Wrangler 4dr JKU Underbody Rust
Results 1 to 4 of 4
    Apr 2021
    Default JKU Underbody Rust
    Hi All,
    I have been a long time lurker of the forums and soaking up all the info. Swambo and I have finally gotten the opportunity to dip our toes into the 4x4 world after years of dreaming and planning.
    I have my eyes on a 2018 JKU with only 30 000 km on it however it is based at the coast and seems to have some rust on the underbody. I would very much appreciate any input on the attached images, is there any cause for concern with this vehicle that I should be aware of?. To my eye it seems mostly like surface rust and should be able to be treated with some rust converter or similar?. Otherwise the vehicle runs perfectly in all other respects.
    I really appreciate all the assistance and look forward to finally being able to participate more actively in the forums!.
    Thank you,
    Ashton
ID:	639161   Click image for larger version.
ID:	639162   Click image for larger version.
ID:	639163   Click image for larger version.
ID:	639164   Click image for larger version.
    Jan 2017
    Gauteng
    Thanked: 12
    Default Re: JKU Underbody Rust
    Seems pretty normal to me and I live up on the Highveld (JHB)
    My 2012 however seems way better than that only because I take care of it from time to time.
    I wash my under-carriage from time to time with Prepsol engine cleaner and rinse with hot geyser water. Later on I would give it a coat of Q20 or WD40 and let it sit for a week or two. The 3rd week another prepsol and hot water, let it dry, take off the wheels and spray the chassis with a can of Rust-O-leum Satin black spray. You really only give it a light coat wherever you deem necessary. You can repeat it every 6 months or so whenever you get bored.
  3. The Following User Says Thank You to Ray v.Beveren For This Useful Post:
    Thanked: 123
    Photo no. 2 looks like there is a coolant leak, I will check that out before buying.
    Could just be the thermostat housing but have it fixed before you buy.
    Zone Built JEEP 018
    ORRA AG42
    2013 Jeep JK Rubicon
  5. The Following User Says Thank You to Jeepanator For This Useful Post:
    Apr 2021
    Quote Originally Posted by Jeepanator View Post
    Thank you but I believe it it was a few drops from the coolant tank cap when it was opened to inspect.
  7. The Following User Says Thank You to sa80 For This Useful Post:
