Page 12 of 14 FirstFirst ... 7 8 9 10 11 12 13 14 LastLast
Results 221 to 240 of 278
  1. #221
    Aug 2017
    Bellville
    Thanked: 274
    Default Re: Portable Solar Panels
    On mine i have float at 13.7 Discharge Reconnect at 12.6 Diacharge Stop 12.3 Workmode 24 Battery Tipe B01
    I have a 12 V 95 AMPH Enertec Deepcycle battery.
  2. The Following User Says Thank You to SP1971 For This Useful Post:
  3. #222
    May 2021
    Thanked: 127
    Default Portable Solar Panels
    Quote Originally Posted by SP1971 View Post
    Thanks @SP1971. I have the Enertec 80Ah deep cycle battery. So quite similar. (When I bought this they didn’t have larger in stock and I couldn’t wait)
    The reason for asking these questions is because I got an alarm on the NL remote monitoring console. At that point in time, the voltage was showing 14.7V and the monitoring console only goes up to 14.2V. I believe the alarm goes off at 14.4V.
    So my main concern is should I be limiting the voltage (as you have done) - one would assume that the charge controller has “safe” settings at default but I’m worried that’s not the case.
    Peter
    2018 Hilux DC 2.8 GD-6 4x4 Dakar MT Z43
    2021 RSI SmartCap EVO Sport canopy
    Maxxis Razr AT811 265/65 R17
    Giant Anthem Advanced MTB
    Victron MPII 5 kVA / JA Solar 5.46 kWp / SolarMD 14.3 kWh
  4. #223
    Centurion / Lagos Nigeria
    Thanked: 662
    My settings;
    Float : 14.2V
    Discharge reconnect : 12.3
    Discharge stop : 12.0V
    Workmode 24
    Battery type B01
    I'm using the NL Grey Box with monitor and it has never exceeded 13.8V when connected to the Solar panel and controller
    Frik Eloff
    Toyota Tuna 2.7 4x4 .... grudge necessity "not my choice"
  5. The Following User Says Thank You to 280iNyati For This Useful Post:
  6. #224
    May 2021
    Thanked: 127
    Thanks @280iNyati. Right now, my controller has gone haywire and I can’t change the settings. I can’t seem to reset it either.
    I don’t have much confidence in this controller because this morning it was dead - and I got the panel swapped out. Now on my second one and the controller is unresponsive.
    Peter
  7. #225
    Aug 2017
    Bellville
    Thanked: 274
    Quote Originally Posted by kilimanjaro View Post
    Hi Kili. Exact reason why i fitted 2 x BH plugs to my MPPT controller. Had the same issue when i initially set mine up for the first time. Now it works 100% after the mod! I first connect BH to my battery and then connect the 2 BH on the MPPT. When i disconect to pack up and go home i first disconnect the 2 panels and then the BH connected to my battery. Safari Centre assisted me to fit the 2 x BH plugs on my MPPT. Was just over R200 for parts and labour.
  8. #226
    Oct 2017
    Thanked: 17
    I see the Eiger Cruiser seems to be out of stock at the moment.
    Has anyone tried these Red-E panels? Red-E 200W Foldable Solar Panel | Portable Power | Solar Power (campandclimb.co.za)
    Besides the price, are they pretty much the same or better than the Eiger Cruiser? I'm wondering how quality feels like compared to the Eigers.
  9. #227
    Thanked: 662
    As from other discussion on the forum; the above is more or less the correct sequence to connect
    Connect the PWM / solar controller to the battery 1st
    Make sure all settings are correct
    Then connect the controller to the solar panel
    This means that you need to slightly modify / change off the shelf combo's to work as above
    Frik Eloff
  10. #228
    Hartenbos
    Thanked: 1978
    I have never had any Probs from my Portable Flexopower Mojave 240 W Panels >> Plug and Play
    Hilux 2.5 Litre DC 2015 4x2
    Summit Everest Trailer Full House
  11. The Following User Says Thank You to Peter Betts For This Useful Post:
  12. #229
    Thanked: 94
    Let's ignore manufacturers' test results under ideal (maybe lab?) conditions which remind be rather like the miles per litre motor industry fuel economy tests! I have never achieved what was claimed for my car.
    What I have learnt since camping with solar from 2011 is that the quality of the solar panel cells varies depending on the price and brand. The panels are designed at a price point and I would not expect the cheaper panels with less expensive components to perform as well. Redarc mentioned earlier for instance is an expensive brand with very good performance and maybe an unfair comparison.
    Overall most consumers don't know what they are buying and seemingly rely on test ratings. One of the companies which does disclose the info is Sunpower - a colleague recently bought one of their panels and it stipulated the cell technology - "Maxeon GenIII Me3bin solar cells" - he knew he was buying excellent performance! (https://us.sunpower.com/company/history).
    Some sellers specify two ranges - their top and then an economy range. Flexopower - a long time solar supplier in South Africa - for instance has its top Mojave panels and then the Namib series.
    The other grey area with portable panels is that few of the sellers spec what their IP (waterproof) rating is! Can you leave them out in the rain even for a short period? What happens if you go for a walk and it rains? I was intrigued the other day to find that EcoFlow is actually specifying that its 160W panel is waterproof! -
    "due to a seamless, one-piece design, making it ideal for outdoor activities like camping and hiking." Most of the EcoFlow panels are rated IP68. You will find that some companies will say "can withstand harsh conditions" without detailing what this implies!
    Overall before buying solar do your homework and consult widely among our forum.
    Just read this. I have this “delamination” problem with my Flexopower Namib 240. I have only used it on 5 camping trips over 12 months since I’ve purchased it new, directly from Flexopower. Could this be a waterproofing issue Click image for larger version.
    When nature calls
    Jacques Steyn
    2009 Toyota Prado 150 VX (202kw)
    OL Front bumper | Snorkel | OME Suspension
    Swambo : 2012 VW Polo 1.4 Comfort line
    Ex 2008 Nissan Patrol 4.8 GRX A/T (199kw) | TD Suspension | Outback Extreme Rear Bumper | Ironman Front Bumper | Air Helpers | Snorkel | FR Roofrack
    Ex 1996 Ssangyong Musso 602EL TD A/T Exec (82kw) |Snorkel | Bilstein B6 | Disco 2 springs | FR Roofrack | ARB Front bumper | Rear Bumper
    Ex 1982 Citroen CX Prestige automatic
    Ex 1976 Citroen GS Club
    Ex 2013 Honda CRV Exec Auto AWD
    Ex 2007 Toyota Auris 2.0 D4D
    Ex 2010 Honda Accord 2.4i Exec Manual (148kw)
    Ex 1997 Isuzu KB280LE TD D/C 2x4
    Ex 1997 Toyota Corolla RSI (121kw)
    Ex 1989 Toyota Corolla GLI TwinCam Exec (98kw)
  13. #230
    Thanked: 94
    Quote Originally Posted by AceVentura View Post
    Just read this. I have this “delamination” problem with my Flexopower Namib 240. I have only used it on 5 camping trips over 12 months since I’ve purchased it now, directly from Flexopower. Could this be a waterproofing issue Click image for larger version.
    When nature calls
    Jacques Steyn
  14. #231
    Thanked: 94
    When nature calls
    Jacques Steyn
  15. #232
    Oct 2006
    Thanked: 423
    Quote Originally Posted by woogs View Post
    Great News, the Cruisers have landed and will be in the shops next week!
    John - '04 Prado V6
    CENTURION
    012-665-2079 e-mail RANDBURG 010-630-0210 e-mail
    BELLVILLE 021-949-0039 email PAARDEN EILAND 021-510-8112 e-mail
    Shop Securely Online at www.outdoorshop.co.za - Please contact the shops directly for fast service!
