Results 1 to 19 of 19
    Ruimsig
    Thanked: 35419
    Default Defender 110 300TDi Costs
    Morning all
    What are the expensive bits on the Defender 110 300TDi to be aware of, should they decide to tjune Huzit and what are their indicative costs?
    Who are the best Indies in Jwannesbeg, closest to the Woes Runt, when it comes to the Defender 110 300TDi?
    And if there is anyone here who thinks this union should not take place, speak now or forever hold your piece
    Estee = S T = Sean Towlson
    1981- ish Land Rover SIII S SW ''Bitsa'', powered by a Toyota 2B oil burning Wheezer
    Apr 2019
    Thanked: 3481
    Default Re: Defender 110 300TDi Costs
    Morning all
    Walter @ LRExtreme is the best of the best. I leave it to others on whatís expensive. Iíll say this:
    Owning 2 D4s and a 97 110 TDI, Iíve yet to find ANYTHING on the 110 thatís expensive, relatively speaking
  3. The Following 5 Users Say Thank You to heyyahhey For This Useful Post:
    Palm Lakes Estate, Umhlali
    Thanked: 181
    Whoooo hoooo!
    Get a green one!
    Graeme
    2010 Puma 2.4 110
    2014 Kuga 2.0 D Titanium
    4X4 Forum1089 & AG0047
    Modderfontien, Jhb
    Thanked: 168
    Just do it.
    Truth, facts and logic should not be employed when buying old landies.
    Walter LR Extreme
    72 Air portable
    2008 BMW 1200 GS ADV
    2008 Ranger Supercab 3.0 tdci
    Wartburg
    Thanked: 3291
    Walter @ LRExtreme is the best of the best. I leave it to others on what’s expensive. I’ll say this:
    Owning 2 D4s and a 97 110 TDI, I’ve yet to find ANYTHING on the 110 that’s expensive, relatively speaking
    That
    The best mods I did were
    1. Block the recirculation water hole inside the radiator header - sorts cooling even in the hottest climate
    2. Fit a variable vane turbo, without changing the fuelling on the injector. It does not add to the op end, but increases low-end torque by a big margin, making slow rev off-road driving a pleasure.
    Edit: Add 3.: Installed Madman. It saved our bacon in Namibia after I had a new head fitted (engine was over 400k km old). Madman warned about water loss and high temp. We managed to limp home at 80km/hr, bleeding the system after every stop. Turned out that the cylinder head gasket was faulty with a pinprick hole seeping water/letting steam into the cooling system. Removing the thermostat and driving at lower water temps and lower throttle inputs prevented water loss and got us home. With a more modern engine, this would have necessitated a lowbed.
    Mike Lauterbach
  7. The Following 2 Users Say Thank You to mikeml For This Useful Post:
    Nov 2011
    Langebaanweg
    Thanked: 2225
    The most expensive parts on an 300Tdi Defender are the mods.
  9. The Following User Says Thank You to jfh For This Useful Post:
  10. #7
    Thanked: 481
    fit madman
    fit madman
    trf box temp , egt , oil pressure , water temp and level , boost pressure
    did I say madman - it will save you plenty plenty money and hassles - the madman makes it very reliable
    the gearbox company in randburg for gearbox , transfer box and diffs
    probably around 12k for a recon g/box or trf box if needed
    enjoy the rest
  11. #8
    Mokopane
    Thanked: 308
    The most expensive bit is probably fixing everyone else's mechanical shortcuts or discovering them when far from civilisation.
    That and doing the motor if it fails.
    Basic maintenance is surprisingly cheap, I realised this again when buying service parts recently.
  12. The Following User Says Thank You to antvz For This Useful Post:
  13. #9
    Nov 2011
    Langebaanweg
    Thanked: 2225
    Keep her standard and fit a Madman.
  14. #10
    Ruimsig
    Thanked: 35419
    Thanks chaps, great info.
  15. #11
    Nov 2011
    Langebaanweg
    Thanked: 2225
    The most expensive part I ever replaced on my 300Tdi was the steering box.
    It was +/-R20 000.
    They usually only leak, but mine had a collapsed bearing.
    But prices on the box's spares have dropped a lot.
    So I'm going to overhaul the old one.
    The other one is the alternator, which I will also overhaul.(rectifier diode failed)
    AMC heads are relatively cheap and injectors as well, compared to other vehicles.
    Finding a good one is the key, then service it with the best parts and oils you can afford.
  16. #12
    Nov 2011
    Langebaanweg
    Thanked: 2225
    Here's my 300Tdi's maintenance history.
    I do all the work myself and usually replace stuff long before really necessary.
    Attached Files Attached Files
  17. #13
    Mar 2015
    New Germany
    Thanked: 1312
    That
    i have a VNT and I adjusted the pump settings as more air need more fuel to get the best out of the VNT you donít have to do much but it much better if you adjust it, just make sure done with a EGT
    VNT peeks put at 1.6Bar and the 300TDi pulls now
    2005 Defender TD5
  18. The Following User Says Thank You to clivemd For This Useful Post:
  19. #14
    Thanked: 5610
    ^^^^^^^^ THIS!
    I would have the timing belt replaced before purchase, regardless of what the dealer says - timing belt goes = valves kiss pistons = you're in the brown and smelly stuff.
    And service her religiously every 10 000k's.
    Ettienne de Kock
    2000 Disco Td5
    1959 SII 88"
    197? RRC
  20. #15
    Mar 2015
    New Germany
    Thanked: 1312
    ^^^^^^^^ THIS!
    done 2 engines with cam belt went both times pistons were ok slight mark from valve, valves were still all good, was 3 to 5 rockers In pieces , the valves are vertical lucky so valves tend to survive and just rockers brake
    So yes best to get cam belt changed and set at the correct tension is very important, while at it also check the valve stem caps as they can wear through and end up in the sump, I check clearance once a year
    my 300 I do service every 5000km as engine is worked hard
    end of the day if looked after they are strong reliable engines and get very high mileage from them
    also change all oils R380, LT230, diffs, PS, brake fluid, radiator if get one, also grease the UJ’s regularly on props ppl tend to forget that and it critical for UJ life
    2005 Defender TD5
  21. The Following 2 Users Say Thank You to clivemd For This Useful Post:
  22. #16
    Thanked: 481
    I wonder if we shouldn't be pushing estee to look at the td5 defender / disco 2
    cause the lack of 300tdi power could make him moedeloos ?
  23. #17
    Mar 2015
    New Germany
    Thanked: 1312
    i have a 300 and TD5 and the 300 leaves my TD5 in black smoke on pull off and up hills, the TD5 like the 300 only come to life with a VGT
    hoping one day to get this for my TD5
ID:	652688   Click image for larger version.
    2005 Defender TD5
  24. The Following User Says Thank You to clivemd For This Useful Post:
  25. #18
    Mokopane
    Thanked: 308
    Reading all of the above, I'm excited already on Estee's behalf!
    However, a word of caution.
    The engine, together with related cooling system and lubrication system, are critical if you don't want to spend big bucks in the near future. I would:
    - verify when the head/head gasket was last changed; also the injectors
    - pull something (glow plugs?) and check with a borescope - for condition of bores, and for any burning/melting of piston tops etc
    - do a good compression check
    - confirm oil pressure (cold=3 bar, warm=2 bar at anything above idle)
    - confirm that water temp stays in low 90's during normal driving and doesn't go above about 95 on normal hills
    In my experience these engines work very well until they don't. This is great until you're the schlepp who buys the thing just before end-of-life. In most cases I suspect it's a gamble - could walk away with a beautiful example or a money pit.
    I love my 300 Tdi but getting it to where it is now was not for the faint of heart.
  26. The Following User Says Thank You to antvz For This Useful Post:
  27. #19
    Wartburg.
    Thanked: 889
    Morning all
    Just don't do it Sean.
    And if you do, we are not mates anymore. Because as a mate I will have to come push or pull you at some stage in the future, I'm not doing it.
    Toyota Land Cruiser 79 DC V8
    Toyota Land Cruiser 79 SC V8
    Toyota RAV-4 2.2 D4D
    ZS5CL
