Results 1 to 5 of 5
    Feb 2012
    Thanked: 50
    Default Renault Clio Issue
    Hi all
    My wife has a Clio 11, 1.4 16v (2004 model) which is running fine.
    There is 1 problem however.
    After putting in fuel, the car starts perfectly, but then would not idle. After driving off, the problem goes away.
    This is not only when filling the tank, but also when putting in less fuel.
    Any idea what is causing this?
    PS, hope this explanation makes sense. Here it is in Afrikaans if not:
    My vrou se Clio start 1ste keer nadat ons petrol ingooi, maar vrek dan dadelik weer. Ek kan hom aan die gang hou deur die petrol pedaal te trap. As ek dan wegry, gaan die probleem weg en hy idle mooi met die volgende stop. Dit is nie nodig om die tenk vol te maak vir hierdie om te gebeur nie.
    Thanked: 800
    Default Re: Renault Clio Issue
    If it is the same as my wife's Clio 1.4i 16v (2001), it will get worse until it hardly ever idles...
    It was the idle control valve in our case. Replacement part 4 odd years ago was something like R5500 from the agents (on a car worth about R35k at the time), I eventually took the sample into a huge part store in Silverton (the name escapes me) and got a part off of a Nissan that was a close match. I can't really remember if it fully solved the issue, but I think it was at least a lot better. We sold the car a year or what later in order to buy an SUV as my wife felt unsafe in such a small car.
    Sep 2015
    Thanked: 219
    I see. So, that's the Clio softroader?
    Friemersheim, Southern Cape
    Thanked: 5198
    Not sure what is meant here?
    Robert van den Berg...(fully vaccinated with two Pfizer jabs & certified)
    '98 Daihatsu Rocky 'The Kitty' (jabbed with 50ppm)
    '02 Daihatsu Rocky 'The Bully' (jabbed with 50ppm)
    Sep 2015
    Thanked: 219
    Perhaps admin should move this thread to a non-softroader area.
  6. The Following User Says Thank You to Butch Dassie For This Useful Post:
