Page 8 of 14 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 141 to 160 of 274
  1. #141
    Welkom
    Thanked: 452
    Default Re: Portable Solar Panels
    Quote Originally Posted by jphewitson View Post
    I'm setting up for a 2-month trip in late July, with a fair amount of time off-grid.
    I've just bought the Eiger Cruiser 200w foldable panel based on this thread, and I'm starting to experiment.
    ADVICE needed:
    The Defender has a dual battery system.
    I have another 100aH lead-acid battery as backup.
    Is it ok to link that one in parallel to the Landy's 2nd battery?
    Will they then both charge on the long drives, or will it be a problem?
    Thanks.
    My experience on my Pajero.
    When i connected my 2 batteries in parallel under the bonnet, i started going through starters. 4 x starters in 18months. I was told that there was to many CCA for the starter. So i put an in cabin isolator switch between the batteries and disconnect them when starting, ever since then my starter is lasting as normal again (touch wood almost a year now)
    When i am stationary i connect the 2 batteries and they both charge from the solar panels.
    When in motion i connect them together again and they charge from the alternator.
    It works well like this so far.
    05 Mitsubishi Pajero LWB 3.2 Did GLX
  2. The Following User Says Thank You to MarcoP For This Useful Post:
  3. #142
    Sep 2010
    Thanked: 52
    Great, thanks.
    I'll test them. Both are fairly new.
  4. #143
    Jun 2013
    Thanked: 5573
    I think I need to clarify.
    The two batteries in parallel should be after the solenoid/DC/DC interrupt to the crank.
    As Marco pointed out, two batteries in parallel will keep the same Voltage but double the amps.
    My bad for assuming that the dual battery system has a solenoid or DC?DC included.
    For interest sake what dual system do you have. ?
    Stranger
    GOF Club
    BMW R1200R
  5. #144
    Hartenbos
    Thanked: 1971
    For my Portable Fold up Panels I just go with the Brand I know >> Flexopower and I prefer the Mojave Models >> mine are 240 Watts
    Hilux 2.5 Litre DC 2015 4x2
    Summit Everest Trailer Full House
  6. The Following User Says Thank You to Peter Betts For This Useful Post:
  7. #145
    Hartenbos
    Thanked: 1971
    Quote Originally Posted by Graeme McConnachie View Post
    I am changing the Harrison plugs on the panel side to MC4 plugs which are "waterproof" & play from there.
    I do trust Fluffy's judgement but l've got nothing else to do!
    Graeme
    My Flexopower Panels have Brad Harrison plugs and work in the coastal rain conditions but I take them under the Trailer awning if I am in camp at that point
  8. #146
    Sep 2021
    Hi All
    I have a problem relating to portable panels. I received a 200w foldable panel (no regulator), but then on looking at specs it states that the Vmp is 20.5v and the OCV is 26.1v . I want to connect to my CTEK D250S and I am obviously concerned that the max input to the CTEK is 23v and the Ctek will fry. How can I reduce the OCV to below 23v? I thought of connecting an MPPT Controller to the folder panels and then to the CTek but somehow I don't think this will work. ... Note I know little or nothing about electrics.
  9. #147
    Mar 2011
    Walker Bay
    Thanked: 2180
    Hi Ted - I think you are referring to VOC - Open Circuit Voltage (Voc).
    This is the maximum voltage the panels can produce.
    As you note you don't want to exceed this voltage.
    I have the same Ctek and would never exceed its 23V. I am not sure of a safe way to avoid this limitation.
    Incidentally although I still use the Ctek I also have a Victron Mppt with a 100Volt limit. Gives plenty of room for solar.
    You could possibly not use the Ctek for solar and buy a separate Mppt charge controller and connect this to the battery as well.
    I have two solar charge controllers on my system but now mainly use the Victron. Victron's are excellent and you have the bonus of Bluetooth for monitoring.
  10. #148
    Sep 2021
    Many thanks Paul, I will take into consideration. I was trying to avoid a bit of rewiring and extra controller in my caravan.
