Results 1 to 3 of 3
    Harties
    Thanked: 905
    Default Estate perimeter UPS power
    On our estate we need to install proper inverter/chargers around the perimeter to provide uninterrupted electrical supply to our fence energisers, security cameras and related security equipment.
    The sizes required for units at each station are either 1 000W or 2 000W.
    We'd prefer combined inverter/charger units - probably 24V, and with a solar option would be a plus.
    Can anyone suggest any good brands for these units - with local credible backup.
    Also, anyone having done something similar your suggestions, comments and/or recommendations will be appreciated.
    Thanks.
    If you need music in the bush or on the beach, you’re missing the point.
    Thanked: 1987
    Default Re: Estate perimeter UPS power
    I'm curious. Why the requirement to put the battery and inverter with the energisers and not nearer the original power source?
    "The problem with internet quotes is that they are very often unverified."
    -Abraham Lincoln
    Thanked: 1670
    I have been installing solar on motors, energisers and remote cameras for many years.
    Solar panel, Victron charge controller. 20A and proper battery. The moment you start adding ac and inverter it becomes expensive.
ID:	660725   Click image for larger version.
ID:	660726   Click image for larger version.
    Training: 4x4, bush mechanics, recovery, defensive, 4x4 trucks
    Angel Construction:Turnkey Construction solutions [Indoor shooting ranges, safe rooms, shops and shopfitting,]
    IP CCTV, electric Fencing, Automation,Steel Fabrication. You name it, we can probably build or manufacture it.
    Angel solar :PV systems, rain water harvesting
    [email protected]
    [email protected]
    +27824453301
  4. The Following 2 Users Say Thank You to Engel For This Useful Post:
