Results 1 to 20 of 23
    Drummond
    Default Amarok V6 DPF issues - what now?
    Ok so i recently had DPF issues where on a trip my V6 went into limp mode because of DPF being clogged. Managed to limp to local dealer where a regen was performed and i was merrily sent on my way... no issue since, but strange that it occurred on a 3000km trip around the country over two weeks with speeds of 60 -130km/h and also a bit of off-road and dirt road but predominantly tar... Many have suggested:
    1. De-CAT
    2. DPF removal and delete
    3. EGR Removal
    4. Stage 1 Re-map
    5. Gearbox software upgrade.
    Are these the only things i should consider? or not consider?
    I am not against this, although i am in no real need of any more power besides a better fuel consumption... (11.6L/100km currently - lots of extras on vehicle and a heavy foot)
    I do however have questions as to possible "side effects" each of these changes? The Vehicle is out of warranty with 75000km on the clock. Anyone have some insights as what i should look at doing, and as to possible negative implications with the changes. I have heard some horror stories, albeit because of chipping and not remapping, but don't want to do this blindly.
    Have at it! and thanks for the assist.
    Gnosis
    AKA Daryl
    _________________________
    VW Amarok - 165Kw TDi 4 Motion (2019)
    VW Amarok - 132Kw BiTDi 4 Motion (2012) - (sadly sold and dearly missed)
    VW Toureg - 3.0 V6 TDi (2015) - (Sadly Sold)
    VW Toureg - 3.0 V6 (2022)
    Oct 2012
    otjiwarongo
    Thanked: 890
    Default Re: Amarok V6 DPF issues - what now?
    Quote Originally Posted by Gnosis View Post
    Ok so i recently had DPF issues where on a trip my V6 went into limp mode because of DPF being clogged. Managed ot limp to local dealer where a region was performed and i was merrily sent on my way... no issue since, but strange that it occurred on a 3000km trip around the country over two weeks with speeds of 60 -130km/h and also a bit of off-road and dirt road but predominantly tar... Many have suggested:
    1. De-CAT
    2. EGR Removal
    3. Stage 1 Re-map
    4. Gearbox software upgrade.
    ek het n 2017 met 139 000km op, en nog net 1 keer gebeur dat die liggie aankom, nog nooit in limp mode gegaan nie. Jy sit kar dan op cruise control 80km uur, sit als aan, ac, hoof ligte, back window warmers, radio als wat jy kanaansit en ry dan vir so 10km tot die liggie af gaan. as jy nie dit gaan doen dan sal hy in limp mode in gaan. ek sal nie die ander goed gaan doen nie, behalwe dalk die remap.
    kan gebeur dat die kar nie hard werk en dan clock die dpf of vuil diesel of verkeerde olie (ek is nou ni en expert) ek het n software update gedoen na myne geclock het en nog nie weer gebeur, hy iddle nou ook normaal, gewoonlik as hy begin clock dan begin die bakkie hoer rev, so by die 1000 rond
    cheers
    2024 VW Amarok V6 Tdi
    2019 Bushlapa Miskruier 1616
    2013 Toyota FJ Cruiser (Sold)
    2017 VW Amarok V6 (Sold)
    2023 VW Tiguan R-Line (Sold)
  3. The Following User Says Thank You to hein100 For This Useful Post:
    Jul 2017
    Paulshof
    Thanked: 1031
    On 88000km now, have also had the light come on once, no limp mode though. I put it in manual and did my daily commute to the South, kept the gears low and revs high for 40km and it solved the problem. Prior to this my car stood for 3 days, it then rained non stop for over a week which made me drive very cautiously with extremely low revs. I would say they need a good burn often.
    2018 VW Amarok V6 Auto 4Motion
  5. The Following User Says Thank You to Ooba For This Useful Post:
    Sep 2020
    Thanked: 60
    I'm not too familiar with this engine, I don't know if it has a cat and a dpf together, but I'd have both removed and have downpipes put in with cat foolers.
    You'll gain some responsiveness.
    The alternative is that you need to do an "Italian tune up" every once in a while to get everything hot, to remove blockages. You'll probably have to drive the car very hard for a couple km every few months.
  7. The Following User Says Thank You to Mikel89 For This Useful Post:
  8. #5
    Jun 2012
    Thanked: 9876
    If its out of warranty and you are not a bunny hugger then its a no-brainer to decat do a DFP delete (you will need the car coded for this, so while you are it you can release quite a few more ponies but thats whole different debate)
    On the upside it will make the car a bit more responsive but dont expect any real improvement on fuel economy.
