Results 1 to 5 of 5
    Wilderness
    Thanked: 1509
    Default 2011 3l 4x4 diff seal
    Hi guys.
    I am contemplating replacing the seal on the rear diff input.
    I saw some leak marks under the diff. I am not sure yet, whether it is only water and dust, or if there is oil involved.
    Anyone out there have the size of the seal please?
    Pieter Kemp.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Apr 2011
    Thanked: 85
    Default Re: 2011 3l 4x4 diff seal
    Investigate if your diff breather is not clogged.
    Had a leaking diff on my Landy, was advised to check the breather and found it was clogged. Cleaned it out and the leak "went away"
    '14 Isuzu KB300 4x4
    '98 Defender 90 TD5
    SOLD: '02 Mitsu Colt V6 4x4
    SOLD: '97 Mitsu Pajero V6 GDi SWB
    SOLD: '08 Audi A5 3.2 Quattro
    SOLD: '07 Audi A4 2.0 TDI
    SOLD: '04 Mazda RX-8
  3. The Following User Says Thank You to guido.e.koch For This Useful Post:
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 2594
    Leaking pinion seal can also be due (at times) to a pinion bearing starting collapse.
    Johan Maree
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    Conqueror UEV-25
  5. The Following User Says Thank You to JohanMaree For This Useful Post:
    Sep 2021
    Boksburg
    As mentioned, investigate if the diff breather is not blocked. Look inside the fuel filler door, just to the right of the filler cap is a small(too small) little thingy. That is where the diff breather "breathes". My kb300 diff is sweating a lot because this breather is to small. I need to reroute to the engine bay sometime when the arthritis and "skete" allow.
  7. The Following User Says Thank You to wcesnr For This Useful Post:
  8. #5
    Wilderness
    Thanked: 1509
    Thanx for all the advice. Anyone have the seal size?
    Pieter Kemp.
