Freelander 2 Fan Control Module
Results 1 to 4 of 4
    Jul 2015
    pretoria
    Default Freelander 2 Fan Control Module
    Hi All,
    I have a 2013 Freelander 2 SD4 - my Radiator Cooling Fan wont shut off, I had to disconnect the battery to stop it.
    After some research I found out that this is a relatively common issue and that it is normally just the Fan Controller Unit that needs to be replaced.
    Anybody here with a similar experience?
    Also do you know where to source just the fan controller unit? You have to buy the entire unit from landrover otherwise which is close to R20K.
    And am I correct in thinking I can replace this controller unit myself? this look like basically just one screw and unplugging the old one and plugging in the new one.
    Jul 2016
    Thanked: 672
    Default Re: Freelander 2 Fan Control Module
    you can buy the module from LP4A or Waldo @ WLR spares
    Jul 2015
    pretoria
    Quote Originally Posted by MikeBob View Post
    Thank you. Waldo has them in stock and will send one to me tomorrow. :-)
  4. The Following User Says Thank You to werner77 For This Useful Post:
    Aug 2020
    Magoebaskloof
    Same problem here, the small fan wont stop. I've just unplugged the fan in question and the bigger one kicks-in and out as expected.
    Is there a risk driving like this? Waldo is only back at his shop next week 10 Jan.