    Anton Muller
    Nothing upsets me more than vegetarians having pudding
    2024 X5 M60i
    2020 X3 M40i
    Birkin SR20VET race car
  9. The Following User Says Thank You to mullerza For This Useful Post:
  10. #6
    Apr 2011
    JHB/BALLITO
    Thanked: 32
    Mate of mine Dad`s V6 dpf also gave issues, vw done regen to luck so I arranged with Liqui Moly team and Big Boss Auto to clean the DPF and Sensor what a world of difference and his is strong again with no issues. Would recommend them closed eyes
ID:	656667   Click image for larger version.
  11. #7
    Jul 2017
    Paulshof
    Thanked: 1031
    Those that have done the above on the v6, is there alot more soot afterwards? I remember the modded 1,9TDI Polos and Ibiza Cupras making terrible soot after been tuned and fiddled with.
  12. #8
    Jun 2012
    Thanked: 9876
    Quote Originally Posted by Ooba View Post
    I did it to my Q7 V8 tdi (very similar engine to the V6), no difference to smoke before and after.
    The Polo's you refer to usually have stupid crazy power outputs by simply dumping as much fuel and boost as they can into the engine, I knew someone who could make traffic behind him disappear both in smoke and distance with his Polo TDI - the car was a monster but had an appetite for turbos. Dont confuse those cars with a sensible tune on the V6.
    Anton Muller
    2024 X5 M60i
    2020 X3 M40i
  13. The Following User Says Thank You to mullerza For This Useful Post:
  14. #9
    Tshwanetoria
    Thanked: 3593
    Quote Originally Posted by MR PERSONALITY View Post
    Is that the MAF?
  15. #10
    Vanderbijlpark
    Thanked: 1166
    None whatsoever.
    I have a 76mm freeflow and remap. My wife once drove behind me and I asked her to watch for smoke. Even at WOT there no smoking at all.
    I does have a very conservative map though, don't know if this has anything to do with it.
    2022 Amarok V6
  16. The Following User Says Thank You to clubbie For This Useful Post:
  17. #11
    Apr 2011
    JHB/BALLITO
    Thanked: 32
    Is that the MAF?
    YIP on the DPF, have a video as well
  18. #12
    Maybe this will help you
    https://www.shop.liqui-moly.co.za/pr...ilter-cleaner/
    You should be able to get this from Goldwagen.
    There are a number of videos on YouTube that show the process, using similar liquid cleaning methods.
  19. #13
    Feb 2012
    Sedgefield
    Thanked: 1398
    My local techy told me the best you can do for your diesel is a De Waal exhaust, adds years to your turbo life.
    2018 Hilux Dakar fully kitted.
    2016 Metalian Parthian
    2021 Suzuli Swift 1.2 GLX Swambo's shopping trolley.
  20. #14
    Vanderbijlpark
    Thanked: 1166
    Quote Originally Posted by pwgg View Post
    De Graaf
    But yes, it brings down the EGT a lot.
    2022 Amarok V6
  21. #15
    Jul 2023
    How long did it last before the engine go into regen again? Or do you have to use Liqui Molly permanently?
  22. #16
    Jul 2023
    1. De-CAT
    3. EGR Removal
    4. Stage 1 Re-map
    What did you end up doing to resolve your DPF problem?
  23. #17
    Drummond
    Quote Originally Posted by kobuslouw View Post
    After another regen issue, in the end i did the EGR delete with de-cat and DPF removal as well as ZF box software update... I was skeptical, but i can honestly say the vehicle is a whole different animal. More that 1L/100km improvement (driving dependant) and the vehicle is much more responsive both on the auto box and engine performance. Didn't do stage one, but did up the KW to current V6 (pre-volksford ama-ranger) spec - 190kw. I have no idea why anyone would want more. Towed a 1 ton loaded trailer and 5 people to CPT and back with a consumption of 13.6L/100km. So all in all i am very happy with the vehicle and will definitely keep it to at least 300 000km. (just done 96000km)
    If you vehicle is out of warranty, i would highly recommend the changes... I have a friend with the 2L and he is also pleased with the change on his.
    Gnosis
    AKA Daryl
  24. The Following User Says Thank You to Gnosis For This Useful Post:
  25. #18
    Vanderbijlpark
    Thanked: 1166
    What does this entail and who did this for you?
    2022 Amarok V6
  26. #19
    Krugersdorp
    Thanked: 3233
    Quote Originally Posted by clubbie View Post
    Generally reputable tuners will be able to do a gearbox flash as well as the engine flash.
  27. #20
    Drummond
    Quote Originally Posted by JS-V8 View Post
    I used a company called ATM Automotive software in KZN. They arranged the software and physical removals. I didnít go with a replacement pipe. I asked that they just cut open the two boxes and remove CAT and DPF then close up. They also ensured there was a slight reduction in the pipe to ensure a little back pressure, but the pipe in general looks standard which is what I wanted.
    Gnosis
    AKA Daryl
  28. The Following User Says Thank You to Gnosis For This Useful Post:
