Results 1 to 15 of 15
    Sep 2020
    Default Gearbox/Transfer Case whine after clutch replacement
    Hi
    I recently had my clutch replaced on my Defender 110 2010 Puma with 135,000 km. Clutch was replaced as a precaution as it started to make that famous rattle noise and we going on a large trip to Namibia.
    After getting the vehicle back it suddenly has a whine coming from either the gearbox or transfer case. The mechanic says it sounds like the gearbox and that the clutch replacement could not have caused the sudden noise. I am not 100% convinced as the vehicle started making the noise 500m after it left the workshop and I never had problems...
    • The sound is present in all gears, except 5th.
    • Its still there, even in low range.
    • Not present when clutch depressed or coasting.
    • Whine returns as soon as my foot goes onto the accelerator.
    • Whine noise increases as revs increase.
    • They put some additive in the gearbox which subdued the noise for a day, but didnt really do much in the end.
    • Gearbox and TC oil levels checked.
    Any ideas what it could be? A bit frustrated that I wanted peace of mind and now have another problem to deal with.
    Thanked: 20097
    Default Re: Gearbox/Transfer Case whine after clutch replacement
    Clutch release bearing.
    Jakes Louw
    Sep 2020
    Why do you think its the clutch release bearing? Surely that is part of the replacement kit and would have been replaced when they installed the new clutch? Why would it stop whining in 5th gear and then whine again in 6th?
    Apologies for my ignorance, my mechanical skills are limited, albeit increasing every day I own this Landy.
    Thanked: 20097
    If the noise goes away if you press the clutch, then usually it's the bearing. Only other option is the main layshaft bearing in the box
    Jakes Louw
    Aug 2017
    Thanked: 365
    5th gear is 1:1 on the puma...maybe that will help someone who needs to diagnose the issue.
    Release bearing does not form part of the clutch kit, but best to replace with slave while gearbox out
    Oct 2015
    Rustenburg
    Thanked: 165
    Can it be that the bellhousing is scew and tension is on the spiggot causing the whine? Maybe
    Trying to rule out obvious faults.
    It does not make sense for a gearbox or T case to start whining after a clutch replacement?
    Are you sure it is the same gearbox as before? Devils advocate I know.
    If your boxes was not opened it should not whine unless like the other posts suggest it to be the thrust bearing.
    Other than that I have no clue.
    Barry Enslin
    ONE LIFE!
    Thanked: 328
    Dont these Puma boxes have a known issue on the output shaft from g/box
    might be wrong though
    Thanked: 20097
    Yep. I've heard that these spud shafts run dry and the bearing fails?
    https://ashcroft-transmissions.co.uk...put-shaft-kit/
    Jakes Louw
    Sep 2020
    From my research it does seem that the spigot bearing could be a possible cause.
    you sure it is the same gearbox as before? Devils advocate I know....
    This is my greatest fear - having changed the clutch under warranty, maybe they thought they could do the same with an old gearbox they had lying around. Again, this is definitely far fetched for a reputable place (but this time around I did make a small mark to check, just in case)
    Sep 2020
    Quote Originally Posted by Jakkals. View Post
    Yes, the 5th is the direct drive on these MT82s if I am not mistaken. I need to ask if they did the release bearing (it would be silly if they didnt do it). I did however put in a slave while this whole process was going on - better to be safe than sorry - and given that the gearbox was out, it was an opportunity to get it done.
    Thanked: 197
    I presume they took the complete Gearbox and Transfer box out as a complete unit and did not split it?
    I found that I have a bad whine after I worked on my Gearbox and Transfer box. I found the Shift to High Low was not quite the same as before and adjusted the linkages to a more Natural / comfortable setting, I found the whine decreased dramatically. Suppose it was the High / Low teeth running on the edge as they were not properly meshed. Maybe your problem?
    Edwin
    Defender '99 TD5 Pick Up
    Rock sliders, Spare wheel carrier, Roof Rack, Aluminium canopy, Tentco RTT, Tentco Awning, 280Ah Dual batteries, 3 x Sliding Drawers, Water tank, Hot Shower, Kitchen
    Sep 2020
    It is a known issue, but as far as I understand it makes a clunking noise when shifting, not a constant whine.
    As a side note, this looks like a nice upgrade to do one day:
    https://lofclutches.com/shop/clutche...v=68caa8201064
    These guys have the same spec vehicle as mine, so its always nice to see how they fix their problems before I tackle my own:
    https://www.youtube.com/watch?v=0rfGuMkNGZ8
    Thanked: 328
    "The sound is present in all gears, except 5th"
    That might be a clue
    My 5 speed box is straight thru in 4th
    maybe your straight thru is 5th ?
    Mar 2015
    New Germany
    Thanked: 1111
    On puma the 5th is 1:1 so straight through 1st 2nd are lower gears then normal and 6th is literally the same as 5th on R380
    2005 Defender TD5
    Oct 2015
    Rustenburg
    Thanked: 165
    Enige vordering Stofdonkie?
    Kyk baie van ons het n whine op die ratkas bloot maar van slytasie en ouderdom. Nadat ek my ratkas en amT-Case se bearings vervang het en als weer opgestel het was daar ook n whine wat nie voorheen daar was nie. Ek reken dit maar toe aan die ratte wat moontlik nie meer op dieselfde plek trap op mekaar met die ou bearings nie of selfs die pre load wat moet settle en so. Maar op n boks waaraan nie gekarring is nie maak dit bet nie sin nie.
    Hou ons op hoogte van jou ondersoek.
    Barry Enslin
    ONE LIFE!
