Results 1 to 9 of 9
    Jul 2013
    JHB
    Thanked: 36
    Default Spare Wheel Lock
    Hi guys and girls
    Does anyone have a tips on a good Spare Wheel Lock that will fitt my Scorpio Suv s11?
    I know 4x4 Direct has a few but will they fit?
    Harties
    Thanked: 1509
    Default Re: Spare Wheel Lock
    Search this forum.
    There are many threads on this exact topic.
    If you need music in the bush or on the beach, you’re missing the point.
  3. The Following User Says Thank You to PRA For This Useful Post:
    Thanked: 362
    Have them check it out when you collect your DC battery components.
    Let us know, cos my spare just cost me a small fortune.
    Your mind is your strongest weapon.
    Then there's.....POWER TOOLS!
    2021 Mahindra Scorpio S11 SUV.
    '00 Frontier 280DT 4X2
    2002 Sprite Surfer Nomad
    '94 Cruiser 80 GX (Sold)
  5. The Following User Says Thank You to steamer For This Useful Post:
    Apr 2012
    Jhb and Rooiberg
    Thanked: 266
    I use a bicycle cable lock through the spare rim and around the chassis.
  7. The Following User Says Thank You to RonS For This Useful Post:
  8. #5
    Thanked: 362
    Fair enough. The Scorpio is going to need a small angle grinder to cut through the cable end if the shopper hasn't opened the rear door. so he can also cut the lock cable same time.
    I'd really like to see an affirmative dealer-proof lock.
  9. The Following User Says Thank You to steamer For This Useful Post:
  10. #6
    Jul 2013
    JHB
    Thanked: 36
    I see there is a true at the spare wheel holder that has a wheel nut so if its long enough to go through the A-Line rims i will get a lock nut set with 5 nuts to use for all wheels
ID:	649438   Click image for larger version.
  11. #7
    Thanked: 100
    I have seen YouTube clips of guys stealing spare wheels in a matter of seconds. How is this done? How is the chain cut above the tyre? I've looked at the mechanism that retracts the tyre up to the chassis and I just can't see how they steal it so quickly.
    2014 Toyota Hilux DC 4x4 3.0 D-4D Melville and Moon seat covers, Gobi-X rock-sliders, Maniac4x4 front bumper, Safari snorkel, Rhinocab canopy, 2" Tough Dog Suspension with 40mm Adjustable shocks, Maxxis RAZR AT811s, Gobi-X rear bumper.
    2005 WJ JEEP Grand Cherokee 2.7 CRD sold 2" Zone coil lift, Rancho 9000 shocks, 245/75/R16 Bighorn 764s, Rola cargo carrier, Escape Gear seat covers, Auto Technic "Bulli-Prop" DC propshaft, Maniac4x4 front bumper.
    BMW F30 320i M-Sport - daily drive
  12. #8
    Jul 2013
    JHB
    Thanked: 36
    My solution as we took off the old stud and welded a longer rod ont to the place and welded the original stud at the bottom so a 12 1.5 lock nut would fitt.
    Adding a bicycle wire lock 🔐 to.
ID:	649523   Click image for larger version.
  13. #9
    Jun 2021
    Tulisa park Johannesburg South
    Thanked: 7
    hi. I fit a bolt and lock nut next to the wheel winch. when you pull the wheel into position the bolt uses the rim hole. then I put double lock nuts on and tighten with socket and spanner. It take a while to get spare wheel of when needed. You have to go under the vehicle.
