenoid Circuit
    P1496 5 Volt Supply Output Too Low
    P1498 Voltage Problem In EGR Valve Position Sensor Circuit
    P1499 Vehicle Speed Sensor (VSS)
    P1501 Vehicle Speed Sensor (VSS) Out Of Range
    P1502 Vehicle Speed Sensor (VSS) Intermittent
    P1505 Idle Air Control At Adaptive Clip
    P1506 Idle Air Control System Over speed Error
    P1507 Idle Air Control System Under speed Error
    P1508 Idle Air Control (IAC) System - Low RPM
    P1516 Inlet Manifold Runner Control Input Error (Bank 1)
    P1517 Inlet Manifold Runner Control Input Error (Bank 2)
    P1518 Inlet Manifold Runner Control Stuck Open
    P1519 Malfunction In IAC Valve Circuit
    P1520 Intake Manifold Runner Control (IMRC) circuit malfunction
    P1524 Throttle Position (TP) Sensor Learned Closed Throttle Angle Degrees Out-Of-Range
    P1527 Trans Range / Pressure Switch Comparison
    P1546 Air Conditioning (A/C) Clutch Relay Control Circuit
    P1549 Intake Manifold Control Circuit Malfunction
    P1550 PSP Sensor Malfunction
    P1554 Cruise Engaged Circuit High Voltage
    P1560 Cruise Control System-Transaxle Not in Drive
    P1564 Cruise Control System-Vehicle Acceleration too high
    P1566 Cruise Control System-Engine RPM Too High
    P1567 Cruise Control- ABCS Active
    P1570 Cruise Control System - Traction Control Active
    P1571 Traction Control System PWM Circuit No Frequency
    P1572 Brake Pedal Switch Circuit
    P1574 EBTCM System- Stop Lamp Switch Circuit High Voltage
    P1575 Extended Travel Brake Switch Circuit High Voltage
    P1579 Park/Neutral to Drive/Reverse At high Throttle Angle
    P1585 Cruise Control Inhibit Output Circuit
    P1594 Charging System Voltage Too High
    P1595 Speed Control Solenoid Circuits
    P1596 Speed Control Switch always High
    P1597 Speed Control Switch always Low
    P1598 A/C Pressure Sensor Volts Too High
    P1599 A/C Pressure Sensor Volts Too Low
    P1602 Loss of EBTCM Serial Data
    P1603 Loss of SDM Serial Data
    P1604 Loss of IPC Serial Data
    P1605 Loss of HVACC Serial Data
    P1607 Malfunction In PCM Internal Circuit
    P1610 Loss of PZM Serial Data
    P1611 Loss of CVRTD Serial Data
    P1617 Engine Oil Level Switch Circuit
    P1621 PCM Memory Performance
    P1626 Theft Deterrent System - Fuel Enable Circuit
    P1630 Theft Deterrent - PCM in Learn Mode
    P1631 Theft Deterrent - Password Incorrect
    P1632 Theft Deterrent - Fuel Disabled
    P1633 Ignition Supplement Power Circuit Low Voltage
    P1634 Ignition 1 Power Circuit Low Voltage
    P1635 5 Volt Reference Circuit
    P1639 5 Volt Reference 2 Circuit
    P1640 DTC's Available In Another Module
    P1641 Malfunction Indicator Lamp (MIL) Control Circuit
    P1642 Vehicle Speed Output Circuit
    P1644 Delivered Torque Output Circuit
    P1645 EVAP Solenoid Output Circuit
    P1646 EVAP Vent Valve Output Circuit
    P1650 Driver 2 - Input High Voltage
    P1651 Power Steering Pressure Switch Input Malfunction
    P1652 Lift/Dive Circuit
    P1654 Cruise Disable Output Circuit
    P1656 Automatic Transaxle
    P1660 Cooling Fan Control Circuits
    P1676 FPTDR Signal Failure
    P1678 FPTDR Signal Line Failure
    P1680 Clutch Released Switch Circuit
    P1681 No I/P Cluster CCD/J1850 Messages Received
    P1682 A/T FI Signal A High Input
    P1683 Speed Control Power Relay or S/C 12V Driver Circuit
    P1685 Skim Invalid Key
    P1686 No SKIM Bus Message Received
    P1686 A/T FI Signal B Low Input
    P1687 A/T FI Signal B High Input
    P1689 Traction Control Delivered Torque Output Circuit
    P1693 DTC Detected In Companion Mode
    P1694 Fault In Companion Mode
    P1695 No CCD/J185O Message From BCM
    P1696 PCM Failure EEPROM Write Denied
    P1697 PCM Failure SRI Mile Not Stored
    P1698 No Bus Message From TCM
    P1701 Transmission Solenoid Malfunction
    P1703 Brake On/Off Switch
    P1703 Brake On/Off Switch Out Of Range
    P1705 Automatic Transaxle
    P1706 Automatic Transaxle
    P1709 Automatic Transaxle
    P1710 Automatic Transaxle
    P1711 Transmission Fluid Temperature Sensor
    P1713 Automatic Transaxle
    P1719 Skip Shift Solenoid Circuit
    P1729 4x4 Low Switch
    P1738 Automatic Transaxle
    P1739 Automatic Transaxle
    P1740 Automatic Transaxle
    P1746 EPC Solenoid Failed Low
    P1747 EPC Solenoid Short Circuit
    P1749 EPC Solenoid Open Circuit
    P1751 Shift Solenoid #1 (SS1)
    P1753 Automatic Transaxle
    P1754 Coast Clutch Solenoid
    P1756 GOV Press Not Equal To Target @ 15-20 PSI
    P1756 Shift Solenoid #2 (SS2)
    P1757 GOV Press Not Equal To Target @ 15-20 PSI
    P1758 Automatic Transaxle
    P1761 Shift Solenoid #3 (SS3)
    P1762 Gov Press Sen Offset Volts Too Low or high
    P1763 Governor Pressure Sensor Volts Too High
    P1764 Governor Pressure Sensor Volts Too Low
    P1765 Trans 12 Volt Supply Relay CTRL Circuit
    P1768 Automatic Transaxle
    P1773 Automatic Transaxle
    P1778 Automatic Transaxle
    P1780 Transmission Control Switch
    P1781 4x4 Switch Out Of Range
    P1783 Transmission Over Temperature Condition
    P1786 Automatic Transaxle
    P1790 Automatic Transaxle
    P1791 Automatic Transaxle
    P1792 Automatic Transaxle
    P1794 Automatic Transaxle
    P1810 TFP Valve Position Switch Circuit
    P1811 Maximum Adapt and Long Shift
    P1819 Internal Mode Switch - No Start/Wrong Range
    P1820 Internal Mode Switch Circuit A Low
    P1822 Internal Mode Switch Circuit B High
    P1823 Internal Mode Switch Circuit P Low
    P1825 Internal Mode Switch - Invalid Range
    P1826 Internal Mode Switch Circuit C High
    P1860 TCC PWM Solenoid Circuit Electrical
    P1887 TCC Release Switch Circuit
    P 1899 Park/Neutral Position Switch Stuck In Park or In Gear
    Bergville
    Thanks a million! Great help!
    New York, USA
    ive had an error code # P0723 before..good thing ive found this thread,,i now know that it means "Output Vehicle Speed Sensor Intermittent".
