Results 1 to 10 of 10
    Harties
    Thanked: 679
    Default Toyota Fortuner GD6 OBD Scanner
    I have a 2020 model Fortuner GD6 and want to get an OBD cable and software for this vehicle.
    It seems that the Toyota Techstream product is the way to go.
    Any advice or suggestions on which OBD scanner to use, or is Techstream then one to get?
    If you make a noise or need music in the bush or on the beach, youíre missing the point.
    Aug 2019
    Thanked: 415
    Default Re: Toyota Fortuner GD6 OBD Scanner
    You need a mini vci j2534 cable
    They are easy to get online
    Harties
    Thanked: 679
    Anybody on the forum using OBD Toyota Techstream?
    Thanked: 883
    Quote Originally Posted by PRA View Post
    Any9body on the forum using OBD Toyota Techstream?
    Yes, I use Techstream and the OBDll MINI-VCI J2534 Interface.
    From this site: Autotools: http://autotools.co.za/
    Direct link: OBDll MINI-VCI J2534: http://autotools.co.za/product/toyot...is-techstream/
    Harties
    Thanked: 679
    Thanks Searcher.
    Do you find that you able to access all Techstream functions for your vehicle and that they communicate/display correctly?
    Also, did you have any hassles loading Techstream on your laptop/PC?
    Thanks.
    Aug 2019
    Thanked: 415
    Thanks Searcher.
    Thanks.
    Yes
    No
  7. The Following User Says Thank You to Tiaan Pot For This Useful Post:
    PRA
    Harties
    Thanked: 679
    Thanks TP
    Thanked: 883
    Thanks Searcher.
    Thanks.
    The Techstream software sold by these vendors are "cracked versions" of Techstream. Many versions are available on the Web. I tried many of the 32-bit versions and they were not that great. Some of the Techstream functions were greyed out and not available.
    Techstream was also quite tricky to install for the first time.
    A 64-bit driver for Techstream is downloadable form Autotools. I found it much better than the 32-bit driver and most of the Techstream features are there.
    My 2005 Land Cruiser's ECU is a bit dated, so does not have all the features anyway. I tested mine unit on a 2010 Fortuner yesterday and it worked great.
    The 64-bit driver may or may not be a pain to install. On my earlier download attempt in 2020, Google Chrome saw the file as dangerous and blocked the download, I worked around this.
    Win10 Defender then saw it as a virus and put the file in quarantine. I unquarantined the file, marked it as safe, then installed it and it worked 100%. (Before releasing the file from quarantine, I went to the origional "Authors/Crackers" forum webpage and read up on it and by his assurances and by all online replies, I satisfied myself that the file was safe enough for me to use.)
    I downloaded the driver file yesterday again from Autotools (on a different PC) and Google Chrome again tried to block it, but I just overrode the warning and went ahead. I then ran the Win10 Defender virus scan on the file and got no warnings, so maybe the file has now been cleared or is less "risky" now.
    Driver file download link is here: https://mega.nz/file/VFMhGSJA#I8ACH1...tL7BT8vMA_i07U
    Download link is also here, but just takes you to the above link: http://autotools.co.za/product/toyot...is-techstream/
    (All at own risk of course )
    Either way it all works for me.
    Harties
    Thanked: 679
    Thanks Searcher.
    Iíve ordered the OBDll MINI-VCI J2534 OBD cable from bidorbuy. It comes with Toyota Techstream TIS V15 software on a CD - see here.
    Iím not sure if it will be hassle to load.
    Letís see.
    Aug 2019
    Thanked: 415
    Thanks Searcher.
    Letís see.
    There is one or two little quirks to get it going. But if you get stuck just ask here.
