Results 1 to 20 of 84
    PE
    Thanked: 136
    Default New building - what geyser options
    I am converting a garage to a flatlet and the guy that's doing my plans has indicated i need an "energy saving" geyser.
    What is your advice:
    - Solar geyser?
    - Heat pump system?
    - this new "waterwise" system?
    The water doesn't have to get very hot.. 40' should be ok..
    Sep 2019
    Boksburg
    Thanked: 492
    Default Re: New building - what geyser options
    Hi, it depends what you want to achieve / prevent:
    1. Counter load shedding with some cost saving?
    2. Save costs?
    For point number: 1. Gas Geyser
    2. Solar Geyser
    2019 Wildtrak 4x4 Bi-Turbo - Current
    2020 Ford Fiesta 1.0 Ecoboost Titanium auto - SWAMBO's new car and she loves it.
    2019 Ford Figo Trend Auto - sold
    2017 Everest 2.2 XLT - Sold
    2016 Ranger 3.2 Manual - Sold
  3. The Following 2 Users Say Thank You to Predator For This Useful Post:
    May 2007
    Thanked: 23
    I faced the same issue, ended up going the normal geyser route. I reasoned that the tenant was going to pay for the electricity anyway. I did set-up a separate meter (so they basically pay their own electricity – I get refunded whenever they buy electricity). However I did fit a “Geyser-wise” (limited the heat to about 50-55 degrees).
    Good luck with your decision
    Edwin
    [SIGPIC][/SIGPIC
    Toyota Prado 150 4.0 VX
    VW Touareg 3.0 Blue Motion – 2011 (Swambo’s)
    Jeep Cherokee 3.7L Sport - 2003 Sold
    Mods.: Frankenlift Premuim II - 2.5" Lift Kit
    ARB Bullbar, Airsprings - Rear
    Conqueror Commander-Sold
  5. The Following User Says Thank You to Jeep001 For This Useful Post:
    Feb 2013
    Thanked: 2460
    Who will live there, do you intend renting it out?
    If you will be renting it out and you look at gas then you must just be sure to make the gas refills for the cost of the tenant, otherwise they will kill you. If going gas you can even put in a gas hob for cooking, but again remember gas for the tenants account.
    Solar is also a option but if you'll be renting the place, remember either gas or solar will cost you much more to install than a normal electric geyser, so then you have to ask yourself whether you'll be able to recoup that money by asking more rent per month.
    A EV tube solar geyser can work great, a single person in a small flat having one bath / shower per day and washing dishes should be able to run on the sun only during summer time with no need for switching on the electrical backup element.
    Your least expensive option and the one I'll personally lean towards if renting the place is a class B energy rated electrical geyser with a Geyserwise timer. Least up front cost, least complicated and the tenant will anyway pay for the electricity. You can simply show them how the Geyserwise works and set it up for them to heat once or twice per day depending on their preference.
    "The man who does not read has no advantage over the man who cannot read" - Not Mark Twain
  7. The Following User Says Thank You to bigboy529 For This Useful Post:
  8. #5
    Aug 2020
    Oasis
    Thanked: 8649
    Daar is min goed so goedkoop soos 'n doodgewone ou donkie as geyser
    Willem Greyling
    Frikkie is my pel en ek erken dit...
    Ja die mense se ou Frikkie is 'n tappet...
    Tune tune baboon
  9. #6
    PE
    Thanked: 136
    Not renting out, it's for our adult kids when they stay..
  10. #7
    Feb 2016
    Brackenfell, Cape Town
    Thanked: 42
    Hello
    100 or 150 liter normal geyser with a geyserwise unit!
    I have a 250 liter solar geyser in my house. it works okish in summer, but to heat that thing in winter kills your electrical bill. I have considered changing to a smaller normal geyser, just a bit of an unnecessary expense and all the houses in the complex came with the solar units fitted.
  11. #8
    Cape Winelands
    Thanked: 365
    Quote Originally Posted by ralton View Post
    if it is not used daily, then go gas
    2011 CashCow 1.6 (Swambo)
  12. The Following User Says Thank You to Kamakazi For This Useful Post:
  13. #9
    Feb 2013
    Thanked: 2460
    Quote Originally Posted by Kamakazi View Post
    Agree with this, for occasional use go gas, costs you nothing if nobody is living there, also very low, almost no maintenance cost.
    Solar geysers have maintenance cost whether you use them or not, heat pumps also have annual maintenance cost.
    If you don't want to spend the initial amount for installing a gas geyser then electric with Geyserwise will still work just fine, you just entirely switch off the Geyser when not in use.
  14. #10
    Thanked: 1308
    When you know when your kids are coming to stay over you can switch the geyser on and off when they leave.
    This will also not use any power when not needed. Elec geyser just needs 2 hours to heat up from cold.
  15. The Following 4 Users Say Thank You to ekkekan For This Useful Post:
  16. #11
    Thanked: 315
    Gas.
    2 Weeks ago I installed a gas geyser as a test for a client who monitors his energy usage very closely. As a norm the house would consume between 36 and 40 unit of electricity per day.
    Since the gas geyser they are down to around 12 units per day - It totally convinced me to install a gas geyser in my own house!
    Si vis pacem, para bellum
  17. The Following 2 Users Say Thank You to thabogrobler For This Useful Post:
  18. #12
    Brisbane
    Thanked: 838
    We had a gas geyser in our previous house. One that heated a drum of water. Used to go through two (I think) 45kg cylinders every three months. We have an on demand gas heater now. Set to 50degrees. With a gas stove we probably use about two a year now.
  19. The Following User Says Thank You to BruceB For This Useful Post:
  20. #13
    Aug 2017
    Durban or Centurion
    Thanked: 1371
    Just be mindful of the risk of pathogens when the temperature is set too low.
    Legionella thrives at temperatures below 50C.
  21. The Following User Says Thank You to SAND For This Useful Post:
  22. #14
    Apr 2016
    Thanked: 118
    Are there any cases of this disease in SA?
  23. The Following User Says Thank You to Richard Mackay For This Useful Post:
  24. #15
    Barberton
    Thanked: 3674
    Quote Originally Posted by MANDREAS View Post
    Ai toggie. Julle Suidwesters verstaaaan nie. Ons Stateside ouens het nie tyd in die oggend om 10 myl te loop en hout maak nie.
  25. The Following User Says Thank You to RoelfleRoux For This Useful Post:
  26. #16
    durban
    Thanked: 1931
    I have often wondered about this myself. I think a prominent political leader died from legionnaires a few years back but Ive never heard of a case.
  27. #17
    Apr 2018
    Umhlanga
    Thanked: 796
    - Solar geyser?
    - Heat pump system?
    This is a personal experience.
    1) A solar geyser is NOT worth the money spent. I installed one at my house, and 8 years down the road, we have not even recouped a quarter of the money spent on the initial cost.
    The water is hot during the day, but cools down rapidly at night. So you need an electrical back up - which puts you back at square 1.
    No sun - No hot water.
    Stay away from Solar Beam. This company are crooks.
    2) A heat exchanger uses electricity to heat the water which still goes into the geyser.
    But it uses half the electricity to heat the water as a normal geyser does.
    I installed a heat exchanger/ heat pump 5 years ago for a client, and it is working perfectly. But it cost 22 grand.
    3) Gas geyser.
    I am having a gas geyser installed at my house this week, after getting various opinions and advice from forum members, and a "house call" from "Plunger" to give me expert advice as well. Thank you Plunger.
    Gas is cost effective. Dewhot gas geysers are locally manufactured. Come with a guarantee, and well priced.
    The main benefit of gas, is that it is hot water on demand.
    No constantly heating the stored water when not in use.
    As the owner of the flatlet, you want your tenant to use as little water & electricity as possible.
    Kitchen sink, hand basin, shower & toilet.
    LED lights
    Radiant shield underlay underneath the roof tiles/ sheeting
    Lots of natural light - big windows.
    I met some crazy people.... They made me their leader.
    2014 Mazda BT-50 - Recently bought. March 2018
    2013 Nissan NP300 - Daily workhorse
    1993 Ford Courier 2.2... Odometer stopped working just over 530'000 km's. Sold 2013
    69' Series 2 Landi - Old, slow, thirsty. Go anywhere. Stolen in 2010
  28. The Following 2 Users Say Thank You to AlexP For This Useful Post:
  29. #18
    durban
    Thanked: 1931
    - Solar geyser?
    - Heat pump system?
    What is waterwise system. ? There is no difference between solar geysers or heatpump geysers except for the bolt hole orientation. Solar geysers cater for brackets on roofs but if its in a cradle you can make a plan. I dont know if a solar geyser is much more expensive than a b rated geyser as I seldom fit solar geysers but they are almost exactly the same geyser. I would just bang in a 150l geyser if there are not more than three grown ups involved and if you can put the geyser outside ,even better. P E doesnt get that cold.
  30. #19
    Aug 2020
    Oasis
    Thanked: 8649
    Ons moet seker iets doen om al die bier en skaapvet af te werk, anders raak ons net so vet soos die Suid-Afrikaners
    Willem Greyling
    Tune tune baboon
  31. The Following 2 Users Say Thank You to Woestyn Willem For This Useful Post:
  32. #20
    Thanked: 1308
    Quote Originally Posted by thabogrobler View Post
    Gas.
    Interesting to see some households can use 28 units of power just for heating water. This is a massive saving.
    I wonder what the gas consumption would be on this installation.....
  33. The Following 2 Users Say Thank You to ekkekan For This Useful Post:
