Results 1 to 8 of 8
    Jan 2022
    Westville
    Thanked: 32
    Default Fork oil expiry Castrol
    I have been meaning to put a new fork seal on my CRF for the last few years, I think over 5 now as it has a slow leak. I found the sealed bottle of Castrol fork oil and fork seals in my storeroom. Is it okay to use fork oil which may be up to 8 years old. I'm sure it can't damage the fork? The current oil has been in the fork since 2008 so hopefully it would be fine or should I just toss it and buy new oil?
    Nov 2008
    Ellisras
    Thanked: 1784
    Default Re: Fork oil expiry Castrol
    Sealed bottle, no issue. tshirt - many years and moola driving son all over RSA for Off Road Racing
    PS I am a little concerned about the seals, are they still in the original packaging, possibility they deteriorated if allowed to dry out or in contact with UV
    2000 Patrol GU 4.2D(onkey) "old-timer" chugging along towards 900 000 km.
    2014 Patrol GU 3.0CRD "teenager" in puberty - 138 000 km
    2007 Echo3 Trailer "the nest" with Braked Axle fitted >60 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" - 131 000 km
  3. The Following User Says Thank You to Dungbeetle For This Useful Post:
    Jan 2022
    Westville
    Thanked: 32
    Thank you, thought so but needed to double check. Could not find an expiry date on the bottle either.
    Nov 2008
    Ellisras
    Thanked: 1784
    Do you still have the CRF manual, follow the oil level instruction closely
  6. The Following User Says Thank You to Dungbeetle For This Useful Post:
    Jan 2022
    Westville
    Thanked: 32
    The seals are still in Honda sealed packaging and look okay. They were about R500 or so those years ago so don't want to even check what they would be now. They should be fine as the other seals have been in since 2008.
    Jan 2022
    Westville
    Thanked: 32
    Yes, I have the manual, a downloaded version now.
    Jan 2022
    Westville
    Thanked: 32
    380ml per fork
    May 2014
    Tshwanetoria
    Thanked: 1935
    If I knew what this was about, I would not have misread this topic.
  11. The Following User Says Thank You to hatjohan For This Useful Post:
