Results 1 to 14 of 14
Thread: Welder Tripping
    Aug 2010
    Durban SA
    Thanked: 85
    Default Welder Tripping
    Quick one for the electricians. I have a very old school oil cooled welder which although old works well and does what I need it to do.
    The problem is my 20amp breaker in the garage keeps tripping if I try weld for more than 20sec at a time which makes for slow going.
    The breaker is supplied by 5 or 6mm cable can I up the breaker size and if so to what or am I at the limit of the supply and to a bigger upgrade.
    Aug 2010
    Durban SA
    Thanked: 85
    Default Re: Welder Tripping
    Picture of weber. I never go above medium on the sophisticated dial adapter Click image for larger version.
ID:	644899Click image for larger version.
    Aug 2020
    Big tree small tree
    Thanked: 10398
    I am sorry, but I can't resist.
    If your welder keeps on tripping, I'd suggest searching his pockets before he starts working.
    Oct 2012
    Roodeplaat
    Thanked: 206
    Those welders draw alot of amps,mine use to do the same,oil was low
    Maybe check your oil level also the transformer might be running hot
  5. The Following User Says Thank You to Werner Brits For This Useful Post:
    cape Town - 0624206806
    Thanked: 638
    Try a lower setting and see what happens.
    A slow trip (20 seconds of welding) could mean......
    you are drawing 19.9amps
    breaker is old/ faulty (the more it trips, the “older” it gets)
    The welder is packing up (only starts acting up when the internals warm up)
    Maybe it’s time for a new inverter type welder (depends how much welding you do..... running costs will be lower)
    As for changing the breaker (bigger) .... most houses in SA were wired with 1,5mm (lights), 4mm (plugs, geyser, stove)
    Theoretically, you can go up to a 30amp breaker on 4mm wire, but you should get a licensed sparky to check everything first.
  7. The Following User Says Thank You to GaryFrank For This Useful Post:
    potchefstroom
    Thanked: 129
    Ons het selde welder. Sy olie kan dalk laag wees. Of sit n grooter breaker op. Ek het 35 amp breaker opgesit. Trip die krag nie meer nie
    Jul 2020
    Thanked: 86
    Quote Originally Posted by warrenpfo View Post
    Input needed is 230v, with 30amps.
    20amp breaker will trip after a while. It will heat up and trip.
    4mm wire. 30 amp breaker.
    Or new inverter.
    F
    Paradise Beach
    Thanked: 91
    Quote Originally Posted by Fomo View Post
    Or new inverter.
    F
    To my knowledge you are not allowed to supply the standard socket outlet with a 30A circuit breaker.
    So, in addition, you will need to find a suitably rated socket outlet and then also change the plug on the welder
    Aug 2010
    Durban SA
    Thanked: 85
    Ok thanks guys. I will check out level in welder, get a sparky out to upgrade greater and add a suitable plug to both welder and socket. I think its those 3 pib blue campsite style plugs
    Aug 2019
    Thanked: 702
  13. The Following User Says Thank You to Tiaan Pot For This Useful Post:
  14. #11
    Aug 2019
    Thanked: 702
    Gary just FYI a 20A circuit breaker doesn trip at 20 A
    In fact a C curve CB wount even trip a constant 25A
    https://www.electricalclassroom.com/...b-trip-curves/
  15. #12
    Jan 2007
    Thanked: 65
    You would be better off spending R2k on an inverter welder.
    Will probably cost you less
    Agree
  16. #13
    King Williams Town
    Thanked: 2704
    My BIL lent me his oil cooled welder and it tripped if I welded too long. Then my dad gave his old Afrox air cooled welder. It's so quiet and draws far less than the oil cooled welder.
    To the OP, get sparky to run a new circuit to garage using 10mm Sq wire and a welding plug, although this exercise will cost more than an inverter welder, the choice is yours.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  17. #14
    Jan 2020
    Thanked: 386
    According to regulation if you install 25amp CB you need to have circuit breakers at each plug point on that circuit. I have am air cooled welder which I installed a 4x4 fan in it as it it used to trip the thermostat when it got hot. Have since bought an inverter welder that does duty when out and about. Far lighter than air cooled welder on power as well.
