Results 1 to 20 of 21
    Feb 2013
    Thanked: 2443
    Default Distance between borehole and septic tank
    Hi all
    There are probably differing municipal regulations, however what's a good practice minimum distance between a borehole and septic tank on a farm? Also does the depth of the borehole have anything to do with it?
    Google couldn't help much, I see anything from 10m to 30m in some countries, but can't find anything SA specific.
    "The man who does not read has no advantage over the man who cannot read" - Not Mark Twain
    Thanked: 20097
    Default Re: Distance between borehole and septic tank
    My opinion: as far as possible. Bacteria can penetrate an aquifer. I've heard as far as 100m.
    Jakes Louw
    Thanked: 1654
    The borehole and the aquifer are 2 different things, the aquifer could be 50-100m underground and over a very large area so I doubt any septic tank contamination will directly reach that far down?
    I'd thumbsuck and say somwhere in the range of 20-40m from the borehole should be fine, depending on what kind of underlying substrate there is, there are many variables to take into account.
    Also would probably be good to know how the local ground water drains into the aquifer and try place the septic tank in a location that will put it out of the way of any ground water flow.
    Feb 2013
    Thanked: 2443
    If I had a choice my head also says as far as possible.
    What I actually want to know here is whether there's a point where you steer clear of buying a place if you see that the borehole and septic tank is a certain distance apart. Or at least bargain on having to drill a new hole and then maybe only using the old hole for irrigation or something.
    This hole is maybe 40, 50m away from the septic tank if that far, it wasn't drilled too long ago and I don't think it's something the owners even considered when they drilled.
    I say that because it almost looks like they were lazy when drilling a new hole, as if they didn't want to drill a bit further from their house, they probably told the guy with the stokkies that he better find water within their yard.
    I don't know much about boreholes, but in my mind a bigger pump, more pipe, more cable will be worth the expense if you find good water some distance away over finding mediocre water on your doorstep.
  5. The Following User Says Thank You to bigboy529 For This Useful Post:
    Friemersheim, Southern Cape
    Thanked: 5428
    Hulle dra jou goed weg as dit ver is....selfs naby....
    Robert van den Berg
    '98 Daihatsu Rocky 'The Kitty'
    '02 Daihatsu Rocky 'The Bully'
  7. The Following 3 Users Say Thank You to Prof For This Useful Post:
    Feb 2013
    Thanked: 2443
    Ek het leeus oom, hulle gaan 'n ###### surprise kry as hulle eenige iets wil weg dra.
    Yes I know this is a factor, but it's in a big 5 game reserve which mitigates the risk quite a lot. They only have opportunistic petty crime, nothing serious from what I've heard from owners who has been living there for 20 plus years.
    Out of Town
    Thanked: 949
    Clarify Septic/Conservancy tank or a soak away. Septic or conservancy makes no difference where you put it. With a soak away on the other hand is a major problem. Regulations does say not within 300m of a water way or river. Underground water is fairly much an unknown.
    We have ground water at 2m from the surface in winter on the farm. Soak-aways are just not allowed here. If I had the slope, I could try proove that my soak away is in fact an evaporation field. But then it has to have a sealed bottom isolating it from the enviroment and any ground water supply. Thats kinda a mix of municipal rules and our own rules we have applied on our farm on the West Coast.
  10. The Following User Says Thank You to bfreesani For This Useful Post:
  11. #8
    Thanked: 20097
    French drain is a soak-away. Have the borehole tested for potability. That's the only real test.
    Jakes Louw
  12. #9
    Oct 2012
    Thanked: 640
    Do this anyway - check with the ;ab as regards the procedure and timing to sample and transport, particularly for e coli; I don't have that much experience but you will almost always pick up some. Luckily treatment is simple and cosy effective (chlorinator, uv light etc). Last test I did cost around R2 500 for more or less all the drinking water parameters which are as per the SA General Standard.
  13. #10
    Jan 2018
    CT
    Thanked: 236
    Nobody without a crystal ball (or a Geotech armed with a multitude of borehole log sampling) will be able to give you a definitive answer. Even then soil sampling may vary and test results could change over time with seepage and bla bla.
    Rather assume that the water may have some contamination and get a simple treatment goodie as Mudgrubber suggests.
  14. #11
    Thanked: 20097
    Quote Originally Posted by mudgrubber View Post
    Water test should be around R1k
    Jakes Louw
  15. #12
    Mar 2007
    Harties Boet
    Thanked: 2004
    well this sounds awesome! Buying a place in a big 5 reserve? Very very cool.
    in terms of distances, it really depends on a lot of stuff. Geology for one.
    also, if itís up gradient of the septic tank youíll have a better chance as well.
    As has been mentioned, the only way might just be to do regular water testing.
    Graham Robertson
    Nissan Patrol 4.8
  16. #13
    Hermanus
    Thanked: 38
    There cannot be a thumbsuck rule. It depends on the geohydrology of the area. Most important is the nature of the aquifer e.g. primary or secondary. Ideally you should not have a soakaway close to an aquifer.
  17. #14
    Thanked: 20097
    Quote Originally Posted by Kobus P Venter View Post
    Yep. The septic cannot be uphill from the borehole.
    Jakes Louw
  18. #15
    Mar 2015
    CT
    Thanked: 8
    Do you think gravity knows where the hill is below ground?
  19. The Following 2 Users Say Thank You to Facts For This Useful Post:
  20. #16
    Mar 2007
    Harties Boet
    Thanked: 2004
    Quote Originally Posted by Facts View Post
    in some cases.
    but more often than not groundwater flow direction is the same as topography. In SA at least.
    Graham Robertson
    Nissan Patrol 4.8
  21. The Following User Says Thank You to Graham For This Useful Post:
  22. #17
    Thanked: 20097
    Yes. In general, the water flows downhill in an aquifer.
    Jakes Louw
  23. #18
    Thanked: 888
    The septic tank is not the issue. The run off from the septic tank is key and must be away from the borehole. Also feed off to a well structured French drain - our farm one is 4metres x 2.5mts x 3 mts deep. Have a water spreader at the mouth of pipe where it enters. The best is drill holes 6mm along the length and close off end
    The more we talk about what is wrong, the less we see what is right in this world.
  24. #19
    Barberton
    Thanked: 3664
    Yip. The water table mimics the surface.
    Also, when you extract water from the hole, recharge is mostly gravity feed. So a septic tank at a higher elevation will be able to feed towards the hole.
  25. The Following 2 Users Say Thank You to RoelfleRoux For This Useful Post:
  26. #20
    Feb 2013
    Thanked: 2443
    Thanks all for the advice, my first step was going to be to get the hole tested and then also the water along with it to see what is what.
