Results 1 to 5 of 5
    Okahandja, Windhoek
    Thanked: 1373
    Default Victron Orion DC to DC charger working?
    I bought a 18amp one for my abba camper. Set it up, and its working fine!
    But my question to those that already have it, do I need to do that 4 step setup procedure each time I connecting it to the car battery and the aux battery? The camper battery (aux) is not kept in the camper when the camper is not loaded/used.
    Johan Kriel
    Feb 2016
    Thanked: 1076
    Default Re: Victron Orion DC to DC charger working?
    To which 4 steps are you referring to?
    When I disconnect my Aux battery I remove the remote on/off wire bridge on the orion, then I remove the fuse at the Aux battery, and then I disconnect the battery itself.
    Okahandja, Windhoek
    Thanked: 1373
    Quote Originally Posted by MrTolbos View Post
    From the manual:
    4.3. Connection setup for charger mode
    1. Disconnect the remote on/off (remove wire bridge).
    2. Connect the input supply cables.
    3. Open the VictronConnect App to setup the product. (always setup the correct charger algorithm before connecting a battery)
    4. Connect the battery to be charged.
    5. Reconnect the remote on/off to activate the product
    From #3 it seems one have to? , once reconnecting the batteries?
    Johan Kriel
    Jan 2021
    Tzaneen
    Thanked: 87
    I have a cable from crank battery to Orion with a BH plug.
    The aux is LiFePo, so when it is not in use then I just pull the BH plug to avoid overcharge. I just plug in again when needed, all works fine without following those steps.
  5. The Following User Says Thank You to Craig McK For This Useful Post:
    Okahandja, Windhoek
    Thanked: 1373
    Quote Originally Posted by Craig McK View Post
    So then its a once off thing! Thanks
    Johan Kriel
