Results 1 to 8 of 8
    Gaborone
    Thanked: 1362
    Default Loading a co-ordinate
    Morning,
    Please can the cartograpers of the world untie and assist me....
    How do you enter the below into a Garmin GPS?
    What should my coordinate format and datum be set to on my unit?
    This is like trying to decode the Rosetta Stone!
    ThanksName:  IMG_20210924_073157.jpg
    1997 Discovery 1 300tdi - Pussy Galore
    1996 Discovery 1 V8 - Mr Creosote
    Gaborone, Botswana
    Thanked: 1804
    Default Re: Loading a co-ordinate
    That is degrees, minutes, seconds. DMS
    Kobus
    May 2016
    Thanked: 4796
    Quote Originally Posted by MickeyBlue42 View Post
    Morning,
    You posted the waypoint as
    Deg Min Sec
    (although I have doubts about your example - Min & Sec should be 60 max)
    You have to convert it to decimal degrees.
    How you do it will depend on how well you know your calculator.
    The formula is
    Deg +Min/60+Sec/3600
    (for both Nothings and Eastings)
    Your example:
    19.1054 S
    22.1255 E
    You then enter the waypoint as
    Northing Easting
    eg 19.1054 22.1255
    2006 VW Touareg V10 (Sold)
  4. The Following User Says Thank You to 4ePajero For This Useful Post:
    Melkbosstrand
    Thanked: 609
    Or you can just use this site to do conversion for you...
    https://www.gps-coordinates.net/gps-...ates-converter
    Everybody needs to believe in something.... I believe I will have another Beer!
    Travel Blog: https://since1652.wordpress.com/
    https://www.instagram.com/since1652travel/
  6. The Following User Says Thank You to Papsak For This Useful Post:
    Hillcrest
    Thanked: 9581
    Or just set your Garmin to Lat Long - Deg : Minutes DM mode.
    It’s in the menu somewhere.
    ZS5KAD - PROFFESIONAL DUMBASS
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
  8. The Following User Says Thank You to Fluffy For This Useful Post:
  9. #6
    Gaborone
    Thanked: 1362
    Ok! Now we talking! Thank you
    This is why I did double science, history for matric.
    Geography was just not my thing!
    So why would a lodge give you that format if it needs to be converted?
  10. #7
    Robertson/ Larissa, Greece
    Thanked: 5632
    Deg Min Sec
    (although I have doubts about your example )
    You're being kind!
  11. The Following User Says Thank You to Francois Theron For This Useful Post:
  12. #8
    Mar 2017
    Okahandja
    Thanked: 1086
    There is no need to convert it. That is one format. Change your settings on your gps to that format and read it in. Then you can change back to format you prefer. And it will automaticly change to your preferred format. I prefer deg and decimal degrees. Degrees. Minutes. Seconds is the preferred format for land surveyors and it is shorters to display a very accurate coordinate. If you converter it you will see how many numbers there is after the decimal.
  13. The Following User Says Thank You to Erwin Schimper For This Useful Post:
