Page 13 of 14 FirstFirst ... 8 9 10 11 12 13 14 LastLast
Results 241 to 260 of 279
  1. #241
    Jun 2023
    Ceres
    Thanked: 28
    Default Re: Portable Solar Panels
    Having just received my Eiger 200w foldable panel today, I have read this thread with interest.
    Having no manual to work with, an initial question I have is:
    The MPPT is 12/24V. Do you have a setting to let the controller know you are running a 12v system?
  2. #242
    May 2021
    Thanked: 127
    Default Portable Solar Panels
    Edit: I somehow missed the MPPT part.
    I’ll redeem myself with a photo of the MPPT to go with Dogbert’s post.
    I’ll also attach the manual I found to go with the MPPT as I didn’t receive one either.
    200731 AKSR-MPPT_20A_01 User Manual Final V1.4.pdf
    Peter
    2018 Hilux DC 2.8 GD-6 4x4 Dakar MT Z43
    2021 RSI SmartCap EVO Sport canopy
    Maxxis Razr AT811 265/65 R17
    Giant Anthem Advanced MTB
    Victron MPII 5 kVA / JA Solar 5.46 kWp / SolarMD 14.3 kWh
  3. The Following 2 Users Say Thank You to kilimanjaro For This Useful Post:
  4. #243
    Oct 2006
    Thanked: 423
    Quote Originally Posted by Isuzu_man View Post
    Apologies for your unit not including instructions - will get that adressed. In the meantime, herewith some basic info to get you going:
    Yes - the MPPT will automatically detect 12/24V when connected correctly.
    THE MPPT CONTROLLER
    Please note: not following these instructions may cause damage to the MPPT controller.
    Ensure that you attach the positive (+) and negative (-) wires to the appropriate terminals.
    1. Connect the positive and negative wires from the battery into the terminals with the battery
    icon ensuring polarity is correct.
    2. The solar indicator light will turn on.
    3. Connect positive and negative solar input into the two terminals with the solar icon, ensuring
    4. The controller is now ready to use.
    5. For additional load circuit, connect positive and negative wires to the terminals with the
    lightbulb icon on the controller.
    NOTE: Ensure a fuse is used on battery positive wiring to prevent short circuits and potential
    damage to the unit or your vehicle
    John - '04 Prado V6
    CENTURION
    012-665-2079 e-mail RANDBURG 010-630-0210 e-mail
    BELLVILLE 021-949-0039 email PAARDEN EILAND 021-510-8112 e-mail
    Shop Securely Online at www.outdoorshop.co.za - Please contact the shops directly for fast service!
  5. The Following 3 Users Say Thank You to Dogbert For This Useful Post:
  6. #244
    Oct 2006
    Thanked: 423
    Here is the manual for the MPPT Charge Controller fitted to the latest Eiger Ranger & Cruiser Panels (attachment)
    Attached Files Attached Files
    John - '04 Prado V6
    CENTURION
  7. The Following 3 Users Say Thank You to Dogbert For This Useful Post:
  8. #245
    Hillcrest
    Thanked: 21496
    It’s not complicated
    Whatever charge controller you use.
    Connect the charger controller to the battery first. This allows the controller to detect the battery voltage.
    Then connect the PV.
    NAGOF
    HAM Callsign - ZS5KAD
    Freedom of speech is useless unless you allow people you don’t like to say things you don’t like………
  9. The Following 3 Users Say Thank You to Fluffy For This Useful Post:
  10. #246
    Dec 2009
    Malmesbury
    Thanked: 91
    The problem is people dont read the manuals. (if supplied)
    So what do they do. They start connecting from left to right (normal behaviour)
    Panel first then battery and then load.
    Maybe they should start changing the layout on the controllers.
    Riaan
    Mahindra S10 DC Pikup
    GWM Steed DC 2.8 TCi - Dastek(Sold)
  11. #247
    Jun 2023
    Ceres
    Thanked: 28
    Thank you Fluffy
    That makes sense.
  12. #248
    Jun 2023
    Ceres
    Thanked: 28
    Quote Originally Posted by Dogbert View Post
    Thank you Dogbert.
