Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 81 to 100 of 136
  1. #81
    Thanked: 121
    Default Re: Grand Cherokee 2015 petrol - Summit Version
    Jeep Changed TPMS in 2013, if you get a set of post 2013 rims with TPMS then you should be good on a 2015
  2. #82
    Dec 2014
    Thanked: 1612
    Quote Originally Posted by backmarker View Post
    Mine with 18" Wrangler Wheels and recently replaced the Scorpion At Plus with Goodyear Wrangler Kevlars
    265 65 18
    Attachment 691687
    100% the same on mine, same tire size too
    2012 Jeep Wrangler JKUR -- Sold (I'll be back )
    2015 Jeep Grand Cherokee Overland 5.7 Hemi
  3. The Following User Says Thank You to Alwyn777 For This Useful Post:
  4. #83
    Apr 2014
    Thanked: 11579
    Thanks.
    There is plenty clearance. Tire place put the thin balancing weights out of the way. The clearance between the rim and the brake caliber parts is actual quite a bit. I will have no issues.
    I had a choice of silver or black rims. I took black. They were cheaper. I have 5. 2nd hand but spotless. I am happy that I took these. On Sunday I see how tires work. Only 120 km of which 11 is on a sand road. I expect that it will be good.
    Nice!
    Not the deign of wheels I had in mind, they actually suite the vehicle very nicely!
    Clearance all ok?
    Jouko
    2015 Grand Cherokee Summit Petrol
    2012 Smart
    Never drive a normal car
  5. #84
    Apr 2014
    Thanked: 11579
    Thanks again to everybody who contributed on this project.
    Cost: Just under R19 k fitted for 4 tires on Jeep and 2 on caravan. I paid a bit premium by using BestDrive compared to the cheapest offer BUT they have done sensor/valve transfers. Jeep sends their vehicles there. It was a good service. If you do not have spare valve stems go to a place who has done the removal before.
    Company vehicle so small premium is nothing due to tax considerations. (Caravan is a mobile office)
    Jouko
    2012 Smart
  6. #85
    Apr 2014
    Thanked: 11579
    Some driven on main roads and also on sand. All good. Speedo was giving true speed. Now it seems to show 3km/h too high.
    Jouko
    2012 Smart
  7. #86
    Cape Town - RSA
    Thanked: 1270
    You can probably change the tyre size with OBD Jscan app and tool.
    2017 Venter Savuti + Tentco Jnr, Dometic CF50 Fridge + Ecoflow River Pro and 120W solar panel.
    Ex - 2005 Cherokee CRD
  8. The Following User Says Thank You to Quiksilver For This Useful Post:
  9. #87
    Apr 2014
    Thanked: 11579
    I did get 3 or 4 times error code P0016. Normally when there was rain or car wash. I thought it was wiring issue. Not so. Error is for: The correlation of the camshaft and crankshaft positions on bank 1 is incorrect based on the intake camshaft position sensor.
    I had it checked properly. Angles are not right. There is a method to train parts to behave. Did not work. Actually got worse. Power loss.
    Apparently what is causing the problem is the chain stretches. Job to replace is not that big job. Only issue is that before opening it is not possible to know if other parts are worn. There are two "kits" Chain only and Chain plus some other parts. Cost will be somewhat over R10 k. I should get Jeep back mid next week.
    I have to paint 2 bedroom flat I bought. Smart is able to take the tools, paint and even ladders plus 2 people
    In general Jeep works nicely. Open road and some town driving under 11 l/100km. Towing 4000 km average was under 15 l/100 km.
    Jouko
    2012 Smart
  10. #88
    Thanked: 1140
    Jouko what's your odo now? I drove my Rubicon to 170k and didn't have this problem
    Alfa Romeo Stelvio - Bellissimo!
    Grand Cherokee 5.7L V8 (sold)
    Alfa Romeo MiTo Quadrifoglio Verde (sold but still near to me)
    JKU Rubicon Pentastar (sold )
    JKU CRD (sold)
    XJ 4liter (sold )
  11. #89
    May 2013
    Thanked: 1467
    +1, I maintain a couple of 3.6 V6's with well north of 200k km on the clock and I've never heard of this.
