Results 1 to 15 of 15
    Gauteng
    Thanked: 114
    Default TD5 - No preventative maintenance goes unpunished!
    I have been going through my "new to me" Disco 2 TD5 since buying it - new rear coils, shocks, discs and pads. Front pads. New filters, grease props etc etc. Cleaning sensors per forum advise (thanks again!).
    Once I had gone through all the above (and got rid of the 3 amigos), I decided to look at some often negligent fluid changes - starting with coolant.
    Trying to do things properly, I read RAVE, watched Youtube, checked the forum before tackling the job etc. Some mentioned removing bottom radiator hose (without giving a reason), or if present, drain plug on coolant rail....
    On 1/4 turn of a 13mm ratchet wrench spanner (i.e. not a power bar or anything), drain plug mount broke clean off:
    Any ideas/suggestions? So far I am thinking I remove the coolant rail (busy with that - quite a mission) and get it welded back or is that a bad idea? Obviously critical it does not leak.
    New Germany
    Thanked: 2440
    Default Re: TD5 - No preventative maintainence goes unpunished!
    Does that plug go into a steal pipe, if so get it silver soldered back in
    2002 Defender with 300TDi VNT modified
    2005 Defender Soon to be powered by M57 3L straight 6 Diesel and 6HP Auto, Ashcroft lockers,HD CW&P, Xcess4X4, upgrade parts, HD side shafts & CV and prop-shafts, Pegged, 35” coppers STT pro ………..and more
    Jun 2019
    Knysna
    Thanked: 35
    I was told to remove the bottom hose because the drain plugs break. One thing though - you cannot get all the fluid out. I forget the coolant capacity off the top of my head (7,3 litres?), but upon refill with new coolant, it only took around 5 litres.
    May 2014
    B-gowrie Randburg
    Thanked: 886
    Silvertons are guys to fix it ,
    … but not sure if theres one near you ?
    (could clean radiator at same time,
    Airckean fins & descale, check pipes etc)
    2002 Defender 130 DC HCPU. :
    Own the road... Any road ...
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8 :
    The Greatest Rover.
    ‘1975 Series3 88 PUP :
    Simply ... Classic ...
    ‘2017 Metalian Mini ...
    A Home from Home
    Gauteng
    Thanked: 114
    Thanks for all the advice everyone - sorted by Silverton Radiators, Germiston - R200 to repair (just blocked the hole entirely) and pressured test whilst I waited (I believe they silver soldered/brazed it).
    I did measure the coolant I removed, from the drain plug it was 8 litres.
    Thanks again for everyone's input!
    My next challenge is I noticed the thermostat is original (2001) once I cleaned it (very cool they stamp the manufacture date on it). I believe I should get an OEM Thermostat? Does this mean from the dealer only?
    May 2014
    B-gowrie Randburg
    Thanked: 886
    … get OEM for key/critical parts etc
    but first try via Dover Spares in Selby
    before going to LR agents who usually charge
    the earth.
    The Greatest Rover.
    A Home from Home
    Dec 2021
    in between due to job
    Thanked: 134
    Default Re: TD5 - No preventative maintenance goes unpunished!
    Is ek reg om te s๊ die td5 is n bullet proof engine, die een om voor te gaan as mens n landy koop?
    Mar 2016
    Thanked: 7093
    Quote Originally Posted by Richarddom View Post
    Praat met Reenen oor dit
    Andr้ Opperman
    Dec 2021
    Thanked: 134
    Quote Originally Posted by Oppies3800 View Post
    Hy s๊ bly weg van disco 3 en 4
    Thanked: 5343
    Ja, maar nee....
    Dit hang af van hoe goed die vorige eienaars die onderhoud gedoen het EN hoe hulle gery het.
    As die olie ruilings gereeld gedoen is en met die regte olie en filters, en as al die nodige goedjies in ag geneem is, dan het jy n goeie enjin, MAAR as dit hard gery is en sonder enige soort van sorg behandel is, dan gaan hy op n punt gaan staan....selfde as enige ander masjien wat mishandel is...
    John Kilfoil
    Rover P6
    Land Rover Discovery II V8 Manual
    Moto Guzzi LeMans
    Aprilia Tuono V2
    The greatest enemy of knowledge is not ignorance, it is the illusion of knowledge.
    Stephen Hawking
    Dec 2021
    Thanked: 134
    Injectors? Is dit n issue?
    Hoe bewaar of breek mens dit?
    Is n 110 sc bakkie met td5 n opsie?
    Weskus van Namibia
    Thanked: 359
    My TD5 was vol probleme, maar nie die motor self nie. My probleme was airbags, olie koeler, hoses, turbo, ratkas, ABS module, alternator ens, maar nooit die motor nie. Bietjie pap, maar betroubaar met gereelde onderhoud
    My speelding: 2012 VW Amarok 2.0 TDI
    Richards Bay
    Thanked: 227
    Quote Originally Posted by kevin4x4 View Post
    For spares I can highly recommend LP4A in midrand.Fantastic service and advise
    1987 Land Rover 110 - 300tdi conversion
    2000 Discovery 2 TD5 auto - local run around
    It's always more fun on the road less travelled
  14. The Following User Says Thank You to iLandy For This Useful Post:
  15. #14
    Mar 2014
    Meyersdal Alberton
    Thanked: 600
    Vra vir die 80 grade thermostat. Ry met bruin asyn in die sisteem vir n paar dae. En sit oat antifreeze in as jy die asyn uit het
    Four wheels move the body,
    Landys move the soul.
    0817360284
    Current: Jeep Wrangler YJ 2.5. Disco td5 auto
    Next landy, D3 V8 HSE Previous one.Disco 3 tdv6. Disco 2 td5. D1 v8i D1 300 TDi donkey, D1 V8 Fuel THIEF!!! freelander 1, biggest pos known to man,
  16. #15
    Thanked: 5343
    Verskoon my as ek in Engels beantwoord....
    The Td5 injectors are very different to "normal" injectors because they use the camshaft to pressurise the main injection dose and they are pretty complex items as such.
    The ECU has coding for the injectors that are calibrated at manufacture and given an Alphanumeric code that is printed on the top of the injector. This code needs to be programmed into the ECU to ensure optimum firing of the injectors, and thus best efficiency of the engine.
    If you strip a head and refit the injectors, they MUST go back in the same cylinder to preserve the programming.
    As with others, they need very clean fuel and particularly the tiny little strainer that goes under the fuel pressure regulator housing into the head, as it's your "last chance" filter.
    It looks like this...
    but is a LOT smaller than depicted.
    The injectors are no longer made, and very few people can repair them properly, so they are pricey, but they are fundamentally sound units if the system is correctly maintained.
    John Kilfoil
    Rover P6
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Stephen Hawking
