Page 6 of 6 FirstFirst ... 2 3 4 5 6
Results 101 to 109 of 109
  1. #101
    Dec 2018
    Highveld
    Thanked: 46
    Default Re: Ford's new 3L V6 Diesel "Lion" Engine
    Cam gear snapped on older Land Rover V6.
    https://www.facebook.com/share/r/HfJ...ibextid=31ks6x
  2. #102
    Dec 2012
    In my agterplaas in die WC
    Thanked: 456
    I am not a Ford or Rand Lover driver at all and not slating the brands at all...But
    Please explain to me how a overtightened Cambelt can cause a Cam pulley to snap . The sheer forces required to do that is just phenomenal. I would like to see a man take a pulley like that ...placed in a vice and break it the way they snapped in pics in this thread. I think you would need a serious amount of torque and a moerske long power bar to snap that pulley. So in my humble opinion I think that a over tightened tensioner is a lot of hogwash .
    I have seen Belts that were stripped bare of the teeth because of a Cam seizure ...or a lifter seizure ...on a few engines . But have never seen a cam pulley broken like this .
    My money would be on a Camshaft seizure
    Something is causing a catastrophic seizure of some internal part and that is the cause of the snapped pulley ...Or the pulley is made of marshmallows . It seems that nobody has opened one of these engines to actually see what the cause is of these failures ? And the manufacturer would most probably like to keep it that way.
    Sakkie van Staden
    Current Jeeps owned
    1.Silver de Lange.2003 WJ Jeep..NOW powered by a 4L VVTI V8 Defy motor Forum Rebuild thread
    2. 2004 Jeep Grand Cherokee 2.7 CRD Diesel power....4 inch Home build Long arm lift
    3. 2005 Black pearl 2.7CRD 4. 2004 Laredo 2.7 CRD 5. 2004. Overlander 2.7CRD 6. 2006 WK1 3.0CRD
    Past Jeep 3.1 Wj..AKA Turbo Esel (RIP)
    Man made it....Man Fix it.....
    I'm going to use all my tools, my God-given ability, and make the best life I can with it.
    LeBron James
  3. The Following User Says Thank You to Sakkie7 For This Useful Post:
  4. #103
    Jan 2016
    Richardsbay
    Thanked: 189
    Just adding some info, my friend’s wife new Ford Everest platinum v6 diesel snapped the cam pully shaft, car has under 15k on the clock!!!
    The putting a new engin!
    Just passing info!
  5. #104
    Aug 2016
    Thanked: 526
    Quote Originally Posted by Sakkie7 View Post
    I believe it is not the rotational torque that breaks it but rather the back and forth bending.
    For context on my statement. We tested it on my TDV6 when I did the cambelt. With dial gauges on both cam gears. When exceeding the tension limit the cam gears and more so the driver side one, the top starts to flex towards the engine and the bottom away. It is very very little but still there. I suspect the slight bending back and forth weakens the spokes on the gear to the point of failure, kind of like flexing a piece of wire from side to side.
    If set to the mid to lower limit of the tension there is no flex in the gear.
  6. The Following User Says Thank You to _FC For This Useful Post:
  7. #105
    Dec 2012
    Thanked: 456
    Quote Originally Posted by _FC View Post
    I hear you ....but under acceleration..or load ...how much force is on that pulley ? If you can bend it like that ....it really is made out of S**t
    If what you say is spot on then it is a simple fix just to beef up the pulley . Would be interesting to see a old pulley compared to the one on a new engine installed on a replacement engine .
    Sakkie van Staden
    Current Jeeps owned
    LeBron James
  8. #106
    Oct 2012
    otjiwarongo
    Thanked: 1109
    Quote Originally Posted by Frikstervx200 View Post
    Just passing info!
    Year model? 23 or 24?
    2024 VW Amarok V6 Tdi
    2019 Bushlapa Miskruier 1616
    2012 Toyota FJ Cruiser
    2013 Toyota FJ Cruiser (Sold)
    2017 VW Amarok V6 (Sold)
    2023 VW Tiguan R-Line (Sold)
  9. #107
    Jan 2014
    Northern KZN
    Thanked: 837
    Just passing info!
    New engine or new sub assembly? It would be interesting to know how long the process takes in this case it being a Ford badged version. A friends Amarok version took close on 3 months to get repaired. I think there may have been a bit of spite involved from the manufacturer or dealer as he made quite the fuss on Facebook regarding his experience. The moment he got it back he traded it on a well known "Japanese" brand. Bridges burnt.
    Groetnis
    Koos
    2013 Amarok 4 motion manual DC (The workhorse)
    2020 V6 Amarok (The underrated and underestimated Plaas Passat)
  10. The Following User Says Thank You to Beurvoort For This Useful Post:
  11. #108
    Oct 2012
    Roodeplaat
    Thanked: 500
    As the saying goes "Built Ford Tough"
  12. #109
    Aug 2014
    Oppi plaas
    Thanked: 2665
    Quote Originally Posted by Werner Brits View Post
    The Ford Lion engine is like Zuma, just problems, but still popular. Why would anyone buy a vehicle with the Ford Lion motor and think it will suddenly be reliable? It is well documented everywhere how unreliable it is, yet people think the VW badge will fix it. I’m too stupid to understand it.
