Results 1 to 4 of 4
    Feb 2020
    Default Campmaster Fride Power Problem
    Hi, has anyone else had the problem of their fridge not running on 220v and only 12v, and if so what's the solution,Thanks in advance
    Jun 2015
    Thanked: 35
    Default Re: Campmaster Fride Power Problem
    The snomaster switching power supply is faulty from a power surge. Will have to be replaced
  3. The Following User Says Thank You to calitzfamily For This Useful Post:
    Thanked: 22
    Speak to Johan Prinsloo. He does repairs on all types of camping fridges. He is in Pretoria. 0 eight two 90 three 99 seven one.
  5. The Following User Says Thank You to Skilpad#7 For This Useful Post:
  6. #4
    Feb 2013
    Thanked: 2443
    On the National Luna it's the compressor controller which needs replacing, I just had one done at upwards of R3k.
    I assume if the Campmaster have a Danfoss type compressor it will probably be much the same problem.
    "The man who does not read has no advantage over the man who cannot read" - Not Mark Twain
