Results 1 to 20 of 23
    Thanked: 13
    Default Generator fuel consumption?
    Hi guys.
    Can anyone give me an idea of how much fuel a 50 Kva genny will use per hour ?
    Would a 100 Kva use twice the fuel ?
    Thanks in advance.
    Gaborone, Botswana
    Thanked: 1859
    Default Re: Generator fuel consumption?
    It is load dependent.
    Kobus
    Constantia Kloof
    Thanked: 2606
    Quote Originally Posted by zambuck View Post
    Hi guys.
    Thanks in advance.
    6 to 12L per hour would be a ballpark figure but it depends on various factors like load, engine make, engine size, altitude etc. a 100KVA wouldn't necessarily use twice the amount of fuel and you should be mindful not to install too large of a generator, they do not like light loads.
    Brandt Theunissen
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
  4. The Following 2 Users Say Thank You to Koebelwagen For This Useful Post:
    potchefstroom
    Thanked: 115
    Ons het op site n 175kva en het tussen 90 en 130 liter n dag gebruik
  6. The Following User Says Thank You to circe For This Useful Post:
    Thanked: 1294
    Quote Originally Posted by Koebelwagen View Post
    These figures seem to be spot on. The 100kVA should use a little bit less under the same load but when estimating one can use just below double for the 100kVA. About 5% less.
  8. The Following User Says Thank You to ekkekan For This Useful Post:
  9. #6
    Mar 2021
    Bronkhorstspruit
    Thanked: 13
    Our 40kva used around 30 litres per day.
  10. The Following User Says Thank You to Willem81 For This Useful Post:
  11. #7
    Friemersheim, Southern Cape
    Thanked: 5407
    Isn't consumption linked to the size of the engine powering the generator?
    Robert van den Berg
    '98 Daihatsu Rocky 'The Kitty'
    '02 Daihatsu Rocky 'The Bully'
  12. #8
    Thanked: 1722
    Just look at it from a car engine perspective.
    If you don't tow a heavy load, consumption will be less compared to the same engine size towing a heavy load.
    The more load you place on the generator, the harder it works to keep the devices on, hence more fuel is consumed.
  13. #9
    Polokwane
    Thanked: 1335
    Our 850KVA Scania V8 uses 60-90l/p/h depending on the load.
    Conqueror Courage 2016
  14. The Following User Says Thank You to DC Polokwane For This Useful Post:
  15. #10
    Thanked: 1436
    Hi guys.
    Thanks in advance.
    Isn't this sorta the same as asking how much fuel a 2L engine would use?
    I would assume make/model/age/technology all play a role in fuel consumption.
    2011 Freelander 2 SE
  16. The Following 2 Users Say Thank You to lizardalpha For This Useful Post:
  17. #11
    Oct 2017
    Rustenburg
    Thanked: 9461
    Quote Originally Posted by lizardalpha View Post
    I think he was just requesting a ballpark figure
    Andrew van Staden
    FJ - 2 Batteries, a tow bar, OME, Good Year Adventurers, and a drawer
    Ex:
    Ranger 3.2, LC 76 V8, Navara 2.5, NP300, Patrol 4.8, Everest 3.0, Jimny 1.3, Defender 110 SW Puma
  18. #12
    Feb 2013
    Thanked: 2431
    From experience, a 30 KVA 3 phase John Deere uses around 5l per hour running at between 70% and 80% load, if the phases are balanced correctly.
    The same generator would easily use up to 3l per hour if only loaded 10% to 20%.
    If I remember the most efficient spot to run a 3 phase generator is at 80%, otherwise the fuel consumption will go out of wack, so if you spec a generator for your house, that's the mark to aim at.
    "The man who does not read has no advantage over the man who cannot read" - Not Mark Twain
  19. The Following User Says Thank You to bigboy529 For This Useful Post:
  20. #13
    Feb 2013
    Thanked: 2431
    I have a friend who was part of the commissioning of 2 1.6 MVA monsters running in sync on a mine if I recall. They installed 60 kl underground diesel tanks for each of them. As part of the commissioning they tested them flat out, full load, I saw the video of the turbo's glowing.
  21. The Following User Says Thank You to bigboy529 For This Useful Post:
  22. #14
    Thanked: 13
    Thanks for the useful replyís so far guys.
    Yes Iím looking for a ballpark figure. It will be used for irrigation pumps when Eskom is out.
    The load will be fairly constant .
  23. #15
    Thanked: 13
    Quote Originally Posted by Willem81 View Post
    Thanks Willem81.
    Is that for 24 hours ?
  24. #16
    Feb 2013
    Thanked: 2431
    Unfortunately I was never good with sizing big generators, the 3 phases confuses me.
    As said 80% is the mark to aim at, however on the other hand you always think to your self that you should maybe oversize a bit in case you add additional pumps or something in future, so it will always be a compromise somewhere.
    If you want to oversize for possible future expansion, then I wouldn't go below 50% load, IMHO from around 50% they are fine and quite happy, as long as you don't run them at something like 20% for extended periods.
  25. The Following User Says Thank You to bigboy529 For This Useful Post:
  26. #17
    Polokwane
    Thanked: 1335
    Yes, one can clearly see the consumption go up from light load to heavy load, the load makes the big difference in consumption, so balancing your load with the genset output is important.
  27. The Following 2 Users Say Thank You to DC Polokwane For This Useful Post:
  28. #18
    Dec 2007
    Nkomasi
    Thanked: 498
    Hi guys.
    Thanks in advance.
    Sizing a generator must be carefully considered. Running at 50% is not good, 80% load is about the best for a generator.
  29. #19
    Thanked: 2691
    Not wanting to get into a big willy contest, but we looked at a condition monitoring system on an MTU engine that they were busy overhauling at a mine in Orkney. The motor apparently is the same one they used in their locomotives, and each piston was around 9.75ltrs. It was a V20! So just short of 200ltr motor. Truly a beast with a turbo either side that was the size of a Fiat Uno. It also ran a huge diesel reserve tank.
    Funny thing is that the consumption sounds awful, but the diesel motors do get more efficient as they get bigger so in terms of Kw produced / Diesel consumed they are actually not too bad.
  30. The Following 2 Users Say Thank You to stephenplumb For This Useful Post:
  31. #20
    Tshwanetoria
    Thanked: 1455
    Our 30kVA uses approx. 20 litres per 2 1/2 hour loadshedding. About 30% load
  32. The Following User Says Thank You to hatjohan For This Useful Post:
