Cadac 2 Cook 2 Pro Deluxe Packing
Results 1 to 20 of 26
    Aug 2015
    Thanked: 203
    Default Cadac 2 Cook 2 Pro Deluxe Packing
    How do you guys who own the Cadac 2 Cook 2 Pro pack the unit?
    Do you keep the hose pipe and regulator attached to the unit when putting it in the supplied bag? The manual does not seem to say much!
    Oct 2017
    Rustenburg
    Thanked: 10301
    Default Re: Cadac 2 Cook 2 Pro Deluxe Packing
    I take mine off and roll it up, and place it under the unit in the bag
    Andrew van Staden
    2021 FJ Cruiser and a trailer
    Ex:
    Ranger 3.2, LC 76 V8, Navara 2.5, NP300, Patrol 4.8, Everest 3.0, Jimny 1.3, Defender 110 SW Puma
    Aug 2015
    Thanked: 203
    How do you take it off so easily? Don't you use the supplied hose clip? Do I every time have to unscrew the hose clip when packing, and then screw it tight when using.
    Tshwanetoria
    Thanked: 1571
    I actually cut an opening in the side of the base and can now store the hose underneath the burners, without causing a bulge. (I hope this is clear enough?) I know I may void the warranty, but was willing to take the chance.
    I also made two wind shields, using some alu chequer plate and gluing coin sized magnets to it so that I can stick the shields to the sides of the stove.
    I will try to remember to post phodies.
  5. The Following 2 Users Say Thank You to hatjohan For This Useful Post:
    Aug 2015
    Thanked: 203
    Some great ideas, thank you. Clear enough, but nothing beats photos lol.
  7. The Following User Says Thank You to Teryos For This Useful Post:
    Oct 2017
    Rustenburg
    Thanked: 10301
    Quote Originally Posted by Teryos View Post
    It unscrews but it has a reverse thread
    The red flowery joint thingy
    Andrew van Staden
    Ex:
  9. The Following User Says Thank You to Hedgehog For This Useful Post:
  10. #7
    Oct 2017
    Rustenburg
    Thanked: 10301
    I値l take some pics in the evening
    Andrew van Staden
    Ex:
  11. The Following User Says Thank You to Hedgehog For This Useful Post:
  12. #8
    benoni
    Thanked: 20
    Would love to see photos also
    Ps there is a coupler that you can use with a Male and Female fitting that you can connect and disconnect the pipe
    I知 not sure if I知 describing it properly
    Sorry for that.
    It痴 made of brass
    I値l try get a photo of it from my friend who used it so you can see it
  13. #9
    benoni
    Thanked: 20
    This is the connection he made to connect two of his portable gas braai痴 to a single gas tank or he can configure it to use just for one appliance. The coupling to the gas Braai can also be screwed on and off so the pipe is not attached and cans be removed when traveling or packing
  14. The Following 2 Users Say Thank You to delwynv For This Useful Post:
  15. #10
    Oct 2017
    Rustenburg
    Thanked: 10301
    So sorry for not getting back to you, but it slipped my mind.
    I have added a reminder now, and will get back to you this evening
    Andrew van Staden
    Ex:
  16. The Following User Says Thank You to Hedgehog For This Useful Post:
  17. #11
    Thanked: 1340
    We just put it n its case as is >> and paclk away carefully in Vehicle or Trailer Drawer system for travel >> works a dream >>
  18. #12
    Tshwanetoria
    Thanked: 1571
    Phodies. Click image for larger version.
ID:	638788Click image for larger version.
ID:	638789Click image for larger version.
ID:	638790Click image for larger version.
ID:	638791Click image for larger version.
ID:	638792Click image for larger version.
ID:	638793Click image for larger version.
ID:	638794Click image for larger version.
ID:	638795Click image for larger version.
  19. The Following 3 Users Say Thank You to hatjohan For This Useful Post:
  20. #13
    Tshwanetoria
    Thanked: 1571
    I use the original bag, to contain the two solid plates, within a Tentco bag. Perfwct fit, prevents rattles and protects the stove and solid plates. Ideal for the corrugated Kgalagadi roads
  21. #14
    Bellville / Weskus
    Thanked: 70
    Quick connect fitting on the gas hose.
    If I had to screw in the regulator every time I would rather use my small gas cannister stove.
    https://youtu.be/E9wc4TgllhY
  22. The Following User Says Thank You to dumbluck For This Useful Post:
  23. #15
    Aug 2015
    Thanked: 203
    I am planning the same Tentco bag.
    Otherwise, clever simple idea of cutting the plastic to avoid the bulge. And that cover around the regulator is a must.
    Thank you.
  24. #16
    Tshwanetoria
    Thanked: 1571
    Thank you.
    Sommer an old sock. They are quite handy
  25. #17
    Oct 2017
    Rustenburg
    Thanked: 10301
    Mine has this connection
    Just screws off (albeit reverse thread)
    Then I just put in there with some cardboard to eliminate rattles
    Andrew van Staden
    Ex:
  26. #18
    Aug 2015
    Thanked: 203
    Interesting. Where do you get such hose connector?
  27. #19
    Aug 2015
    Thanked: 203
    Lol thought so. I idea came in my mind too, now I am inspired lol
  28. #20
    Oct 2017
    Rustenburg
    Thanked: 10301
    It came with it, when I bought it
    Andrew van Staden
    Ex:
