Results 1 to 14 of 14
    Jun 2018
    Thanked: 115
    Default BAIC South Africa Launches the B40 PLUS SUV
    Johannesburg, South Africa
    BAIC South Africa has officially announced the launch of their iconic SUV, the B40 PLUS today. The OEM, headquartered in Linbro Park, Johannesburg also boasts a local assembly plant in Coega, Eastern Cape which is set to create much-needed employment opportunities for the Port Elizabeth community. In addition, the facility, with a footprint of 10,000 hectares aims to produce 40,000-50,000 vehicles for local sale and export by the end of 2022.
    Mr Hu, Vice President of Marketing Operations for BAIC South Africa said “BAIC SA is proud to add the B40 PLUS to the model line-up. We believe this vehicle will be well received by the market and will find quite a following amongst consumers that want to stand out in a crowd.”
    Speaking of the company and its commitment to the country, Mr Hu added, “We are committed to the people of South Africa. We are actively working to improve the standard of the local automotive manufacturing industry, whilst creating more local employment opportunities. Our goal is to provide South Africans with a wide range of quality products to suit various lifestyles and requirements.”
    Heritage
    The B40 PLUS which has its roots in the military, has over 60 years of heritage to draw on. It has been tested in almost every condition, altitude, terrain, and application over this time leading to the claim that it was born in the battlefield and perfected in the real world.
    Design & Interior
    The design of the B40 PLUS is bold and imposing. The styling echoes the confidence of the driver, with aggressive bumpers and wheel arches. The vehicle commands presence whether it’s on city streets or showcasing its prowess off-road.
    The front of the B40 PLUS is striking, with the iconic 5-slot grille design that is inspired by the Great Wall of China. The chrome and black accents on the exterior contrast the vehicle’s body colour, adding visual interest. This is also echoed in the interior of the B40 PLUS.
    The bold design features imposing headlights with Daytime Running Lights (DRL) as well as front and rear fog lamps. The vertical windshield design, large exterior mirrors and high seating position make for great all-round visibility.
    The red tow hooks are a confident design characteristic on the B40 PLUS, while making it easy to pull, tow or rescue travel companions in other vehicles.
    NVH dampening is provided by the Liquid Application Sound Deadening (LASD) technology which increases the application area of the sound-dampening material in a vehicle by 50%, is environmentally friendly and allows for weight reduction in the vehicle while resulting in increased noise reduction.
    It doesn’t matter if you’re travelling city streets or exploring the hidden paths, you get to do it in comfort and style in the B40 PLUS. The considered cabin is modern, sleek and contains all the appointments you would need in an SUV from Dual Zone Air Conditioner, 6-speaker audio system, colour-coded interior trim, chrome accents and to top it all off, reclining rear seats.
    There are also features like the reverse camera, Park Distance Control (PDC), and customizable Multi-Information Display (MID), to keep the driver in complete control of his landscape.
    Off-road capability
    Mr Basil Costa, Senior Manager for Sales and Marketing, said “The B40 PLUS is more than capable off-road. The testing on extreme environmental adaptability included a process called “5 high & 1 drought” which included high temperature, high altitude, high humidity, high cold, high salt content and of course, a drought. This stringent testing process ensures adaptability to extreme conditions that is 10% higher than regular passenger vehicles.”
    The off-road ability did not just inspire the design, the B40 PLUS was designed with practicality, and functionality, at the forefront of consideration.
    The front suspension is a double wishbone/coil spring independent suspension while the rear suspension is a 5-link/coil spring non-independent suspension. The overhangs are minimal and combined with a ground clearance of 210mm, it results in a generous approach angle of 37 degrees, departure angle of 31 degrees and rampover angle of 23 degrees.
    The selectable 4WD system with mechanical central transfer case and rear differential lock allows driver control over how the engine is powered, dependent on the terrain, conditions and requirements.
    Safety and Security
    The B40 PLUS comes standard with a host of active and passive safety features to ensure your adventure is on your terms. Anti-lock Braking System (ABS) and Electronic Brake force Distribution (EBD) and Electronic Parking Brake (EPB) are standard across all models, while some models also feature Electronic Stability Programme (ESP), Emergency Brake Assist (EBA), Traction Control System (TCS), Hill Ascent Control (HAC) and Hill Descent Control (HAC).
    The B40 PLUS also has a built-in cage anti-roll body structure and anti-roll bar framework composed of a high strength steel plate and pipe beam, doubling protection and able to maintain integrity in a 50-metre hillside roll, ensuring the safety of driver and passengers alike.
    Engines
    The B40 PLUS is available in 2.0 litre Petrol Turbo or 2.0 litre Turbo Diesel. The choice is yours on how you power your adventure. The petrol engine kicks out 160kW @ 5500 r/min while the diesel pushes out 110kW @ 4000 r/min and 350Nm of torque at 1800-2800 r/min.
    Model line-up
    • B40 PLUS Diesel
    • B40 PLUS Petrol
    • B40 PLUS City Hunter Diesel
    • B40 PLUS City Hunter Petrol
    • B40 PLUS Champion Petrol
    Colour Range
    • Ice White
    • Onyx Black
    • Desert Red
    • Military Green
    • Forest Green
    • Sky Blue
    • Ocean Blue
    Pricing
    The B40 PLUS is priced quite competitively, offering generous features in all models in the line-up. The range starts from R549,500 and goes up to R629,500 for the top-of-the-range offering.
    Mr Basil Costa added “I look forward to seeing the B40 PLUS taking over South African roads soon. We believe the market will be pleasantly surprised at just how much vehicle they are getting with the B40 PLUS.”
    Aftersales Support
    All B40 PLUS models are sold with a 5-year/120,000km warranty. Competitive service plan options are available. Service intervals are 15,000km/12 months for both the Petrol and Diesel models.
    About BAIC
    After 59 years of unremitting development, BAIC Automotive Group Co., Ltd. (BAIC Group) has become one of the five largest automotive groups in China. With its headquarters located in Beijing and at the Turin Styling Centre in Italy and production bases all over China, BAIC Group currently has around 130,000 employees. It is one of the automotive groups in China with the most comprehensive portfolio of products, covering the full range from passenger to commercial vehicles.
    In 2018, BAIC Group achieved the promising results 2,402,000 sold units, making BAIC Group No. 5 in China’s automotive sector in terms of income and profit, and No.3 in terms of brand value. Today, BAIC Group 124th in the Fortune Global 500 and has been on the Fortune 500 list for the past 9 years.
    Business vision and international expansion with BAIC INTL
    BAIC International Development Co., Ltd. (BAIC INTL) is a wholly-funded subsidiary of the BAIC Group. Under the guidance of the board’s chairman of BAIC Group, Mr. XU Heyi, BAIC INTL is expanding its cross-border businesses with the aim of building “Global BAIC”. This visionary project will give birth to networks in the main regions of the world: the Middle East, West Asia, Central Asia, Africa, South America and several other regions. It will thus enable the BAIC Group to reach its strategic objectives and achieve internationalisation in terms of talents, markets, products, brand recognition and management. In order to solidify its global presence, BAIC INTL focuses on five main activities: export of finished vehicles and individual components; import of technologies; equipment and finished vehicles; product improvements; overseas investment; international cooperation.
    BAIC INTL’s core business is the development of reliable commercial, passenger, electronic and other types of vehicles. The implementation of BAIC INTL’s strategy is based on two main focal points:
    “Strategic business”: The development of the strategic target market and the introduction of complete supply chains.
    “Profitable business”: The import and export of vehicles and components and vehicle remodeling within the scope of international trade.
    General Aspirations
    BAIC INTL is committed to becoming a trendsetter, not only in terms of automobile design, but also by delivering a dynamic, stylish and tasteful lifestyle. BAIC INTL aims to offer vehicles equipped with user-friendly features that meet the standards of the international automotive market and fulfill customer expectations globally. Under the motto “Faster, Leaner, Smarter,” BAIC INTL will use the powerful combination of its innovative spirit and its strong research and development capabilities in order to achieve the top position in technology advancement, out-of-the-box business development and global resources integration.
    The BAIC South Africa plant project was officially launched in December 2015. The factory construction kicked off in August 2016. The first production units of SKD vehicles came off the assembly plant floor in July 2018.
    BAIC reiterates their plan to become a household name in South Africa and a bigger part of the economy from an employment and skills development perspective. BAIC vehicles are set to become a popular sight on our streets, giving much needed independence and mobility to an up-and-coming market.
ID:	633030   Click image for larger version.
ID:	633031   Click image for larger version.
ID:	633032   Click image for larger version.
ID:	633033   Click image for larger version.
ID:	633034   Click image for larger version.
ID:	633035   Click image for larger version.
  2. The Following User Says Thank You to MediaReleases For This Useful Post:
    Jul 2017
    Paulshof
    Thanked: 1062
    Default Re: BAIC South Africa Launches the B40 PLUS SUV
    10 000 hectare footprint?
    That factory must cover half of PE
    2018 VW Amarok V6 Auto 4Motion
    Dec 2006
    Thanked: 57
    I've seen it in Beijing and like it!!
    And since no JL in CRD as yet and maybe I could just do it...
    2012 Jeep Wrangler 3.6 Unlimited Sahara
    2022 VW Amatrok 3.0 V6 4motion
    2024 Suzuki Jimny 1.5 GLX 5dr
    2021 Sprite Splash/Tourer SX
    May 2019
    Brackenfell
    Thanked: 983
    If they bring the 2 door in manual, and reliability is proven, I am going to have a crisis of conscience.
    2018 Mitsubishi Pajero Sport 4X4
    2016 Mazda CX-3 2.0 Dynamic Auto - Sold
    2012 VW Tiguan 2.0TDi Bluemotion - Sold
    2009 Ford Fiesta 1.6 Titanium 3 door - Sold
    Dec 2006
    Thanked: 57
    Quote Originally Posted by WernerDL View Post
    Werner when I look at the international web, it seems like 4dr only...
    Mar 2012
    Thanked: 1824
    Joh even Fong Kong is getting expensive.
    GaryG
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
    4.0 XJ Jeep Cherokee - Sold
  8. The Following User Says Thank You to ViperR For This Useful Post:
    May 2019
    Brackenfell
    Thanked: 983
    Quote Originally Posted by Jacques_R View Post
    Ja for us, but I saw these online overseas - so hoping / or not hoping - I don't know!!
Name:	B40 3 door.jpeg
ID:	633671   Click image for larger version.
Name:	b40 3door 2.jpg
  10. The Following User Says Thank You to WernerDL For This Useful Post:
  11. #8
    Thanked: 1294
    ...the launch of their iconic SUV, the B40 PLUS today.
    How can a new vehicle be "iconic"?
    Tyrannosaurus R5 (sold) and now on my second second hand D4 British Tata.
  12. The Following 2 Users Say Thank You to JanB For This Useful Post:
  13. #9
    Ruimsig
    Thanked: 46028
    I dont quite see the value in the price
    Does the potential buyer view it as an alternative or an option to a more established brand?
    Value:
    1. the regard that something is held to deserve; the importance, worth, or usefulness of something.
    Alternative:
    1. (of one or more things) available as another possibility or choice.
    2. one of two or more available possibilities.
    Option:
    a thing that is or may be chosen.
    Estee = S T = Sean Towlson, A Schrodingers Douche Bag GOF
    ''In Western society, it is not the facts or the truth that are important, but the correct presentation of information, even if it is a lie.''
    Clank, a 1979 Ex-SADF Series III 109 SW powered by a Toyota 2B Oil Burner
  14. #10
    Feb 2012
    Thanked: 299
    So Grenadier made a better looking Defender/G-Wagon, and now BAIC have designed a better looking Jeep/Hummer.... I think mainstream vehicle manufacturers need to employ some Chinese designers.....
    Gary Walker
    Discovery 2 (Td5). Only LR owners will understand.
    Nissan Qashqai. The "Cash-Cow"
    BMW GS 1200LC Adventure. Redistributed
  15. #11
    Dec 2006
    Thanked: 57
    Quote Originally Posted by Tsotsi View Post
    BAIC is onto a nice G-Wagon too or should we say G-classless...
    https://www.baicintl.com/html/2020/O...d_1222/22.html
  16. #12
    Jul 2019
    Snor City
    Well I did NOT expect the engine to be a 1981 SAAB design
  17. #13
    Dec 2006
    Thanked: 57
    I have now learned that Jeep JL diesels does not exist in RHD , so this is becoming more tempting...
  18. #14
    Jul 2021
    Dubai
    Thanked: 171
    2 guys in the 4X4 club Iím in here in Dubai just got these. Had them about a month now. So far, they have proven to be quite capable and reliable. Guys are enjoying them.
    Letís see though when they want to start customising and modding them as 99% of all Jeep,owners do.
