Testing MAF Sensor
Results 1 to 2 of 2
    May 2016
    Jozi
    Thanked: 65
    Default Testing MAF Sensor
    What's the best way to TEST whether the MAF is getting power or not? "Unplug it" isn't the solution. Need to establish IF there is power TO, thus reading FROM would be helpful.
    The part number for the sensor is 22204-20010.
    I have a multimeter.
    Hillcrest
    Thanked: 11318
    Default Re: Testing MAF Sensor
    IMHO a bit of a useless test and waste of time. The probability of there not being power TO the MAF is probably a 1000 times less than a faulty MAF. Reading FROM is difficult and impractical.
    Best way is with a diagnostic computer. Problem is that it doesn't often fail in a way that can be detected with a multimeter. It has hot wire sensors that get contaminated, so they don't go open or short circuit, they just don't do their job properly.
    Read the entire article below.
    https://www.samarins.com/glossary/airflow_sensor.html
    ZS5KAD - PROFFESIONAL DUMBASS
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