  16. The Following User Says Thank You to Dogbert For This Useful Post:
  17. #233
    May 2021
    Thanked: 127
    Quote Originally Posted by 280iNyati View Post
    My settings;
    Float : 14.2V
    Workmode 24
    Battery type B01
    So Andrew from Enertec advised me to use the following values which I’ll drop here for comparison:
    Bulk: 14.4 - 14.8V
    Float: 13.6V
    Cut-off: 11.8 - 12V
    Peter
  18. The Following 2 Users Say Thank You to kilimanjaro For This Useful Post:
  19. #234
    May 2021
    Thanked: 127
    This is what the default values were on my Eiger 200W folding solar panel:
    So just a warning to adjust the values because they could be different to the defaults specified in the 2-page manual on the C&C product page.
    Peter
  20. #235
    May 2021
    Thanked: 127
    Just an update, I visited C&C again today. By now the branch manager, JP, knows me very well. He saw for himself that my controller was misbehaving and could no longer be programmed. They swapped out my controller, since they were out of stock of the Eiger 200W folding solar panels.
    Initially we could change settings and then the (swapped) controller also started misbehaving. JP took it inside, out of the sun, and we were able to change the settings again.
    So all’s well that ends well - and a bit of PWM controller experience for me. At least I know my setup now before heading into the bush soon.
    Peter
  21. The Following User Says Thank You to kilimanjaro For This Useful Post:
  22. #236
    May 2021
    Thanked: 127
    My next question, is whether or not I should get one of those Lumeno 200A “power analyser” / energy meters. Not cheap at R455.00 RRP.
    https://www.lumenoled.co.za/product/...olt-amp-meter/
    Considering that a Victron SmartSolar 75/15 is R960.00, I’m a bit on the fence on which route to go.
    On the one hand I will be able to observe Amp, Volts, Watts and Watt Hours. The meter also accumulates and stores the data. All at half the price of a Victron MPPT with Bluetooth.
    On the other hand, I will still have a cheap PWM controller with unknown lifespan and reliability.
    What say you all?
    Peter
  23. #237
    Wartburg.
    Thanked: 2171
    What say you all?
    That's easy, Victron.
    Rather get something else to worry about on your trip than worrying about is it charging, is my fridge cold.....
    Toyota Land Cruiser 79 DC V8
    Toyota Land Cruiser 79 SC V8
    Toyota RAV-4 2.2 D4D
    ZS5CL
  24. The Following 2 Users Say Thank You to Chris8d For This Useful Post:
  25. #238
    Palm Lakes Estate, Umhlali
    Thanked: 326
    I am totally happy with my Eiger foldable panels, work brilliantly with my "A" frame stand (see post 132), but I didn't like the controller
    that it came with. Couldn't work out the settings etc, bought another (about R300) now sorted.
    Reading this thread has taught me that you attach controller to battery first, then the panels. This may be the reason
    I changed the controller!
    Graeme
    2010 Puma 2.4 110
    2014 Kuga 2.0 D Titanium
    Skipper Oyster LT 75
  26. The Following User Says Thank You to Graeme McConnachie For This Useful Post:
  27. #239
    Okahandja, Windhoek
    Thanked: 2053
    Doesn't look good, I would take them back?
    Johan Kriel
  28. #240
    May 2021
    Thanked: 127
    I’ve now done extensive testing on the Eiger 200W folding solar panel and can confirm the following:
    1. The bulk/absorption charge specification for the PWM controller is undocumented and I don’t know what the ceiling is - but this is a problem. It cannot be set anywhere.
    2. The 3 stages of the PWM controller are also undocumented.
    3. By observation it seemed that the bulk charge voltage was in the range of 14.4 - 14.8V but it is exceeding this and reaching 14.9 - 15.0V. (Photograph above) This is over the spec of my Enertec 80Ah lead acid battery so the controller will damage my battery.
    4. As a comparison, Victron MPPT controllers bulk charge at 14.4V.
    5. I’ve had discussions with C&C about all of this and, while I can’t advise the general public, I am asking for another controller - hopefully the MPPT that comes with the solar blanket.
    Edit:
    Just an update, I’ve had very good service from both C&C and Eiger Trade. Eiger are dropping off a MPPT controller for me tomorrow.
    Peter
