Results 1 to 10 of 10
    Jun 2016
    Default Hilux ABS problem
    Hello
    I was hoping someone here could shed some light on a problem I have.
    Hilux DC 3.0D4D 2012 4x2
    If I drive up or sometimes down a pass, tar road perfect conditions and turn left or right, the opposite side I am turning, the abs would engage briefly. That is if I turn right the left front brakes will engage just for a moment.
    ABS or ESP or both?
    Where do I start? Clean sensors or just replace them?
    TIA
    Jan 2020
    Thanked: 232
    Default Re: Hilux ABS problem
    As most of driving these days is tar roads and ABS seldom gets used thus it sometimes acts up due to lack of use. Try taking a good sand road and stomping on the brakes to lock up wheels. ABS should come into play and perform as it should. This will give the system a bit of exercise. M2cw. Good luck
    Thanked: 2651
    Quote Originally Posted by Wylie E View Post
    I sincerely hope nobody asks you advise about airbags!
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    083 399 2046
  4. The Following User Says Thank You to Uys For This Useful Post:
    Jan 2020
    Thanked: 232
    I'm not being sarcastic or anything. Used this myself from time to time. My Prado gets used in DAC mode from time to time going downhill needless to say it exercises the ABS quite a bit. My common 2 ( cents) sense.
    Jan 2015
    Thanked: 666
    Sounds more like a traction control issue than ABS. Since the outside wheels are travelling through a larger arc than the inner wheels, they would have to be turning faster. To the traction control it may appear that they are losing traction, so the brakes are applied to the faster turning wheels.
    Guy B. Vergoes Houwens
    2014 LC76 4.5 V8
    Henties
    Thanked: 2184
    Quote Originally Posted by ghouwens View Post
    Itís a 4x2. OP states the front brake engage. TC wouldnít work on the front axle, itís not a driven axle.
    Sounds like the stability control seems to think the vehicle oversteers. Are there any lights coming on on the dashboard, like ABS or stability control?
    Does this happen when stability control gets deactivated?
    2012 FJ Cruiser
    1983 FJ60 Landcruiser -sold-
    Jun 2016
    I think you might be on to something.
    No warning lights at all.
    I have switched off the ESP but it switches back on if i go driving speed.
    A member has sent me some info on troubleshooting. Will give it a go and report back.
    Jul 2016
    Thanked: 646
    Go into live values with diagnostic and check the steering angle sensor value
  10. The Following 2 Users Say Thank You to MikeBob For This Useful Post:
    Nov 2020
    Crosby
    Post Re: Hilux ABS problem
    Hi hope everyone is doing well
    Today I got my steering rack replaced on my 2010 toyota fortuner and after putting everything back together I took the car for a drive the alignment is totally off
    when I drive about 40 to 50 the brakes grind and the traction light comes with that there is a beep noise that also come on
    Just to mention 1 more thing the car looses power after 40 to 50
    Jun 2016
    Roodekrans
    Thanked: 37
    Quote Originally Posted by Tauhir View Post
    Cntl+c.....cntrl+v. Clever hey Were you ever in a class at school higher than f?
    Myne: Wildtrak 4x4
    Hare: GV 2.4
