Marshmallows | Malvalekkers | Camping treats
Results 1 to 20 of 27
    Sep 2019
    Pretoria East
    Thanked: 2771
    Default Marshmallows | Malvalekkers | Camping treats
    Be warned, once you have tasted a fresh marshmallow you will instantly become a marshmallow snob as you realize for the first time how stale the ones in the shops actually are. Luckily they are very easy to make.
    I have waffled on in the technicalities of baking thread regarding the tricky bits if you want to go and have a look there for more information.
    The attachment is a photo how-to that should help you know what it looks like at each stage. Have fun!
    MARSHMALLOWS
    50g gelatin (powder) 80ml
    100ml water for the gelatine
    625ml water for the sugar syrup
    800g sugar (4 cups)
    5ml vanilla extract
    1. Add the gelatin to 100ml water.
    Try to scatter it evenly rather than clumping in a heap.
    2. Heat the sugar and the 625ml water in a thick bottomed pot. Stir continuously until the sugar is dissolved. Bring to the boil over medium heat. Let it simmer until the temperature reaches 118°C.
    3. Remove from the heat immediately and pour the hot sugar syrup down the side of the bowl of the mixer.
    4. Start slow and ensure the gelatin is incorporated fully in the sugar before increasing the speed.
    5. Whip on medium high until thick and glossy. You will wonder if this is it and then suddenly it will thicken. You won't wonder anymore.
    6. You have to work fast at this point as it will want to set fast. Scrape it out of the bowl into your oiled pan/ glass serving dish or prepared surface.
    Shape it into a slab as best you can. Wet your hands in hot water to moisten the top and smooth it out. I also tidy up the sides if it's not in a pan.
    7. Leave it to set for 4 hours or even overnight.
    8. Prepare a mixture of half icing sugar and half cornstarch or rice flour to cover the surfaces of the marshmallow with.
    9. Remove the slab from the pan and cut it in strips. Cut each strip into cubes. Cover the surfaces of each marshmallow with the icing mixture.
    10. Store in an airtight container.
    I have no idea how long they last. I have never managed to keep the hordes away long enough to find out.
    Aristotle wrote; ''Excellence is never an accident. It is always the result of high intention, sincere effort, and intelligent execution. It represents the wise choice of many alternatives. Choice, not chance, determines your destiny''
  2. The Following 3 Users Say Thank You to Emmie L For This Useful Post:
    Jun 2016
    Randfontein
    Thanked: 6779
    Default Re: Marshmallows | Malvalekkers | Camping treats
    Dink ons moet smorrs met tuisgemaakde Marshmallows maak.
    Willie Knoetze
    2019 Nissan NP300 2.5tdi d/c 4x4
  4. The Following User Says Thank You to FWM For This Useful Post:
  5. #3
    Sep 2019
    Pretoria East
    Thanked: 2771
    If I am going to put the marshmallows into the fireplace or over the braai fire I often cut them into longer thinner marshmallows so that they don't slide off the stick too easily.
  6. The Following User Says Thank You to Emmie L For This Useful Post:
  7. #4
    Hillcrest
    Thanked: 11404
    Dear Emmie,
    I have reasonable kitchen skills and have for a long time been looking for a Marshmallow Recipe.
    I have also been sitting on Forum Post # 19 999 for a while, looking for the ideal post to break my forum hymen.
    Thank you so much for the effort. I am sitting in Centurion right now, but promise to "give it a go" when I get back home to my kitchen.
    For what it is worth - you get the honour of Post # 20 000
    ZS5KAD - PROFFESIONAL DUMBASS
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
  8. The Following 4 Users Say Thank You to Fluffy For This Useful Post:
  9. #5
    Sep 2019
    Pretoria East
    Thanked: 2771
    Congratulations Keith. That is a lot of words. And what better spend them on than something delicious.
    This is a very forgiving recipe. It takes colouring and flavoring quite well.
    It's really easy. Bloom the gelatin. Boil the sugar syrup. Transfer to the mixer. Transfer to the setting up spot. Cut and powder. Done. Simple.
    I also sometimes make it a bit softer, put it in a piping bag with a plain but widish nozzle and pipe worms. Cut the worms in short, even pieces and voila, mini marshmallows. But become used to the process before you go there.
  10. #6
    Hillcrest
    Thanked: 11404
    Quote Originally Posted by Emmie L View Post
    Just when I thought it was simple you go and complicate things.
    3 Land Rover V8's
  11. The Following User Says Thank You to Fluffy For This Useful Post:
  12. #7
    Sep 2019
    Pretoria East
    Thanked: 2771
    More intricate play in case you get bored with how easy it is.
  13. #8
    Sep 2019
    Pretoria East
    Thanked: 2771
    One thing I forgot to mention. When removing it from the mixer, don't try to scrape off every bit. The slab will set while you are struggling.
    Just do a quick scrape or two then deal with the slab. If you have a kitchen assistant let them struggle to get it out of the whisk attachment while you deal with the slab.
  14. #9
    Hillcrest
    Thanked: 11404
    Let the fun begin.
    Pics to follow today.
    I love learning new skills.
    3 Land Rover V8's
  15. The Following User Says Thank You to Fluffy For This Useful Post:
  16. #10
    Sep 2019
    Pretoria East
    Thanked: 2771
    Whoop whoop.
  17. The Following User Says Thank You to Emmie L For This Useful Post:
  18. #11
    Hillcrest
    Thanked: 11404
    And so it came to pass.
    My icing sugar turned out to be castor sugar.
    My baking tray isn’t as big as I thought it was.
    And 8 cups of sugar is a lot of sugar, especially for a household that only keeps a little bit of sugar in the larder for when the Vicar pops around for tea.
    Tomorrow is nog n dag.
    3 Land Rover V8's
  19. #12
    Sep 2019
    Pretoria East
    Thanked: 2771
    Hee hee. So it goes. Enjoy shopping tomorrow.
    You will be amazed how fast the marshmallows disappear. I have never once struggled to get rid of them after the first taste.
    It's the hinting at when you are making them again that gets to you.
  20. The Following User Says Thank You to Emmie L For This Useful Post:
  21. #13
    Hillcrest
    Thanked: 11404
    You mentioned making them straight on your marble slab. How do you contain them to a rectangle.
    3 Land Rover V8's
  22. The Following User Says Thank You to Fluffy For This Useful Post:
  23. #14
    Hillcrest
    Thanked: 11404
    Have you done toasted coconut, they are my favourite.
    3 Land Rover V8's
  24. The Following 2 Users Say Thank You to Fluffy For This Useful Post:
  25. #15
    Sep 2019
    Pretoria East
    Thanked: 2771
    It sets as I'm taking it out the mixer. I'm shlopping it out and shaping it with my wet hands to the height I want it to be. Then I just tidy the edges as if I took it from a pan. You have to trim off the edges anyway when you cut them, so it's not really an issue.
    And it gives you something to feed the eager beavers while you are cutting.
    It's thick and barely oozes, so it doesn't run all over the places. I have to use the spatula to help make the rectangle.
    If it's creeping all over you took it off slightly earlier than I did. It will still set, it will just be messier until it does and better off in a glass dish as it might end up thinner and therefore smaller cubes.
    I initially did it in a pan until I realized that I can achieve the same thing without. It's my aversion to struggling things out of pans that made me use the slab. You can stick to a pyrex dish initially.
  26. The Following User Says Thank You to Emmie L For This Useful Post:
  27. #16
    Sep 2019
    Pretoria East
    Thanked: 2771
    Yes I have. Toasted coconut was my gran's favourite too.
    Make sure you have at least 200g of toasted coconut before you go shopping.
    During the cutting step instead of rolling the marshmallows in the icing/ rice flour mixture, roll them in the coconut instead.
  28. The Following User Says Thank You to Emmie L For This Useful Post:
  29. #17
    Sep 2019
    Pretoria East
    Thanked: 2771
    It would look something like this. Except I don't know why they are so thin. Normally I make them thicker than this. Click image for larger version.
  30. The Following User Says Thank You to Emmie L For This Useful Post:
  31. #18
    Hillcrest
    Thanked: 11404
    Let the fun begin - again.
    And the secret is out - the worlds best amateur mixer. Proper mixer for baking and food prep.
    3 Land Rover V8's
  32. The Following User Says Thank You to Fluffy For This Useful Post:
  33. #19
    Hillcrest
    Thanked: 11404
    Assembly of some of the stuff.
    Anybody notice something special in the baking tray.
ID:	638450   Click image for larger version.
    3 Land Rover V8's
  34. The Following User Says Thank You to Fluffy For This Useful Post:
  35. #20
    Hillcrest
    Thanked: 11404
    OoohKaaay,
    So right now I think I may be looking at the words biggest Jelly Baby
    3 Land Rover V8's
  36. The Following User Says Thank You to Fluffy For This Useful Post:
