Results 1 to 7 of 7
    May 2019
    Tongaat
    Unhappy Hilux Starter sluggish
    Hi allI have a 2014 Hilux dc 3.0 D4D and noticed the starting is abit sluggish at times. The problem is intermittent so I thought it was the battery so checked the water and topped it up. However that didn't resolve it, I got the battery tested and was advised the problem isn't battery related. It tends to happen as the bakkie engine gets hotter. I checked the wiring to the starter and all looks intact with no loose or damaged connections. Any ideas on what the actual problem could be?Thanks...
    Sep 2012
    Thanked: 88
    Default Re: Hilux Starter sluggish
    I had the same issue on my 2006 Hilux. Changing the battery made a tiny difference.
    I lived with it for years. Did not let me down.
    If I still had the vehicle i would strip the starter and clean it. That should help.
    Its not about how fast you are but about how quick you get there...
    Jan 2020
    Thanked: 246
    I had a Ford Husky panel van.(stolen) Also had battery checked but was ok. Eventually stripped starter and found a brush housing skew and out of true. Straightened out and it solved the problem. Unfortunately didnt stop them from stealing it.
    Ballito
    Thanked: 27
    I had the brushes replaced and works perfect.
    HiLUXURIOUS
    Nov 2014
    Thanked: 3559
    Mine very sluggish now, my indi completely certain it needs a recon. It's worked damned hard, we're very keen wildlife watchers and birders so on our breaks the car is off and on all the time, perhaps 100 times a day on a good day in the park. Due my 240k service, they'll take care of it then.
    Nemo me impune lacessit
    Apr 2021
    Klerksdorp
    Thanked: 19
    I've heard of this a few times now. Seems it is a common problem on the d4d's.
    May 2019
    Tongaat
    Thumbs up Re: Hilux Starter sluggish
    Thanks for the responses gents, very helpful.
