Puncture repairs
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 60
    Jun 2008
    pmb
    Thanked: 16
    Default Puncture repairs
    Never had a puncture to repair in the bush! I have all the kit. Had it for years. How long do the glues, patches and hole bungs last for?
    Kevin and Michelle Heyes
    [/SIGPIC]
    www.kevinandmichelle.co.uk
    Ellisras
    Thanked: 1555
    Default Re: Puncture repairs
    Maybe just my bad luck bit the 2 I did on a set of Duelers some years back lasted only a couple of weeks before they started leaking slowly
    2014 Patrol GU 3.0CRD "teenager" in puberty - 138 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" - 131 000 km
    krugersdorp
    Thanked: 725
    mine always lasted tire life.never had any issue.
    i'm prone to punctures.
  4. The Following User Says Thank You to jadranko For This Useful Post:
    May 2016
    Thanked: 5282
    The glue dries out, even in a unopened tube.
    I would inspect and replace as required.
    Maybe all the "soft" items (glue, patches an snot sticks).
    2006 VW Touareg V10 (Sold)
  6. The Following User Says Thank You to 4ePajero For This Useful Post:
    King Williams Town
    Thanked: 2476
    I tossed out the small glue tubes in the kit and bought a bigger tube. Secret to repairing a puncture with those snot plugs is to ream hole,add glue to ream tool and re ream,add glue on snot plug. Insert and cut off any excess,then take hammer and hit around and in snot plug to get tyre to close up hole( I was told to do this as it shocks the tyres memory back into play to close the hole thus squeezing against the plug)....no idea if the hammer idea works but it looks good when being watched,
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  8. The Following 5 Users Say Thank You to hunter26 For This Useful Post:
  9. #6
    Thanked: 2391
    Installed, they last for many years. The solution in the tube dries after a while.
  10. #7
    Mar 2007
    Harties Boet
    Thanked: 2180
    Just on this.
    If its the kit with the plastic handles please throw it away or burn it asap! Those plastic handles break when youre putting all you force on them pushing the shaft through the tyre, and it then goes straight through your hand.
    Get the metal handled ones!
    Graham Robertson
    Nissan Patrol 4.8
  11. The Following 10 Users Say Thank You to Graham For This Useful Post:
  12. #8
    Melkbosstrand Cape Town
    Thanked: 155
    Just on this.
    Agree 100 % those plastic ones are absolute rubbish , ditch them and buy the proper ones , also buy the bigger tube of rubber cement , I find the last much longer the the small tubes.
  13. #9
    Jan 2020
    Thanked: 296
    Wrote a piece in a 4x4 mag couple of years back and won an iron man repair kit. Added a couple of snot plugs to kit. Have replace glue on regular basis others haven't had a problem with them loosing air yet.
  14. #10
    King Williams Town
    Thanked: 2476
    The secret to installing a snot plug ,besides glue ,is to insert plug with ample glue then twist handle and pull out. This causes the plug in tyre to form a type of mushroom inside. Just a hint I was told.
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
  15. The Following 7 Users Say Thank You to hunter26 For This Useful Post:
  16. #11
    Aug 2010
    Thanked: 62
    Just for info
    Plugs are a temporary repair only, and are intended to get you only to the nearest repair facility where a proper internal inspection and repair can be done. SANS 10408 Puncture Repairs.
  17. The Following 2 Users Say Thank You to hedjudd For This Useful Post:
  18. #12
    Oct 2017
    Rustenburg
    Thanked: 10279
    Quote Originally Posted by hedjudd View Post
    Just for info
    Ermmmm...... Thanks.. Good to know that this what I must do if I have shop that fixes tyres.
    Andrew van Staden
    2021 FJ Cruiser and a trailer
    Ex:
    Ranger 3.2, LC 76 V8, Navara 2.5, NP300, Patrol 4.8, Everest 3.0, Jimny 1.3, Defender 110 SW Puma
  19. The Following User Says Thank You to Hedgehog For This Useful Post:
    JJJ
  20. #13
    May 2013
    Thanked: 24
    Where could I find the ones with metal handles.
    I have only seen the ones with plastic handles.
    What glue do you use with the plugs?
    I use a tube of ordinary contact adhesive. Is that fine?
  21. #14
    Thanked: 643
    Dont take anything I say as actual advice or fact. I dont.
    Haval H9 2.0T AWD
    Ex 2019 Ranger DC XLT Manual 4x4
    Ex 2017 Ranger DC XL Auto 4x4
  22. The Following User Says Thank You to PsyPhin For This Useful Post:
  23. #15
    Polokwane
    Thanked: 1506
    Quote Originally Posted by Muhammad View Post
    You can find it all here https://4x4direct.co.za/513-tyre-care
    Conqueror Courage 2016
  24. The Following User Says Thank You to DC Polokwane For This Useful Post:
  25. #16
    Apr 2017
    PUMULA KZN & {near} MORGAN BAY EC
    Thanked: 482
    I have several vehicles with kits.
    I have found-
    -They donít last more than a few years and once the seal is broken, they don't last very long at all. Even with the seal intact they go hard - replace every few years. Keep the old one in the kit and use first if hard you have the newer tube.
    -A big tube is next to useless as once the seal is broken it hardens fairly quickly, before you get a chance to use the full tube.
    -A tube in a cool garage lasts longer, than in a hot car. With the farm, once I have broken the seal of a bigger tube, I put it in the garage where I do most of the plugging.
    -I have found the smaller tubes last longer and cost effective, better to have a few smaller tubes than one bigger one that hardens quickly once the seal is broken.
    Not just for gluing in placeÖ. One of the jobs of the glue is lubrication to get the plug in easier and for the tyre around the plug to settle around the plug to seal, as plugs are meant to be temporary if you are stuck with a hard tube of glue and canít get the plug in - at the last resort -water or even spit will work, this will help you to get to a tyre place, to do a more permanent repair. On the farm many of my plugs have become permanent and I used water and they have not slipped out or leaked.
    And yes the plastic handles get hard and brittle and can break, ALWAYS use leather glove when pushing in the plug.
    Those cheap kits are not worth the money spent.
    GOOD tip with twisting the plug before plulling out the insert tool, also jeaking the tool out helps.
    Current off-road vehicles: *** Great family accommodation. See Facebook, Google maps and airbnb. Mkulu Kei at Wild Wind Ranch
    * 1975/8 SHREK LAND-CRUISER FJ40 DIESEL P/U, BFG 31x10.5 muds. 1.6 ton tirfor winchs
    * 1994 LAND-CRUISER J70 DIESEL P/U, my truck recovery vehicle. 15000 warn winch. And 3.5ton tirfor winch. Back full of appropriate sized recovery gear. BFG31x10.5 muds
    * 2014 LAND-CRUISER LX V8 76 DIESEL STATION WAGON, BFG's 285 all terrain.
    * 2011 HILUX 4X4 P/U, BFG 31x10.5 all terrain
    * 1999 PAJERO 3.5 V6 Mitsubishi (sorry not a Toyota), BFG 31x10.5 all terrain
    * 2006 FORD ranger 2.5 diesel. 4x4, (what was I thinking, also not a Toyota!) I have a spare 5000 warn winch I might fit.
    * 2011 ISUZU bakkie 4x4
    * MERCEDES UNIMOG U416.
    * FIONA - Rhino Yamaha 660 4x4. Warn winch. Mud tyres
    * 4x4 trailer, 1987, BFG all terrain
    * GSA 1200 BMW ADVENTURE LC 2018, the closest motorbike to a land cruiser. And a Honda 200
    * A Massey Fergusson 375 tractor. And a John Deere E140 2020 tractor
  26. The Following 4 Users Say Thank You to K-9 For This Useful Post:
  27. #17
    Garsfontein
    Thanked: 3984
    Quote Originally Posted by K-9 View Post
    And yes the plastic handles get hard and brittle and can break, NEVER USE A REAMER / SNOT PLUG FITMENT THINGY WITH PLASTIC HANDLES
    Fixed it for you. A leather glove is not going to stop the shank going through someone's hand if the handle breaks.
    Ian de Villiers
    Nissan Patrol GRX 4.5
    Rainier Vermaak: And in Ian we have a resident cacafuego...
  28. #18
    Apr 2017
    Thanked: 482
    Will not stop it completely, agree with you but - but a good leather glove will reduce the damage to the hand significancy.
    I have thrown out all my plastic handed ones, they are dangerous. Even my bikes have the heavy duty metal plug insert tools, not worth the risk. The reamers don't need the hard pushing like the plug inserts, but i chucked them out as well.
    The last thing you need is a spiked hand on a 4x4 trip.
  29. The Following 3 Users Say Thank You to K-9 For This Useful Post:
  30. #19
    Apr 2017
    Thanked: 482
    Ordinary glue works as a lubricant to get the plug in, but will not stick to the rubber for long.
    I bought 14 of the heavy duty insert tools, a few years ago, very, very cheap, i need need a few more. They are/where a dealer supplier, as a retailer they let me buy. But they don't turn anyone away- Accessories Spares Centre (Pty) Ltd, 17 travertine cres, Briardene Durban north
  31. The Following 3 Users Say Thank You to K-9 For This Useful Post:
  32. #20
    Thanked: 3948
    To answer the OP's question, which is how long do the UNUSED components last - I don't have a definitive answer, but I buy new ones for every major trip, and keep the previous trip's bits and bobs as reserves. The glue, snot plugs etc are cheap and not worth taking a chance on. Heat and humidity obviously play a role in speeding up deterioration.
    And yes, metal handles only for the tools.
    Tony Weaver
    2010 Mitsubishi Pajero Sport 3.2l diesel
    Previously
    1991 Land Rover 110 Hi-Line 3.5l V8; 1968 2.25l Land Rover SII; 1969 2.6l SIIA; 1973 2.25l SIII
    1983 Toyota HiLux 2l 4x4
  33. The Following User Says Thank You to Tony Weaver For This Useful Post:
