Results 1 to 20 of 27
Thread: Dead battery?
    Thanked: 193
    Default Dead battery?
    I have a 12v 4000w Changi inverter running off 3x200ah gel batteries. This covered my load shedding needs easily.
    The past 2 days, the inverter has been giving low battery warnings after about an hour.
    Nothing has change with the load.
    I disconnected all the batteries and each one is showing 12.8 volts. I then connected the inverter to each battery separately without any load, but it does the same thing on each battery (i.e. inverter powers up, but then says that the battery is in the low 11 volts).
    Any ideas as to what could be the issue?
    Thanked: 1475
    Default Re: Dead battery?
    How old and how many cycles has the batteries done? have you done a load test? take them to a battery place to check
    Training: 4x4, bush mechanics, recovery, defensive, 4x4 trucks
    Supply and manufacture: Recovery gear, Custom 4x4 installations and manufacturing, 4x4 equipment
    Angel Construction:Turnkey Construction solutions [Indoor shooting ranges, safe rooms, shops and shopfitting,]
    IP CCTV, electric Fencing, Automation,Steel Fabrication. You name it, we can probably build or manufacture it.
    Angel solar :PV systems, rain water harvesting
    [email protected]
    [email protected]
    +27824453301
    Thanked: 1633
    Quote Originally Posted by veedub View Post
    Even if they show 12.8V when charged they have lost capacity and the voltage just collapses under load. Perhaps too deep cycling with all the LS and not enough time to recharge to full.
  4. The Following User Says Thank You to ekkekan For This Useful Post:
    Kriel
    Thanked: 353
    Quote Originally Posted by Engel View Post
    I also have 4x 200amp gel batteries...at night when Eishkom runs out with only the fridge and freezer the batteries lasts only 1 and half hours....then low battery warning....considering switching to 2 lithium battery packs...
    Thanked: 1633
    Quote Originally Posted by John.oosthuizen95 View Post
    As a test one could also charge each battery to 14.3V and do another load test to see if it does not give a longer time on the same load before writing them off. With the LS it might just be that there is not enough time to recharge them to full.
    This test charge to be done at no higher than 20A.
  7. The Following User Says Thank You to ekkekan For This Useful Post:
    Oct 2018
    Pietermaritzburg
    Thanked: 10
    For those 3 x 200ah batteries in parallel to fully charge the charge current needs to be around 60A. Check what the Changi charge current is.
  9. The Following User Says Thank You to BumperD For This Useful Post:
  10. #7
    Thanked: 193
    The batteries are about 2 years old and I never run them beyond the 50% dod. I only run tvs, wifi, led lights and security system, so max 350watts during load shedding.
    The battery charger is separate to the inverter. Its a 50amp 'smart' charger. If i connect the charger to the batteries, it doesn't charge as its picking up that the batteries are fully charged.
    I've now put the inverter to each battery and ran seperate tests. The inverter initially reads 13.0v on the battery. As soon as a I run a 70watt load (tv and decoder), the voltage drops to 11.5 and alarms. Doing this on each of the 3 batteries.
    Maybe the inverter is faulty?
  11. #8
    Cape Winelands
    Thanked: 450
    Sounds like those batteries are shot if if it drops like that with such a small load, you can try to set the minimum voltage settings lower on inverter to see if you can get more usage out of them maybe?
    2004 Ranger 4000 V6 Auto (Weekender & Heavy loads)
    2011 BMW X1 Auto (My Mommy-Wagon)
    2011 CashCow 1.6 (Swambo)
  12. #9
    Oct 2018
    Pietermaritzburg
    Thanked: 10
    Quote Originally Posted by Kamakazi View Post
    Agreed, the batteries seem to be shot.
  13. #10
    Thanked: 193
    I connected the inverter to my car battery and ran the same load...it worked fine, so batteries are toast.
    I need to still figure out whether I want to spend the money to move to 48v inverter and lithium batteries, so might just get 1x200ah gel to run wifi and some lights for now.
    Where can I dispose of the these batteries (they are bloody heavy)?
  14. #11
    Dec 2011
    Thanked: 197
    Scrap yard or dedicated battery scrap guy
    The value is quite high
    My battery guy paid me R2k for around 225kgs a few months ago
  15. #12
    Nov 2008
    Ellisras
    Thanked: 1730
    Also check if that charger has an Equalization algorithm. Not good for Gel and Lithium.....
    2000 Patrol GU 4.2D(onkey) "old-timer" chugging along towards 900 000 km.
    2014 Patrol GU 3.0CRD "teenager" in puberty - 138 000 km
    2007 Echo3 Trailer "the nest" with Braked Axle fitted >60 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" - 131 000 km
  16. #13
    Thanked: 1633
    This is a clear sign that the batteries are no good if the smart charger does not SEE the discharged state but goes to fully charge immediately.
  17. #14
    Cape Winelands
    Thanked: 450
    Quote Originally Posted by DirtBasher View Post
    Care to share the details of your battery guy? I have 2 Trojans to dispose of and also don't know where to take them
  18. #15
    Perlemoenbaai, Gansbaai
    Thanked: 2866
    Winter is a great leveler of batteries.
  19. #16
    Mar 2011
    Walker Bay
    Thanked: 1669
    What brand were your 3x200ah gel batteries ?
  20. #17
    Feb 2020
    Melkbosstrand
    Thanked: 171
    I usually take my batteries to the place I get new batteries. The last two replacements were with Cooper Power (UPS) and Batteries24 (crank battery).
    Generally you get around R200 off the price of the new ones with the return of the old ones.
    1995 Defender 110 300tdi (nick-named Alfie)
    1978 Mercedes Benz 450SL
    2000 Volvo V40 T4 (on the market - What offers?)
  21. #18
    Thanked: 1633
    Quote Originally Posted by CraigWatt View Post
    The standard discount when buying a new battery from dealers is R250 + VAT. This is mostly shown as a scrap loading on an invoice. Any car battery is good as the scrap trade in.
    It seems everything is cheaper in CoCT
  22. The Following User Says Thank You to ekkekan For This Useful Post:
  23. #19
    Thanked: 193
    I left the old ones at the dealer (no money for it) and bought a 300ah 12v gel battery.
    Old batteries and new one are from Five Star.
    Will use this one for now until I decide on lithium.
    My cousin got a 10kva hybrid inverter with wifi plus 2x5kva lithium batteries from them for under R60k. I can probably live with a 5kva inverter and 1x5kva battery, so will be a lot cheaper for me.
    Question - the lithium battery says 5kva 100ah. Does this mean that you can safely draw 100amp per hour from it and that it's capacity is also 100amps (5000wų48volts) at 100% dod? So 2 of these batteries will give 200amps of usable power, but still at max 100amps per hour?
  24. #20
    Sep 2008
    Vanderbijlpark
    Thanked: 400
    2x 100 Ah batteries in parallel will give you 200 Ah, yes.
    Battery capacity is (may also be) stated in Wh or kWh (not kVA). Battery mfrs. state a recommend continuous discharge current and max. short term discharge current. This means that there will be a minimum recommended number of batteries needed depending on the size of the inverter. You cannot for example use just one (say) 3.5 kWh battery on a 3 or 5 kVA inverter, as the inverter's current draw will exceed the maximum rated discharge current of the battery.
    As an example, for Pylontech batteries, Victron recommends 2x batteries for their 3 kVA 48 V inverters and 4x batteries for the 5 kVA 48 V models.
    I would not discharge to 100% DOD though,
    ZS6VL
