Results 1 to 4 of 4
    Sep 2017
    Joburg
    Thanked: 8
    Default National Luna Rattling sounds
    Hi,
    My NL twin fridge mechanics or compressor really rattles a lot more than I like and I am wondering if anyone else has solved this problem.
    I have checked the mounting pins and rubbers and the proximity of the cooling fins to the covers plate and also eliminated other possible areas. I am starting to think that it could possibly be coming from inside the compressor. This fridge has been dragged all over Africa and endured the worst roads and still works well.
    Any suggestions gratefully accepted. Thanks
    May 2014
    Tshwanetoria
    Thanked: 1477
    Default Re: National Luna Rattling sounds
    Best to just take it in to the factory, close enough to you
    Thanked: 460
    Perhaps check the cooling fan,might be loose .
    edit:
    Sorry,see you already covered the possibility.
    Jun 2015
    Thanked: 35
    Your compressor mountings have broken, cannot be repaired as compressor is a sealed unit