    Ordering and delivery of the panel was fast and efficient.
    Will have to sort out the XT140's internal cabling first and remove the current charge controller before testing the new panel.
    Trailer is booked on Monday for that.
  13. The Following User Says Thank You to Isuzu_man For This Useful Post:
  14. #249
    Bellville
    Thanked: 274
    100% spot on Fluffy. With the Eiger from C&C its all "solid wires" so you cannot follow this correct procedure as per your fewdback. I fitted 2 BH plugs to solve this issue. Maybe Dogbert can speak to his supplier to look into this?
  15. #250
    Jun 2023
    Ceres
    Thanked: 28
    What about removing the controller from the panel, mounting it in the trailer connected to the batteries.
    That'll solve the issue of picking the batteries up first?
  16. #251
    Centurion / Lagos Nigeria
    Thanked: 677
    Quote Originally Posted by SP1971 View Post
    I agree with this.
    If the foldable panel was supplied/wired as per the blanket, it would solve a lot of issues and potential comebacks
    Frik Eloff
    Isuzu 300tdi D-teq, reg vir die bos....
    Toyota Tuna 2.7 4x4 .... grudge necessity "not my choice"
  17. #252
    Stellenbosch/Plett
    Thanked: 76
    Any update on when the Cruiser 200 W will be back in stock?
    https://campandclimb.co.za/product/e...ng-solar-panel
    Land Rover Defender Puma 110 Station Wagon - finally found its set of 35s
    Volkswagen Amarok V6
  18. #253
    Oct 2006
    Thanked: 423
    Quote Originally Posted by kmcoetzer View Post
    Thanks for asking, the Cruiser with the new MPPT Charge Controller is back in stock
    John - '04 Prado V6
    CENTURION
  19. #254
    Sep 2023
    Thanked: 126
    Got myself a 125 watt Snowmaster solar kit today, on special al Chamberlains. See it can only charge AMG, GEL, Calcium and Wet, what size battery would the boffins recommend please...... It's only for lights and a 65lit fridge. Will charge the battery while driving as well.
  20. #255
    Sep 2023
    Thanked: 126
    duplicate post
  21. #256
    May 2011
    Thanked: 6156
    Quote Originally Posted by AndreZA View Post
    This looks like a good price.
    https://leroymerlin.co.za/agm-gel-ba...kle-100ah-20hr
    Sent from my SM-A336E using SA 4x4 Community Forum mobile app
    "When a clown enters a palace, he does not turn into a prince, the palace turns into a circus."
    Luka Geertsema
  22. #257
    Sep 2023
    Thanked: 126
    Thank you appreciate. I'll go for the 100ah
  23. #258
    May 2021
    Thanked: 127
    Quote Originally Posted by kilimanjaro View Post
    FOMO averted!
    Order just placed for the Eiger 200W Folding Solar Panel.
    Edit: collected in-store at the Bellville branch.
    Attachment 714586
    I’m very happy with this panel. I’ve since changed my setup to a NL DC25 and the panel works extremely well feeding into the DC25.
    I’ve also changed the cable to a 10m lead which provides that magic arrangement of having your vehicle in some shade and the panel out in full sun. I saw this in one of Peter Betts’ posts and vowed to follow suite one day.
    Yes, the panel is heavy but stores easily at the front of the load bin, propped in place by some (heavy) ammo boxes.
    The folding ability and the leg supports are faultless.
    Peter
  24. The Following 4 Users Say Thank You to kilimanjaro For This Useful Post:
  25. #259
    May 2010
    Greenstone
    Thanked: 478
    Sitting on the Zambezi and the Eigar has failed in the African sun on the 1st trip. You get what you pay for and this seems to be rubbish.
    2024 Ford Ranger XLT Super Cab.
    2013 Defender 90 2.2 LE.
    2006 Defender 110 DC Td5.
    1994 Discovery 1 200 Tdi Auto.
  26. #260
    S-West/Stellenbosch
    Thanked: 285
    Quote Originally Posted by Byron View Post
    Can't see was it from heat or impact?
    Is the panel dead now?