    I have done the oil cooler fix on ALL of them, though.
    Current Fleet:
    Mercedes-Benz ML350 4Matic
    Mercedes-Benz B180 Auto
    VW Up!
    Ford Ranger 2.2TDCi Auto Supercab
    SWAMBO: 2020 Renault Koleos 2.5 Dynamique
  12. #90
    Apr 2014
    Thanked: 11579
    Just under 140 k. I am 3rd owner and 4th user. I was told that it happens mainly due to heat. I know that I have not over heated the engine. I keep checking temperatures. Towing on a hot day with uphills the highest oil temp I have seen just over 100 C.
    I drive old cars. I expect things to happen. I was a bit surprises with the chain issue.
    I will report when I get more info.
    Jouko
    2012 Smart
  13. #91
    Apr 2014
    Thanked: 11579
    I have extra radiator for the gearbox.
    What is this oil cooler fix? Is it the one between the V banks? What was done and what was rough cost?
    Quote Originally Posted by Kix View Post
    Jouko
    2012 Smart
  14. #92
    May 2013
    Thanked: 1467
    Quote Originally Posted by Jouko View Post
    Yes, the one in the V.
    The cooler + the oil sensor and water temp sensor is replaced. The whole job was R15k. Did the last one last week.
    Some of them leak oil into the V, some fail and mix oil and water. Some cause the car to overheat instantly. I've seen all 3 instances.
    The oil and water mayo is the worst, getting that system flushed and cleaned out is a pain.
    Current Fleet:
    VW Up!
  15. #93
    Apr 2014
    Thanked: 11579
    Is the replacement still the same design or is it different?
    I understand that originally that cooler was no good but it was improved. Which year?
    I do know about the issue but I get conflicting details on it. I have 2015 model. I have asked also the mechanic. Basically no good answer.
    Jouko
    2012 Smart
  16. #94
    May 2013
    Thanked: 1467
    The replacements are a different design as far as I know.
    I'm not sure which year it was changed.
    Current Fleet:
    VW Up!
  17. The Following User Says Thank You to Kix For This Useful Post:
  18. #95
    Apr 2014
    Thanked: 11579
    Possibly not. There is aluminum option:
    https://www.dormanproducts.com/p-135...xoC3IcQAvD_BwE
    https://www.amazon.com/Dorman-926-87...t?ie=UTF8&th=1
    Currently not available at Amazon. Price was about $200
    Worth to investigate this.
    Jouko
    2012 Smart
  19. #96
    Dec 2014
    Thanked: 1612
    The 'Muricans speak highly of the Dorman products
  20. #97
    Apr 2014
    Thanked: 11579
    I did get the car back yesterday. About R8500.00. Only chain replaced. There was a delay as a result of some wrong chain supplied. Was it ordered or supplied wrong I do not know. Car drives well.
    Forgot to ask about the cast oil cooler
    Jouko
    2012 Smart
  21. #98
    Thanked: 1140
    It's going to keep giving you trouble.... until you stop calling it a car..
    Sent from my SM-T725 using SA 4x4 Community Forum mobile app
    JKU CRD (sold)
    XJ 4liter (sold )
  22. #99
    Thanked: 121
    The Oil cooler on mine was swopped in 2018 by the dealer on a recall. You can call a Jeep dealership with the vin and ask them to check the recall and service history.. Just sold my WK2 after 220k kms. never had any engine issues...I was the third owner, put 80k kms on her.
  23. The Following User Says Thank You to backmarker For This Useful Post:
  24. #100
    Apr 2014
    Thanked: 11579
    Recalls and their status can be also checked here: https://www.mopar.com/chrysler/en-us...ls/search.html
    I did check this (again) and while doing it I did find out that I have been driving one year with a disk for SWAMBO's Suzuki.
    Jouko
    2012 Smart