  11. #149
    Mar 2011
    Walker Bay
    Thanked: 2180
    No major wiring needed.
    You can buy a PWM solar charge controller (lead acid batteries) for a few hundred rand. (Takealot). Check the voltage limits!
    Mount it somewhere (not sure of where your Ctek is) and connect to battery
    either permanently (or with croc clips for temporary camping). I mounted my Victron on the side of
    an ammo box with a piece of offcut. If you don't want to DIY 15 minute job for any auto electrician.
    Being a solar beginner in 2011 I never realised the voltage ceiling of the Ctek's. This really limits
    adding more panels in future as voltage adds up for each additional panel. You don't have to worry about Amps.
    Always recommend Victron - expensive but reliable with warranty, great apps and huge user group. When my Ctek eventually dies I will replace with a Victron DC-DC charger.
  12. #150
    Sep 2021
    Thanks Paul again. I have thought up a slightly different solution as I have a Powerbank (with Lifepo4 batteries) (716wh) with a 230v outlet. I can charge from the 230v outlet of the Powerbank to the caravan's 230v inlet and charge the Powerbank via the foldable solar panels. Whilst the solar input will be lower than the output (whilst charging my 2 x 105ah batteries from say 50% capacity and really only running the 90l NL Fridge/freezer at the same time), i should have enough time (with decent weather) to top up the caravan batteries and then recharge the Power bank when caravan batteries are full. I will have to test. I do have a Victron MPPT controller that can take upto 75v input which will be my 2nd choice if the Powerbank doesn't work well enough.
    Ted
  13. The Following User Says Thank You to TedBaxter For This Useful Post:
  14. #151
    Thanked: 108
    Quote Originally Posted by Bush2C View Post
    Just got the Cruiser version of the 200W Eiger blanket, where the 5 panels fold out in a row, each with its own built in stand. Very easy to set up! Unzip the bag and take out the accessories. All the panels in their "rolled up" configuration then rest on the stand of the first panel. Open the "roll" to the next panel together with the stand for the next panel, and so further. Takes about 10 seconds to have the row of 5 panels standing.
    Three questions please:
    1. The leaflet refers to setting the "float" charge voltage. On my 100Ah FNB leisure batteries float is at 13.6 and bulk is at 14.4. Is the terminology in the leaflet correct? Should I not set it to bulk rather than float?
    2. The controller instructions provided earlier in this thread refers to the default battery type as lithium. Which of the three options is sealed lead acid?
    3. I measure a 0.8V voltage drop from the panels to the battery using a 20m x6mm extension cable. Increasing the charge voltage setting on the controller to even 16V makes no difference to the actual voltages on the controller and and the battery. Why does increasing the charge voltage setting not compensate for the voltage drop with the extension?
    I was running the 74 liter NL fridge off the battery during the test. When the compressor is running the the voltages at both the battery and the controller drops by 0.7V.
    Would be grateful for your thoughts.
    Attachment 690658
    Attachment 690659
    Used the panels on the Moremi trip, worked well.
    Couldnt do without the 20m extension, had to add the supplied 3m cable as well to get to a sunny spot in North Gste.
    Kept the batteries charged and the NL74 lilre fridge running, with the freezer set at minus 8. Charge setting on the regulator was 14.4V, but with the extension the charge voltage was never above 13.6V (100% or top orange LED) on the NL indicator. This was enough to do the job, though. Batteries were charged within 2 or 3 hours.
  15. The Following User Says Thank You to Bush2C For This Useful Post:
  16. #152
    Dec 2007
    Back in Boksburg (ex PE)
    Thanked: 33
    So i have gone through all the above threads and was very keen on the Eiger 200w panels with stand-- WHEN suddenly i get a offer on a brand new, never used Eiger 200W blanket -- like flint its in my car and home it came.
