D2 long range tank
Results 1 to 5 of 5
    Dec 2014
    Thanked: 3668
    Default D2 long range tank
    What could I expect to pay to have the under fender tank made and fitted to my D2?
    Stainless or Mild Steel.
    Cheers,
    John Kilfoil
    'People who believe the vaccination will alter their DNA should probably consider it an opportunity"
    Rover P6
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 421
    Default Re: D2 long range tank
    Had them in both my D2's , both gave issues with airlocks.. they were frontrunner.
    not sure if there is anything better out there, but it was hell annoying.
    Defender 130
    Defender 90
  3. The Following User Says Thank You to D-tox For This Useful Post:
    Dec 2014
    Thanked: 3668
    Quote Originally Posted by D-tox View Post
    Interesting... The breather tube is 20mm diameter, so unless they bodged the installation, I can't see why they'd lock.
    Certainly if they never connected the breather tube into the tank it'd back up in no time flat and cause major issues, not to mention the loss of a lot of the extra capacity of the tank.
    Cheers,
    John Kilfoil
    Rover P6
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 357
    Not the same vehicle but on my mates def kalahari
    both sides tanks under / in the wheel well
    I think 40ltrs each
    It took so long to fill that a rule was made that we checked if they were full before we left home or he stayed back
    Separate fill points either side
    Mar 2014
    Brakpan
    Thanked: 544
    Had one in my d2 td5. Fitted it myself. No problems. No airlocks.
    Four wheels move the body,
    Landys move the soul.
    0735236742
    Current: Discovery 2 td5.
