Results 1 to 20 of 99
Thread: Mecer 2.4kVA
    Apr 2014
    Thanked: 246
    Default Mecer 2.4kVA
    Hallo everybody
    I need to get my parents out of the dark, i.e. lights only.
    What are the opinions of the following "load shed" kit.
    Hillcrest
    Thanked: 13805
    Default Re: Mecer 2.4kVA
    There are a hundred other options and a thousand other opinions.
    I will offer one opinion.
    YES.
    It is not the best or the optimal.
    And somebody may offer an alterative possibly better option, which is fine.
    Listen to that if you like.
    But otherwise - just do it - it will do the job.
    ZS5KAD - PROFFESIONAL DUMBASS
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
  3. The Following 3 Users Say Thank You to Fluffy For This Useful Post:
    Mar 2016
    Thanked: 4207
    I have a 720w inverter with a 200ah battery.
    For relatively cheap under R10 000 it is a great solution
    André Opperman
  5. The Following User Says Thank You to Oppies3800 For This Useful Post:
    Hillcrest
    Thanked: 13805
    Quote Originally Posted by Oppies3800 View Post
    That's a great solution that will cover many use's.
    Analysis Paralysis is our greatest enemy.
    KISS
    3 Land Rover V8's
    Northcliff
    Thanked: 471
    As fluffy says it will do the job, I was using similar for a short while before I got my kit installed, if you are able to find something with a lithium battery in it thats even better
    though that might be very difficult, I had a look on geewiz and I see a lot is sold out.
    If you are looking to help out the folkes buy what you can.
    2009 Suzuki GV 3.2
    ex : 2010 Suzuki GV 2.4 M/T
    ex : 2007 Audi A4 2.0T - RS4 rear suspension
  8. The Following User Says Thank You to ColeGP For This Useful Post:
  9. #6
    Hillcrest
    Thanked: 13805
    Quote Originally Posted by ColeGP View Post
    A bit of education on how to use the system for the old folks will help lot.
    Honestly
    3 Land Rover V8's
  10. The Following User Says Thank You to Fluffy For This Useful Post:
  11. #7
    Jul 2018
    Also check www.geewiz.co.za Great prices
  12. #8
    Thanked: 1715
    YES.
    As you indicated. I kind of prefer a pure sine. Can at least keep a small fridge running in these testing times.
    https://www.geewiz.co.za/long-run-up...BoCzDIQAvD_BwE
  13. #9
    Oct 2008
    Thanked: 282
    Personally I would recomend this
    https://www.inverter-warehouse.co.za/collections/solar-inverters/products/zuva-back-up-box
    Or maybe the bigger one
    https://www.inverter-warehouse.co.za...-back-up-box-3
    I have the small one and it has worked perfectly for a year, then had to replace the battery, as expected with the amount of outages experienced. Changing the battery is quite simple and easily achieved
    Why I would recomend it, is the solar option, as well the option to add another battery. It is also far less noisy than the mecer setup. I have a single battery 600w mecer option, and it is just so noisy.
    Edit - there are similar options available at geewiz
    Mitsubishi Triton 3.2 DI-D 4x4
    BL925 - Ratel 4
  14. The Following User Says Thank You to Charlie100 For This Useful Post:
  15. #10
    Sep 2014
    Suurbraak
    Thanked: 67
    I would specify emergency lighting (led tube) automated with integrated battery.
    1/10 the cost, no training required, and skip any re-wiring (with exception of plug point lighting, then battery bulbs are apparently available)
    Sent from my SM-P585 using SA 4x4 Community Forum mobile app
  16. #11
    Northcliff
    Thanked: 471
    Quote Originally Posted by Charlie100 View Post
    Both sold out.
    Most things sold out.
    2009 Suzuki GV 3.2
  17. #12
    Thanked: 299
    Also install a few of these rechargeable bulbs in rooms that are used a lot, bed side lamp, toilet, bathroom, living room etc. They need to charge when used, works from the light switch even if power is off.
    https://www.chamberlains.co.za/litem...SABEgIyT_D_BwE
    2014 Nissan Navara 2.5 4x2
    1995 Nissan Sani 3.0 V6 4x4
  18. #13
    Thanked: 334
    Honestly
    A lot of truth in this. Sometimes it is better to spend more and get a system that requires minimal intervention or understanding once installed or set up.
    Even simple systems can be daunting for older folks if it needs some management or consist of several components.
    Keep it as simple as possible. (We forget you know)…
  19. #14
    Thanked: 452
    Quote Originally Posted by staalwol View Post
    How does these work? Do they switch on/off with the wall switch either with/without eskom power or do they come on permanently when eskom is out?
    Neil
  20. #15
    Thanked: 1747
    Quote Originally Posted by neoT View Post
    Read the reviews on that link?
    Political Correctness
  21. #16
    Thanked: 334
    I have to come back to your original post. If it is only lights you are after, one of the cheapest solutions may be getting two or three of the below units.
    https://www.hificorp.co.za/tevo-magn...SABEgLfx_D_BwE
    Change the batteries once a year if need be and Bob’s your uncle.
    They can be left on charge and set to automatically turn on when power goes down.
    If you want to start powering other appliances then the thinking needs to go a little further.
  22. #17
    Thanked: 95
    We have installed a few of these throughout the house. They need to be switched on to charge (4-5 hour charges gives about 2 hours light when power is down. What we're experiencing with stage 4-6 LS is that there is not enough time for the bulbs to charge fully before the next outage.
    We also recently installed a Mecer 1440W inverter from Geewiz. This runs our wifi, a floor lamp, tv, soundbar and Mi box and has been brilliant! Best R9000 we have spent to combat LS.
  23. The Following User Says Thank You to Mikepike For This Useful Post:
  24. #18
    Gaborone, Botswana
    Thanked: 2141
    Quote Originally Posted by Mikepike View Post
    .....We also recently installed a Mecer 1440W inverter from Geewiz. This runs our wifi, a floor lamp, tv, soundbar and Mi box and has been brilliant! Best R9000 we have spent to combat LS.
    Exactly how I have been using mine for many years.
    Add a few rechargeable torches/lanterns (for the trip to the kitchen/bathroom) and Bob's you Uncle.
    Kobus
  25. #19
    Apr 2014
    Thanked: 246
    Thanks everyone. Great to have a forum like this.
    Looking at prices, the Mecer 2.4 at that price still seems to be a good option.
  26. The Following User Says Thank You to LdLL For This Useful Post:
  27. #20
    Apr 2014
    Thanked: 246
    Quote Originally Posted by bloudraad View Post
    Thanks. Really a good option.
    At this stage only lighting, but would like to add the TV later.
    My parents are already turning 85 this year. Apart from lighting I want to try and give them some "normality" and if you want to, quality of life.