    Tested and used it in Gonarezhou, Mabuasehube, Mozambique and a few local wild camps-- works well, plenty power- (Victron MPPT and AGM Battery in trailer / Intervolt to lithium battery in the car. -- very happy.
    BUT -- my dilemma is the lack of frame.. yes i can hang it on sides of car, but then must move car around all the time, yes i can hang it on trailer, but then must move panel around all the time.
    Has anyone built a fold up/ dismantle type frame yet?
    Hot and Sweaty- Nice if you with a Lady, - BAD if you in the Jungle.
    Triumph ST 1050
    Toyota 2.8 Auto
    Honda CBR 1000
    Toyota Fortuner D4D
  17. #153
    Mar 2011
    Walker Bay
    Thanked: 2180
    That is the problem of blankets. I have one. Who wants to have your 4x4 in the sun all day?
    The Cruiser looks like a better buy.
    https://campandclimb.co.za/product/e...ng-solar-panel
  18. #154
    Thanked: 4271
    I would build frame using either 19mm or 25mm aluminium square tubing and Connect-IT corner pieces. Disassembled, the frame will hardly need any packing space.
    Mike Lauterbach
  19. The Following 4 Users Say Thank You to mikeml For This Useful Post:
  20. #155
    Thanked: 4599
    Quote Originally Posted by Tony View Post
    In summer, just lie it flat. Almost ideal angle.
    Winter is an issue, I think you need 45°. I used to just prop one half of the blanket on a rock or other object so half is ideal, other half was lying flat.
    Not perfect but did the job if you don't want to use it as a windscreen sun protector.
    "K.a.k Wheeler"
    Dont take anything I say as actual advice or fact. I dont.
    GWM P Series 4x4 Limited
    Ex 2019 Ranger DC XLT Manual 4x4, 2017 XL Auto 4x4, Ex Haval H9
    Ex 320d, Maz MPS, CITI Golf, Anglia Van
  21. The Following 2 Users Say Thank You to PsyPhin For This Useful Post:
  22. #156
    Thanked: 5791
    Why dont you just make three poles that you can hammer into the ground, add an eyelit and some bungee cord. Attach those to the little noose on the panel. Or rod stands can also work.
Name:	Rod stand.jpg
    "When a clown enters a palace, he does not turn into a prince, the palace turns into a circus."
    Luka Geertsema
  23. The Following User Says Thank You to Luka For This Useful Post:
  24. #157
    Jul 2023
    Ekurhuleni
    Thanked: 14
    Wonder if anyone can help. We have these panels. Just purchased. But we only getting 4A charge into the system. Checked all the panels are working. Is this what everyone gets? I was expecting more?
    https://campandclimb.co.za/product/e...caAg-BEALw_wcB
  25. #158
    Sep 2008
    Vanderbijlpark
    Thanked: 808
    Quote Originally Posted by Bullbulls View Post
    Without us knowing what the rest of your system looks like, it is impossible to give an answer. What type of charge controller? What type of battery? What is the battery's state of charge? Any diagram?
    ZS6VL
  26. The Following 2 Users Say Thank You to An3s For This Useful Post:
  27. #159
    Hillcrest
    Thanked: 20832
    Quote Originally Posted by An3s View Post
    We need to know where you are measuring 4A, at what voltage and under what conditions.
    Also remember that the panel will only deliver what the load needs. So, in full sunlight the current will be 0A into a fully charged battery.
    Panel testing is complex and not for sissies.
    NAGOF
    HAM Callsign - ZS5KAD
  28. The Following 5 Users Say Thank You to Fluffy For This Useful Post:
  29. #160
    Jul 2023
    Ekurhuleni
    Thanked: 14
    Thank you. I am new to this and learning by the hour. We have a summit trailer that has an HCDP MK7S SYSTEM so we don't use a controller as I understand that the controller is built in? The battery is pretty flat but not completely flat. We measured mid day in Joburg. Clear skies with very little haze. 101ah battery. 5 m Extention cable that came with the panel with bh connectors. Does this help?
